Manifold back exhaust question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2019, 03:04 PM   #1
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Default Manifold back exhaust question
After looking further into my truck its leaking at the driver side frt cat, and the passenger side frt cat is making a rattling noise inside
So Since I'm super cheap but want to to everything right, what is the best but cheapest way to replace the exhaust from the manifolds back?
Can I use just one universal cat on each side and have a o2 sensor in frt and behind the cat So a total of 2 universal cats and 4 o2 sensors, and then one muffler?
Or should I do as above but go with dual exhaust and have 2 mufflers?
The truck runs great, looks good just has 207,000 miles and rust on the bed. Purrs like a kitten and I dont want to go buy something else and then have to worry about the what ifs, I already know this truck
My wife is about to make me sleep in the garage as I am driving her crazy about this LOL
Fyi Its a 99 f-150 4x4 with the 5.4
mideerslayer is offline   Reply With Quote
Old February 24th, 2019, 07:56 AM   #2
cerial
Direct Drive FTW
cerial's Avatar
With the truck cold run a bungee around the rattling cat then fire the thing up for a few minutes to see if the rattling is gone or is diminished to see if the rattling is just a heat shield. If it is diminished or gone you can just get a 10 or 12" "duct" clamp(at home depot, etc) and tighten the heat shield down after using a piece of wire to determine the size you will need.
If it is not the heat shield something is inside the cat and you will need to replace it.
As far as the leaking cat use some muffler tape.
Watch this;
Let's fight to replace the 1953 oil pipelines from under the Mackinaw bridge before they rupture.
Old February 25th, 2019, 07:03 PM   #3
not sure
no wait! my name is joe
not sure's Avatar
Buy direct fit front pipes and converters. Do it right. Back half is easy to make or take it to a shop and have the back part made.
If the converter is bad and rattling something has caused that. They don't fail on their own. They don't wear out. Just know that if there is an issue it may hurt the new converter. Oh and replace all the oxygen sensors. O2 sensors do degrade over time. Optimal life is @100k
Sent from my LM-Q610(FGN) using Tapatalk
not sure is offline   Reply With Quote
Similar Threads
Anyone swapped a 5.8L exhaust manifold with a newer one to eliminate heat riser? speedfreakracing Ford Tech 0 May 18th, 2018 05:35 PM
4.0L fuel rail, exhaust manifold, and distributor bbaXJ Wanted 3 November 21st, 2016 09:56 AM
Needed: 4cyl exhaust manifold or header. Alternator mount yjwheeler13 Wanted 1 June 25th, 2015 10:47 AM
ISO stock 98 TJ exhaust manifold back. apdoutry Wanted 0 December 24th, 2014 05:22 AM
4.0 Exhaust Manifold replaced. Engine full throttle now. dochereford General Tech 5 November 23rd, 2014 09:14 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.21892 seconds with 36 queries
