Fiona the Samurai - Page 14 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 3rd, 2018, 02:25 PM   #261
Alex456123
Durango-space-division
Alex456123's Avatar
Skid is 10 gauge, shock mounts are 1/8"
#Durangoclan
Alex456123 is offline   Reply With Quote
Old April 3rd, 2018, 10:40 PM   #262
Alex456123
Alex456123's Avatar
Skid plate is pretty much finished
#Durangoclan
Old April 9th, 2018, 12:50 AM   #263
Alex456123
Alex456123's Avatar
I sleeved the frame for the tracker power steering box
Swapped my tires over to some nicer rims
Then notched and plated the frame, and tied in the shackle hanger outriggers.
#Durangoclan
Old April 16th, 2018, 01:52 AM   #264
Alex456123
Alex456123's Avatar
Frame painted and finish welded
Dropped the motor and trans in, with a new clutch and motor mounts.
Then dropped the body on and trimmed for the rear shock tower, and made sure the front clip would clear the new shock mounts. Everything fit close to perfect.
I like the amount of lift I got from the proper suspension geometry. Sits pretty much perfect now.
Flexes pretty good too, I still had more room to stuff but without the full weight in the rear it would just tripod. Lol
#Durangoclan
Old April 16th, 2018, 08:10 AM   #265
greygoose
Gustafson
greygoose's Avatar
Good job!
Old April 16th, 2018, 09:06 AM   #266
looking good!
Old April 16th, 2018, 12:13 PM   #267
Alex456123
Alex456123's Avatar
Thanks guys!
#Durangoclan
Old April 16th, 2018, 12:59 PM   #268
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Looks good.
That engine seems so tall. Maybe it's because it's so narrow. And the motor mounts seem so low on the block, like it if had torque it would tear them up quickly.
Old April 16th, 2018, 03:15 PM   #269
Alex456123
Alex456123's Avatar
That is the factory mounting method, it's a tiny (but tall because of the SOHC 16v head) 1.6l and weighs 160lbs fully dressed. I don't think 99hp is gonna break those mounts
#Durangoclan
Old April 16th, 2018, 03:45 PM   #270
greygoose
Gustafson
greygoose's Avatar
99hp.
Old April 16th, 2018, 05:13 PM   #271
Alex456123
Alex456123's Avatar
you also have to consider that it has a divorced transfer case, so drive line torque in low range isn't going to be tearing on the motor mounts either.
#Durangoclan
Old April 16th, 2018, 10:35 PM   #272
busyfixin
Balls Deep
busyfixin's Avatar
Looking good. There seems to be an optical illusion or a mirror action going on on the skid plate. It looks like there is either a reflection of yourself, or the illusion of a DickButt on the skid! Probably just one of those reflection things, like when someone waxes their car before taking for sale pictures naked, and everybody gets to see their dong.
Old April 16th, 2018, 10:54 PM   #273
Alex456123
Alex456123's Avatar
There is no way I would have welded a dickbutt onto my skid plate, who would do such a thing?
#Durangoclan
Old April 27th, 2018, 01:56 AM   #274
Alex456123
Alex456123's Avatar
I mounted my fuel pump finally
I also fixed the gaping hole that was left in my floor from my stock tank dipshittery
Took this
And turned it into this
Then I plumbed and fitted the fuel cell, still need to get some sort of straps for it
Then I made a power steering pump bracket out of some 3/16 and the stock tracker bracket. Easy enough.
Also mounted the radiator and found a good spot for the power steering resi
This weekend is going to be all about brakes. I have all new stuff to put on, new hard and soft lines, master cylinder, rebuilt geo tracker 4 door calipers, new wheel cylinders and shoes. It pretty much had no brakes before, so I'm gonna make sure it can stop now that it's going to be on the road.
#Durangoclan
Old April 27th, 2018, 10:06 AM   #275
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Looking good.
RIP FULLSIZE4LIFE
Old May 16th, 2018, 12:23 AM   #276
Alex456123
Alex456123's Avatar
I skipped over some stuff.
I cut the flange off a 1.3 header I had laying around and cut out my own flange. Sounded cool with the header till I put the full exhaust on, now its as quiet as stock. Not a bad thing, but the ford e2000 pump is pretty noisy. Got everything together and drove it around the yard. I love the power steering, no more wrenching on the steering wheel. Put in the driveshafts and new spacers, rebuilt the drums, put the dash back in, painted the windshield frame, and some other small bullshit. Getting close to being done.
#Durangoclan
Old May 16th, 2018, 07:16 AM   #277
greygoose
Gustafson
greygoose's Avatar
That's cool that it's running and driving.
Old May 16th, 2018, 08:38 AM   #278
Old May 16th, 2018, 11:34 PM   #279
busyfixin
Balls Deep
busyfixin's Avatar
Did you crank up the jams and sing out "Rollin though the yard in my 32% of a 5.0, with my rag top up so my heads not cold..."
Old May 17th, 2018, 12:48 AM   #280
Alex456123
Alex456123's Avatar
Unfortunately not.
#Durangoclan
Similar Threads
Project Rural Legend - a Second Gen Dodge Four Door Ramcharger Build kkodet Rig Builds and Pics 43 September 26th, 2019 12:22 PM
Go-Fast Inspired Colorado build RDK_YJ88 Rig Builds and Pics 274 March 19th, 2016 10:40 PM
The Ultimate KJ Liberty Build RDK_YJ88 Rig Builds and Pics 12 October 19th, 2014 10:00 PM
Mild build 1990 EFI Samurai with tons of extra parts - SOLD kkodet Completed Sales 19 August 12th, 2014 10:45 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.56219 seconds with 87 queries
