Murphy, the B2 build - Page 30 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 13th, 2019, 04:25 PM   #581
roll-bar Bob
roll-bar Bob's Avatar
God, I look pathetic in that pic , cant tell my back was hurting can ya?
Fun is not supposed to be painful
RBB
Old August 15th, 2019, 06:10 AM   #582
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Changing out the aluminum wheels for steel, hopefully I don't have bad luck with the narrow wheel. Glad to dump the aluminum ones, and after getting them apart, they are very light weight, and probably only one aggressive climb from being broken.
Anyone have a good hookup on weld on beadlocks?
Sent from my SM-G955U using Tapatalk
Old August 15th, 2019, 07:22 AM   #583
@Tab used to make them.
Old August 15th, 2019, 08:04 PM   #584
Projectnevrending
Xj 4 Life!
Projectnevrending's Avatar
I ordered my DIY Beadlocks from TMI Customs (Total Metal Innovations). Not a local guy but looks like good quality stuff. Just need to get mine welded on.
Other benefit of the TMI beadlocks is that they don't destroy to inner bead. So if you wanted you could mount your tire like normal.
Projectnevrending is offline   Reply With Quote
Old August 15th, 2019, 08:26 PM   #585
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
What did they run ya shipped?
Old August 15th, 2019, 10:02 PM   #586
Projectnevrending
Xj 4 Life!
I ordered 5 for a 17" wheel, 3/16" thick inner and outer, with bolt hardware and valve stems was $424 shipped
$333.75 for the diy beadlocks and $90.25 for shipping
[IMG][/IMG]
This is what I ordered, took a little over 2 weeks before they shipped
Sent from my Pixel 2 XL using Tapatalk
Old August 22nd, 2019, 07:30 AM   #587
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thanks, that's probably the direction I'll be going.
New to murphy seats installed on the stock slides... Gotta keep them adjustable for my daughter.
Also got the new floor pan installed ish, I had the intention to do it properly, but I didn't feel like rebuilding the whole floor right now, so bolted it in for now. Much better than rust holes.
Then I found the cheapest light bar on Amazon, $31 and installed that above the windshield. Debating on taking the time to gaurd it because I'm sure I'll ruin it asap. Maybe I should order a spare while they are still cheap haha.
Next up is a harness bar and harnesses, oh and a different water pump, current one is leaking pretty good
Old August 22nd, 2019, 07:35 AM   #588
Very nice (borat voice)
Old August 22nd, 2019, 08:46 AM   #589
Keep the battery box. It adds character.
Is this gonna be in Canada soon?
Old August 22nd, 2019, 09:47 AM   #590
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Haha, definitely fits the build
Yes, that's the plan as long as I don't break it too bad labor day weekend.
Old August 22nd, 2019, 09:57 AM   #591
I'll be there next week to watch you, and brag about how you would lose if I raced.
Old August 23rd, 2019, 10:20 AM   #592
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Haha, I'm sure!
It's been so long since I raced, not sure I have the drive anymore... That or I don't want to break it lol
Side note, got a new water pump installed last night, thanks John for the parts, and the new Amazon special winch rope spooled up on what feels like the world's slowest winch.... That'll probably be one of the next upgrades
Another thing I'd like to figure out is the cam sensor code I have and to see if that's what causing a delayed start and backfire. From what I read, the ecu reads cam position from the sensor to determine the firing order on initial start up, which would explain the back fire I get sometimes. But otherwise it runs great and starts fine most of the time.
#makingbuildthreadsgreatagain
Old August 23rd, 2019, 11:05 AM   #593
xj4life
xj4life's Avatar
Old August 23rd, 2019, 11:09 AM   #594
Just updated my build thread because of this.
Old August 23rd, 2019, 11:20 AM   #595
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
My new sig
Old August 23rd, 2019, 11:36 AM   #596
302sploder
302sploder's Avatar
Should probably get it on a hat too.
Kyle M. 2020
302sploder is offline   Reply With Quote
Old August 23rd, 2019, 12:49 PM   #597
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Kyle M. 2020
Haha
Old August 25th, 2019, 01:35 PM   #598
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Added a harness bar into the cab, it's a little low, but it fit around the windows and seats good. I welded a couple 2 bolt flanges to to interior sheet metal, then bolted the flanges down using big washers, then hole sawed through the interior sheet metal and ran a bar across, leaving it sunk into the cab, then welded it to the flanges. This way it's bolted, welded and a mechanically locked into position, should be good enough for a trail rig.
I also cut the gates out of my shifter. With the gates in, it's a pain to go from first to reverse. Did this on my ranger and I liked it better
Still need to mess with the cam code, I was told to run a relearn on the sensor, just haven't gotten around to it.
Old September 2nd, 2019, 10:12 AM   #599
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Went racing at rocks and valleys, and I couldn't help myself and I gave it a beating. It did good until I took a bad bounce and got stuck feet from the finish line. Had to get pulled back then took another run at it and broke my driver's side front axle shaft. I would have tried to finish in 3 wheel drive, but I lost all brakes at the same time and decided to take a penalty and let Jamie finish. Turns out the master cylinder came unhooked from the brake pedal, easy fix.
New shaft is ordered, gonna do new balljoints at the same time.
Old September 2nd, 2019, 10:33 AM   #600
It was a good show.
Similar Threads
eddie murphy first black president archerchaos Politics, Government, or Religion Chat 0 July 25th, 2011 08:03 PM
Brittany Murphy Dead? Ridin Dirty The Pub 30 December 21st, 2009 12:48 AM
Charlie Murphy is the coolest. Pokerob The Pub 0 June 30th, 2009 11:51 AM
Shamus and Murphy GreaseMonkey The Pub 11 June 13th, 2006 10:22 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.56137 seconds with 87 queries
