"Dirthead 509" TJ Project - Page 51 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2019, 09:52 AM   #1001
LCG HIJKLMNOP
New fuel pump in, new filter/reg, new problem. Replaced #7 injector and got that cylinder back working but still have an issue on passenger side. Going to pull the whole rail, look at the injector inlet screens, and purge rail. Not finding anything in the lines but something isn't adding up. I might replace all 4 coils with spares on that side while I'm there just to see if the problem goes away. Starts up, runs fine for about 10 minutes then goes lean without dropping a cylinder. Very odd and annoying.
Added a check valve to the fuel cell vent to see if that's how I'm getting dirt in the fuel cell. Also bought a vented catch can for the D300 so I don't have to deal with 90W smell in the cab. Little things. 1 month to go, need to start getting serious about it being ready.
Old August 16th, 2019, 10:21 AM   #1002
Ryanw10
Ryanw10's Avatar
Bad o2 sensor? Could be running open loop for the first 10 minutes and then when it goes to closed loop and the o2 sensors start reading you get the lean condition. I'm not sure where your located but I have a brand new Bosch o2 sensor in holland you can try and see if it's your problem.
Ryanw10 is offline   Reply With Quote
Old August 16th, 2019, 11:45 AM   #1003
I think he already put a o2 in it.
Old August 16th, 2019, 12:42 PM   #1004
I think he should wait to work on it till he gets to Canada.
Old August 16th, 2019, 01:25 PM   #1005
LCG HIJKLMNOP
STFT and LTFT drop out and it goes to open loop but I can't find the trigger. O2's still have reading voltage and will switch if I step on the throttle. Here is the lead up where you can see the wideband (only reading pass side bank) go from steady to shaky and start leaning out.
That goes to this where it's kicked to open loop but I can't find the cause of the kick from CL to OL. I've replaced the B1S1 o2 sensor already. I shut each cylinder off via injector 1 by 1 at 2000 rpm to see if it's a dead cylinder. That's how I found #7. I did new wire, then coil, then injector on #7 to get that back under way. That bank won't show on the wideband though so I know I still have an issue on the passenger side.
I would like to finish my tuning from last year finished up before I get there this time @whiterhino
Old August 16th, 2019, 02:26 PM   #1006
Ryanw10
Ryanw10's Avatar
I had a closed loop/open loop problem a couple of summers ago that ultimately Lead to a bad o2 sensor. But in my research I found that if your harness is plugged in backwards (passenger side plug in drivers side o2 and vice versa) you will see issues like your having. I also had someone tell me if your pcv valve is stuck you will have issues like that.
Old August 16th, 2019, 04:36 PM   #1007
No point in rushing things.
Old August 19th, 2019, 10:23 AM   #1008
LCG HIJKLMNOP
Finally able to correlate a P0200 code to when the vehicle flipped open loop. This all tied back to the fuel injector adapters having one wire pulled almost out so as it warmed up the connection was intermittent. Cut and spliced all the adapters into the harness so that connection is eliminated. Running fine now. On to the trans cooler relocation, vented catch can for the transfercase, finish building the spare front driveshaft, finish tuning, then get to the original list I made when I got back from Loonie last October......... 4 weeks.
Old August 19th, 2019, 11:17 AM   #1009
Glad you figured it out. As of right now my list consists of swapping tires.
Old August 19th, 2019, 01:10 PM   #1010
LCG HIJKLMNOP
You need to wheel with more enthusiasm
Old August 19th, 2019, 02:08 PM   #1011
Ouch that hurts.
I'd like to think that my rig is pretty much complete other than regular maintenance ~ which I do regularly. I tend not to wait 11.5 months to fix a known problem.
Old August 19th, 2019, 08:07 PM   #1012
LCG HIJKLMNOP
Ouch that hurts.
To be fair it's only been 10.5 months since it's earlier this year Honestly, I've fixed quite a few things through the year, just never get to the bottom of the to do list on it.
Old August 20th, 2019, 11:27 AM   #1013
LCG HIJKLMNOP
Uninstalled the trans cooler last night and cleaned up the fluid/canada dirt mess that it left in the tub. 30 days......
Old August 20th, 2019, 11:52 AM   #1014
That was quite a mess - as was John. Lol
Old August 20th, 2019, 05:09 PM   #1015
LCG HIJKLMNOP
Shop Vac is almost disposable at this point. It was bad.
Old August 20th, 2019, 07:50 PM   #1016
Old August 26th, 2019, 01:35 PM   #1017
LCG HIJKLMNOP
Put the spare front driveshaft together and welded up my fire extinguisher mount. Finished relocating my transmission cooler. Not much room where it went but it's in there. Went with PTFE line and fittings as the lines run above the exhaust most of the way to the cooler. They are 14" away from the exhaust but if the lines leak it'll be a fire for sure. At least this way if it burns down I can say I tried.
The cooler has 2 loops so I tied the two together like JFR had it and run it as a quad pass cooler. Had one leaking fitting fixed with a new ferrule so hopefully that's all for now on that.
Now I'm back to mashing keys and hoping for the best. Below is what it looks like to run out of gas during WOT testing Lucky for me Beefy has already done this to me so I was able to recognize the problem and "fix it". 75mph is super sketchy on a loose gravel road so I'll finish the 5600-6500 area in 4low in the field or something. No more road 2 high wot runs.
#makingbuildthreadsgreatagain#WOTorNOT#youreoutofg asyouidiot#needsmoarpremium
Old August 26th, 2019, 02:29 PM   #1018
Well at least you will have a fire extinguisher. I'd hate to have to use mine on your pos.
Old August 26th, 2019, 03:25 PM   #1019
LCG HIJKLMNOP
I've always had one, just not in a fancy mount. I'd still appreciate you using yours on my POS if it comes time.............I'll return the favor should you ever get aggressive enough driving to generate heat.
Old August 26th, 2019, 10:18 PM   #1020
Now that really hurt.
Similar Threads
project "almost as cool as stan's yj" yj UPDATE 1 ton tj now page 2 *DONE* tom77cj5 Rig Builds and Pics 84 June 11th, 2010 02:14 PM
Project "Spartan" 1977 K5 Blazer "Drove it yesterday and new pics" Hoss Blazer Rig Builds and Pics 35 June 16th, 2009 10:01 AM
"""SOLD""" New Extreme Duty Rocker Guards $150.00 fits TJ & YJ """SOLD""" Nerv Completed Sales 10 June 11th, 2009 04:40 PM
03 Jeep "Project Rubi" 37's beadlocks and stuff ... SOLD TJ-RUBI Completed Sales 61 November 6th, 2008 07:47 PM
SOLD - 1968 CJ-5 $800 Good "starter" project. PavementPounder Completed Sales 21 November 20th, 2007 12:39 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.54907 seconds with 87 queries
