F700 build - Page 14 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 2nd, 2015, 08:22 AM   #261
back woods
59 days left to finish this thing.
Ordered a pile of parts to get it running.
New oil pan/starter/alt/water pump
New trans pan/filter kit
Oil-water trans cooler
Oil-air trans cooler
Bunch of other stuff.
Here is the cooler setup. Oil to water cooler and from there into a oil to air cooler.
My cooler is a few inches shorter than this one.
Should keep everything cool running WOT.
Pulled the oil pan and replaced it along with the starter. Motor looks fantastic from the bottom end, no tarnish on the rods/cranks and no sludge in the pan. Definitely makes the 5.9 look dinky.
back woods is offline   Reply With Quote
Old September 2nd, 2015, 08:30 AM   #262
back woods
Using Grace Ice and Water shield for sound deadening. Bought it in a 9" x 75' roll and cut it to fit. Going to do the entire cab in it to cancel out as much road noise as possible. Will still be able to hear that Hx40 singing though.
The original plan was to use the stock pickup column shifter. Ended up being too sloppy for my liking and didnt want any problems down the road with it bumping into gear. My solution...Hurst piston grip shifter. Planning on mounting it on the dog house and using the red button on the top for the electric locker.
Also bit the bullet and bought some gauges. They are ridiculous, $250 was the absolute cheapest setup I could find. Made by Glowshift, got an EGT gauge, Trans temp, and boost gauge.
Working on hooking up steering/brakes/throttle/shifter/wiring right now. Would like to give it a fire in a week or two then lengthen the frame. So far we are on scheduled to have it finished, going to start knocking down some longs days on it.
Old September 2nd, 2015, 08:39 AM   #263
camoII
camoII's Avatar
What is it you do for a living? Just curious I'd never have the time or money for all this work. Nice job, takes a lot of motivation and determination to accomplish this stuff. Awesome.
camoII is offline   Reply With Quote
Old September 2nd, 2015, 09:00 AM   #264
back woods
My Father and I are professional dog trainers, we train bird dogs to hunt and handle their game(grouse and woodcock around here). We also compete on the National Circuit with a string of high power competition dogs. This takes us everywhere, north, south, east, west. My parents have their own rig and this truck is for my wife and boy. It is nothing more than a hardcore work truck, very hardcore. It will have the capabilities to stay off the grid with horse and dogs for over a week before any supplies are needed. Between the two rigs we haul around 600 gallons of water, 50-70 bales of hay, 6-7 horses, and at times close to 50 dogs. This is with 4 adults and my boy, we also carry a huge amount of tools, guns and misc supplies for on the road. Basically if SHTF and you see this coming down the road, make friends, or start running.
Old September 2nd, 2015, 09:02 AM   #265
camoII
camoII's Avatar
Sounds like a good gig. Keep up the good work.
Old September 2nd, 2015, 02:58 PM   #266
back woods
Steering and brakes are pretty close to being finished. Working on the throttle next, thinking about building a wider pedal for the brake also.
Old September 2nd, 2015, 03:14 PM   #267
Woodyjiw
FUCK CANCER!!!
Woodyjiw's Avatar
Sweet, I like this build.
Woodyjiw is offline   Reply With Quote
Old September 2nd, 2015, 04:10 PM   #268
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Win!
Old September 2nd, 2015, 05:17 PM   #269
HVYRTFT
Reed my teef
HVYRTFT's Avatar
I got tools and guns and a dirty truck are you hiring?
Old September 2nd, 2015, 05:28 PM   #270
back woods
Throttle and linkage is done.
Old September 2nd, 2015, 05:40 PM   #271
firehawk
Live Action!
firehawk's Avatar
Cool stuff
Old September 2nd, 2015, 07:02 PM   #272
back woods
Was talking to my Dad earlier and he said "go look in the race car stock, I think there is some big hose line out there." Turns out there was about 20ft of it. Would like to use it as transmission line. It is rated for 300 degrees and 350psi, dimensions are -12 AN with an ID of .688in. Will have to go through all the fittings to see what I've got but is there any reason not to use this line? Looks the exact same as what is currently on it and the fittings are very close in size.
Old September 3rd, 2015, 04:56 PM   #273
back woods
Starting to look like a truck again.
Old September 3rd, 2015, 06:26 PM   #274
firehawk
Live Action!
firehawk's Avatar
I like the idea of the ice and water shield for sound dampening, gotta be cheaper than the real stuff. How well do you think it will work?
Old September 3rd, 2015, 08:03 PM   #275
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Is that the same as tar paper? It's the same stuff but the sound deadening is a little higher quality iirc
The Kernel (46 CJ2a)
Mary Jane
Old September 3rd, 2015, 08:04 PM   #276
back woods
Thinking it will work pretty good. Read about other people using it with good success. It is not tar paper, one side is Vycor rubber and the other is tar, no granulation. Bought a 9" x75' roll for $40 and it will cover almost the entire cab.
Old September 4th, 2015, 08:19 AM   #277
back woods
Sooooo, thinking about what to do with the dash cluster. All the gauges will be aftermarket except the speedo, and will probably have to pick up a fuel gauge. Anyways got to thinking since my gauges wont be around the dash there will be a big void.
I am the first one to say this isnt quite my thing but figured maybe give it a try. My idea is to get a larger GPS unit with a backup camera. Make a bezel for it to mount into the dashboard and wire it for key "on" operation. Electronic shit really isnt my thing but I know that I dont want anything wifi capable and it to be as stand alone as possible.
Found this 7" unit with a back up camera. We buy a lot of Garmin supplies for our bird dogs and they make pretty decent stuff. I know there are some gurus out there that know a lot more than me. What do you think?
http://g.factoryoutletstore.com/deta...l?mms_chref=cj
Old September 24th, 2015, 06:30 PM   #278
back woods
Hate to link this over but I am more of a Pirate4x4 guy.
38 days to finish the truck.
All the pretty pictures are here.
http://www.pirate4x4.com/forum/tow-r...-3-0-a-12.html
Old September 25th, 2015, 08:50 AM   #279
tweak
Are we there yet?
tweak's Avatar
That a nice looking GPS unit, and with the built in backup camera would be a nice option... only issue might have is the length of the backup camera cable? I see they sell an optional one on the webpage, but its only like 6 feet long.
Old September 28th, 2015, 02:33 PM   #280
back woods
New turbo is ready to rip.
Compared to stock.
Similar Threads
*SOLD*1997 Ford F700 Ridin Dirty Completed Sales 5 November 11th, 2011 12:53 PM
1962 Ford F700 Dump Truck 4x4 DD04WJ Ebay / Craigslist / Auction Links 0 January 6th, 2010 12:47 PM
John's YJ ground up build..Stroked, Stretched, Petted, groomed Koz Off Road build JKOZ Rig Builds and Pics 56 September 19th, 2007 11:18 AM
YJ Build, 5.7L hemi, Dana 60's, coil overs, Koz Off Road current build-Yes another YJ JKOZ Rig Builds and Pics 22 April 17th, 2007 09:13 PM
78 Ford F700 RUSTYSPIKE9 Vehicles for sale 10 February 17th, 2007 05:46 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 1.64046 seconds with 86 queries
