97 chevy cummins swap - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2018, 09:22 AM   #181
no1mover
are you going big power wiff the 24v
no1mover is offline   Reply With Quote
Old February 8th, 2018, 09:40 AM   #182
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Maxed and balanced pump, injectors, cam, just the normal stuff. 500-600 hp ??
sbcrichie is offline   Reply With Quote
Old February 12th, 2018, 05:36 PM   #183
no1mover
That should git a trailer around rite nice.
Old February 12th, 2018, 05:48 PM   #184
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Yes I'm hoping so
Old February 12th, 2018, 05:54 PM   #185
no1mover
i gave a guy from Ann Arbor your number, he needs a little wiring work on a 57 chevy. I told him you do great work. I hope you can help him.
Old February 12th, 2018, 05:57 PM   #186
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thank you
Old April 21st, 2018, 07:09 PM   #187
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Old April 21st, 2018, 07:13 PM   #188
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Finally got this thing going again. Changed cooling system, built new intercooler system, rear discs, abs module delete, built new exhaust, whole new fuel system, built new trans crossmember. Gotta love when projects spiral out of control.
Old April 21st, 2018, 08:05 PM   #189
Kegger83cj7
Kegger83cj7's Avatar
You have quite the shoehorn there. Looks great. A lot tighter in that style Chevy....
Kegger83cj7 is offline   Reply With Quote
Old April 21st, 2018, 09:36 PM   #190
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Yes pretty tight fit in these trucks.
Old June 18th, 2018, 08:09 AM   #191
smittySS
Great build!
And looks like a lot of fun being added to it.
I have a 1997 K2500 Suburban and I'm in the processes of swapping in a 12 valve.
I'm curious, what was the application or the part number for the A/C compressor you ended up going with?
So far the issue I see I may have is the Suction and Discharge are swapped for the Manifold lines I have. The compressor has the Discharge below the Suction, I have a manifold line for a 1994-97 Ram, and the set that was on my 7.4 in the Suburban, both when positioned on the compress would put the Discharge above the Suction.
I noticed yours appeared to have individual screw in fittings, that could help my situation.
I have plenty more work to get done before the A/C has to be done. I have to keep plugging away at the other things as I try to figure out what I'll do with the A/C lines.
Thanks for all the info you've already shared.
I look forward to seeing some more updates on your build upgrades!
Smitty
smittySS is offline   Reply With Quote
Old June 18th, 2018, 08:12 AM   #192
greygoose
Gustafson
greygoose's Avatar
You should start a build thread for your Burb.
Old June 18th, 2018, 08:20 AM   #193
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I honestly canít remeber what ac compressor I have, if you search the internet really well you will find it, Cummins high mount ac bracket, I think itís a sanden compressor?
Old June 18th, 2018, 11:56 AM   #194
smittySS
Thanks for the quick reply!
I procured a High Mount A/C bracket from a Heavy Truck Recycler in the area. It came off an early 90's F700. It didn't have A/C, it had an idler bolted in the compressor's place.
I bought the compressor that says it fits 94-05 Ram with a Cummins, and to go with it I bought the Manifold line that says it fits the 95-97 Ram with a Cummins.
The compressor has the manifold port on the rear of the pump, very close to the oil filter, so there isn't enough room to flip it around and try to make it fit.
I'm not afraid to fabricate, but my first choice is a part of the shelf with little modification... in case something needs fixed/replaced down the road (or on the road).
I'm still not sure what application your compressor is for, but I did find that the C7 CAT compressor from a GMC 7500 has the manifold ports facing the same direction as yours. This may work for me, looks like the 7.4 lines may actually bolt to it, with a little bending and rearranging... it just might work!
Perhaps when I get some more loose ends tied up, I post on here what I've been able to do, and how I did it.
In the mean time, I've been chronicling it on the GMT400 forum. http://www.gmt400.com/threads/1997-k...version.40952/
Thanks again for the info!
Smitty
Old June 18th, 2018, 12:27 PM   #195
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Old June 18th, 2018, 12:40 PM   #196
smittySS
I see you changed your Alt. mounting slightly...
Was there a significant reason?
Yes, that compressor you have, has the suction and discharge in the location I'm looking for... I have yet to find which compressor has the screw in lines though.
Smitty
Old June 18th, 2018, 12:45 PM   #197
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
something was different about the 24v head so i had to make a new mount
Old June 18th, 2018, 01:18 PM   #198
greygoose
Gustafson
greygoose's Avatar
Oh I know, 12 more valves?
Old June 18th, 2018, 01:41 PM   #199
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Old October 4th, 2019, 11:05 AM   #200
green50gt
Got rocks?
green50gt's Avatar
Can the folks have an update about this?
I heart Jeeps
green50gt is offline   Reply With Quote
Similar Threads
cummins swap, need help, free beer! camccardell Meets, Greets, and Wrenching 0 July 9th, 2011 12:35 AM
5.9 cummins swap farm_boy General Tech 13 October 16th, 2009 11:31 AM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 1.36810 seconds with 87 queries
