Mall rated sheep build aka "the other gray LJ" - Page 22 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2016, 08:46 AM   #421
Warn makes a standard and a premium. I broke at least 3 premium hubs.
Old January 22nd, 2016, 08:53 AM   #422
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Warm makes two different locking hubs.
http://eastcoastgearsupply.com/i-227...uper-duty.html
Offers a drive flange kit. On the buggy, I have rocksolid flanges.
Yukon is rumored to be offering something soon.
ECGS and Rock Solid use stock outers, right?
Old January 22nd, 2016, 11:50 AM   #423
Stock outer?
Stubs? Yes. The factory stub shaft is 35 spline.
If I recall
Top factory stub from 05+ 60
Middle chromo 35 spline pretty 05
Bottom stock 30 spline pretty 05
Old January 22nd, 2016, 11:53 AM   #424
From the c out the 05+ is big.
Overall 4"s wider from the c out then a 80s kingpin Ford 60 is.
Not 100% sure we're the 2" difference a side is, never took time to figure out. But the wms is close to 72"s. That's why I take 4"s out of the long side to bring it real close the wms of an older 60.
Old January 22nd, 2016, 11:54 AM   #425
I have a few factory lockouts, and one extra drive flange. I don't plan on buying the warns. Never been impressed with warn lockouts.
Old January 22nd, 2016, 12:00 PM   #426
I believe production will pick up on aftermarket parts for these axles.
Super stout, dirt cheap, plentiful.
I've bought 3 complete minus calipers and rotors in the last 6 months and haven't paid over 225 for one yet. And that includes the core charges I've paid on each one.
Old January 22nd, 2016, 01:11 PM   #427
bbaXJ
Yooper In Training
bbaXJ's Avatar
From where? I have no need for one at this point but it could certainly come in handy at a later date.
Old January 22nd, 2016, 01:17 PM   #428
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Agreed, We paid $200, cut the knuckles off, and sold the center chunk for $75.
I've read through most of the pirate4x4 thread, and followed a link to a guy that had his own slugs made, and had someone cut the old style 35 spline shaft to work with his setup so he could get chromo shafts. Trying to figure out if it's worth calling in favors to go that route, or just buy some slugs and wait for someone to come out with chromo outers.
It looks like the inner bearing can be swapped out on the unit bearings, so we could try and find something that would run on the 1.5" 35-spline chromo instead of the stock setup.
Old January 22nd, 2016, 01:27 PM   #429
Yeah inner bearing of bearing is just clipped in.
Old January 22nd, 2016, 06:04 PM   #430
Just about finished mocking rear suspension. Just have sway bar left to figure out.
Old January 24th, 2016, 02:15 PM   #431
Can't decide how to make the mount for the sway bar. It needs to sit 3.5" above the frame to clear the links.
Old January 24th, 2016, 02:32 PM   #432
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
run tube across, simple bracket welded to bottom of bracket to side of frame to space it up.
something like this:
Old January 24th, 2016, 02:40 PM   #433
I have a tube, just haven't decided how to mount it. Image doesn't show.
I was leaning towards mounting it off a triangle shaped boxed piece of channel directly off the top of the frame vs side of the frame.
Old January 24th, 2016, 11:08 PM   #434
bbaXJ
Yooper In Training
bbaXJ's Avatar
Mine has the cross tube mounted with a couple of short tubes coming off the top of the frame. Simple and effective. I ended up not running a rear seat bar but the mount is still there.
Old January 25th, 2016, 05:48 AM   #435
@JohnnyJ your images sucks.
Old January 25th, 2016, 08:30 AM   #436
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Weird, it worked for me on work PC and home PC. maybe this will work?
link to pick
Old January 25th, 2016, 08:44 AM   #437
bbaXJ
Yooper In Training
bbaXJ's Avatar
Nope, didn't work.
So with all the other bling parts going on this why are you sticking with coils rather than coilovers or something? Not knocking it, just curious.
Old January 25th, 2016, 08:53 AM   #438
pic works now.
Old January 25th, 2016, 03:05 PM   #439
LCG HIJKLMNOP
Originally Posted by bbaXJ View Post
Nope, didn't work.
This?
Old January 25th, 2016, 03:39 PM   #440
I ask myself that all the time.
Mostly its $ right now. With a trip to utah and Colorado on the horizon, and needing to get it done by then. As it sits most likely the buggy and jeep are gonna be sharing a pair of struts this summer. Itll work and function with the coils in the back. I chose those shock mounts for the reason if I decide down the road to change it up, I wont have to change that.
I am hoping to have it drivable by april 30th. I may be sporting 3.73s and welded carriers at that time. Hoping to have the 5.38s and arb/zips in it by june.
This is my down time of year at work, so just doing what I can as the extra $ is there to do it.
Similar Threads
The Kernel - 46 2a build - Broke Ground 11/27/15 Lousypirate Rig Builds and Pics 174 March 29th, 2019 02:49 PM
Go-Fast Inspired Colorado build RDK_YJ88 Rig Builds and Pics 274 March 19th, 2016 10:40 PM
Want to see your build sheet? blackbronco92 The Pub 43 February 16th, 2015 09:45 AM
blazer/jimmy sas build 2.2 OL RED Rig Builds and Pics 4 November 28th, 2014 06:00 PM
The Ultimate KJ Liberty Build RDK_YJ88 Rig Builds and Pics 12 October 19th, 2014 10:00 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.54585 seconds with 87 queries
