what do you think of mini-spools? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2007, 07:32 AM   #1
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
Default what do you think of mini-spools?
for the rear? I have a rear dana 44 in my cj and am wanting to put in mini-spool. my upgrade budget is kinda tight since there is much that I wanna do, so this would lock my rear for about 60 bucks. I am also going to be getting an aussie locker for my front dana 30 and warn premium lockouts.
it is not a DD by any means, but I do like to drive it to work once in a while. I have known a few people with mini-spools and have gotten mixed feelings from all.
let me know what you think!!
thanks
Justin
gotsand? is offline   Reply With Quote
Old January 23rd, 2007, 08:17 AM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
It's a decent cheap upgrade if your Jeep isn't going to see alot of asphalt. Since you won't be DDing it much, I'd say go for it. You can always upgrade to a locker later if you choose. I'd just take it easy when you do drive it to work taking it around the corners.
Old January 23rd, 2007, 08:23 AM   #3
Icebreaker88
Icebreaker88's Avatar
I ran one for a little while in a 9" rear with no problems, but It does put alot of stress on the center (diff) pin. I think you can get a hardned diff pin to use with it
Icebreaker88 is offline   Reply With Quote
Old January 23rd, 2007, 08:37 AM   #4
gotsand?
gotsand?'s Avatar
thanks guys, I think I will get one.....
Old January 23rd, 2007, 09:34 PM   #5
ron86toy
R&V Ranger
ron86toy's Avatar
Send a message via Yahoo to ron86toy
I run one in the rear(full spool)....just cheaper than a locker and does basically the same thing.Tires bark around corners and its a little hairy when there is snow on the roads....but I only drive around town once in a while.
ron86toy is offline   Reply With Quote
Old January 23rd, 2007, 10:01 PM   #6
I toasted one in a 9" running 35's. Went to a full spool and never had a problem.
Old January 24th, 2007, 01:30 AM   #7
Todd
"HCT"
Todd's Avatar
If you are later planning on gettin a lunch-box locker then put a mini spool in there with a cromo cross pin. If you later want a full carrier locker then just weld up the diff. Way cheaper then a mini spool and stronger if done right.
My 8.8 is welded, love it. And my rig is trail use only.
Todd is offline   Reply With Quote
Old January 24th, 2007, 08:46 AM   #8
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
a mini spool may be cheap now... But I have replaced many a parts for people for exploded carries and ring gears. The factory open carrier isn't strong enough to be abused with the mini spool. Like mentioned it would be better to weld it up.
Similar Threads
Spools F&R On&Off road xj bmx General Tech 1 October 25th, 2009 05:19 PM
gone sold spools of 12 ga wire 1badzuk Completed Sales 4 April 7th, 2009 02:12 PM
spools 101 not sure Axle Tech 9 February 17th, 2009 09:19 PM
Cable Spools Skooter_Built Freebies 3 June 17th, 2008 09:09 AM
Geo -Spools, Lockers, or what? Dirtdug Axle Tech 3 January 16th, 2008 06:37 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.76688 seconds with 50 queries
