Go-Fast Inspired Colorado build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 14th, 2015, 03:38 PM   #1
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Default Go-Fast Inspired Colorado build
Finally, not a Jeep build. Time to spice it up with something different.
For a new project I had nothing specific in mind, just a few key things I was looking for:
-Pick up truck
-Full Frame
-Crew Cab or Single Cab (no extended cab)
-Reliable Drive Train
-Good shape/ no rust.
-4 wheel drive
I found a 2004 Chevy Colorado. Single cab, old man cap, high miles, and 2wd. But the price was at the bottom of the budget, and I thought, well that's different. So I went to look at it, and after a test drive I made an offer and drove it home. After some research I find out it has the ZQ8 suspension, which is like the factory lowered edition. Kind of backwards from what I want, but oh well I'll be cutting all that off anyways.
Unfortunately all my pictures were lost when I got a new phone, but here is one I found that is similar.
Picture an old man cap on the back and Boom, you have what I started with.
Original Plan: Pretty basic, 1/2 tons, 35's, etc.
I had the Dana 44 and 9" from my old cherokee, already geared and locked with chromo shafts. Also had a brand new set of 35" KM2's from the jeep. So I started ordering tubing and Heims from RuffStuff. Planning to run a 3 link front with air shocks and SOA in the rear.
JohnnyJ's buddy had a good deal on 2.5x14 Air shocks, so I picked those up.
Order from RuffStuff had come in by now, and I had stripped the whole front end of brackets and was ready to begin. Until I changed my mind....I woke up one morning and decided to make my different project even more unique...
IFS.
Now is where I call it a "Bebe inspired Colorado". If you don't know Bebe's build on Pirate, it's a good read.
http://www.pirate4x4.com/forum/humme...vel-build.html
I mean why not? Stock Chevy Diff and shafts, build some control arms? How hard could it be?
So I sold off the air shocks and 35s started to search for more parts. And, I found this.....
1999 GMC Sierra 2500. Only driven on the weekends by an old lady, never in an accident, complete with Front axles, rear axle, 6.0l, 4l80e, NP261.
Perfect.
9.25 front axle and SF 14 bolt rear. Let the build begin------
Planned Rubber, 37" MTR-Ks
More Sub frame work
On to the lower control arms. Made with 1.75x.25 DOM and a 1.25" Heim on the knuckle. On the frame side I turned out some bushings made from Nylatron, after it was recommended from a racing buddy.
Since I was using a hard bushing, it was imperative that they both stayed on the same plane. So I used a 5/8" solid bar to keep them straight during welding.
Little TIG action
Upper Control Arms. 1.5x.25 DOM tube with 7/8's heims.
Starting to get everything mounted.
It's gonna be wide!
Next up Steering.
Old February 14th, 2015, 03:52 PM   #2
concreteguy82
Yeah Buddy!!
concreteguy82's Avatar
Awesome!!
concreteguy82 is offline   Reply With Quote
Old February 14th, 2015, 03:58 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I like it!
H.o.r.e
Old February 14th, 2015, 03:59 PM   #4
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
For steering I had to do some research. Steering can be difficult with IFS. 1/16" off can lead to noticeable bump steer and poor driving characteristics. Originally I was going to use and OEM type Rack and pinion like Bebe did on her H3. But I ran over an article on Pirate about IFS steering caught an idea that intrigued me.
So I've decided to do a full hydro setup, where the ram ends mount to the frame and the steering mounts to the body of the cylinder. More on this later.
Here is a picture of the suspension with mock up steering.
No on to shock mounts. I picked up a set of 10" travel FOA 2.0 coilovers, set up for dual rate. Currently running PAC racing springs, 750/800.
More TIG
Upper mount
First lower mount, but have since moved it forward and outboard more.
Finally holding its own weight, close to ride height.
While waiting for steering parts, I've started on the rear. Pics to come.
Old February 14th, 2015, 04:07 PM   #5
1 ton tj on 40's
1 ton tj on 40's's Avatar
sweet
Old February 14th, 2015, 04:11 PM   #6
Toyfish
Toyfish's Avatar
wow this thing is sweet!
Old February 14th, 2015, 04:18 PM   #7
oz97tj
Wasn't this attached?
oz97tj's Avatar
Not going to lie. When I read the title I thought for sure this was going to be gay. I was wrong.
Way more in depth build than I anticipated. Very cool.
********GLFWDA.org********
Old February 14th, 2015, 04:24 PM   #8
Tab
Tab's Avatar
Yes. A typical build thread on here is a first post about what the builder wants to make happen then 23 pages of shit talking and nothing actually being built.
Well done.
Old February 14th, 2015, 04:49 PM   #9
kickstand
circling the drain
kickstand's Avatar
I like.
Old February 14th, 2015, 04:51 PM   #10
alexdummy
gas, grass, and ass
alexdummy's Avatar
i like it! subed
alexdummy is offline   Reply With Quote
Old February 14th, 2015, 05:01 PM   #11
fordbronco
the ocean called
fordbronco's Avatar
Awesome! Nice work!
Old February 14th, 2015, 09:24 PM   #12
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Thanks Guys. Hopefully some more updates tomorrow.
Old February 14th, 2015, 10:27 PM   #13
chevotass
chevotass's Avatar
Winner
Old February 14th, 2015, 10:59 PM   #14
t_ank
t_ank's Avatar
Badass!
t_ank is offline   Reply With Quote
Old February 14th, 2015, 11:01 PM   #15
1TFROT
1TFROT's Avatar
pretty cool. can't wait to see the final product
1TFROT is offline   Reply With Quote
Old February 15th, 2015, 06:56 AM   #16
Mr.Green
I can levitate!
Mr.Green's Avatar
I like it. The lower control arms concerns me. Possibly add some additional gussets 90deg to the existing ones and have all gussets connecting thru both the top and bottom plates.
Old February 15th, 2015, 07:40 AM   #17
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
cool build. I read the steering thread on pirate too, In my mind the huge advantage of ifs is the increased steering accuracy with a rack, seems like you would loose that advantage if you go full hydro. So is it dimensionally the same as a full size chevy front end? how much travel?
sbcrichie is offline   Reply With Quote
Old February 15th, 2015, 08:04 AM   #18
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Nice work. Subscribed.
Old February 15th, 2015, 08:50 AM   #19
ATVLIFESTYLE
ATVLIFESTYLE's Avatar
Very cool build.
My fear with a full hydro steering setup is that you loose the ability for it to want to self center and lose of pressure means no steering. Not a huge concern when you are going slow but more important for go fast. Or am i wrong?
ATVLIFESTYLE is offline   Reply With Quote
Old February 15th, 2015, 09:07 AM   #20
bdd1469
bdd
bdd1469's Avatar
Very cool.
Similar Threads
The Kernel - 46 2a build - Broke Ground 11/27/15 Lousypirate Rig Builds and Pics 174 March 29th, 2019 02:49 PM
Want to see your build sheet? blackbronco92 The Pub 43 February 16th, 2015 09:45 AM
Maeve's 2000 XJ 2-door Sport build (Mira's li'l sister) 1x1_Speed_Craig Rig Builds and Pics 6 January 2nd, 2015 05:58 PM
blazer/jimmy sas build 2.2 OL RED Rig Builds and Pics 4 November 28th, 2014 06:00 PM
The Ultimate KJ Liberty Build RDK_YJ88 Rig Builds and Pics 12 October 19th, 2014 10:00 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.65279 seconds with 86 queries
