1999 Nissan Altima SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicles for sale
Old September 4th, 2016, 07:01 PM   #1
cerial
Direct Drive FTW
cerial's Avatar
Default 1999 Nissan Altima SOLD
1999 Nissan Altima
SOLD
2.4 5 speed stick
184k
Took it on trade.
Runs, drives, shifts good, stops, sunroof, heat,
Crack in windshield, small exhaust leak, rear running lights on a switch, rockers gone, interior worn, no radio.
Fast little car that is good on gas.
Open to trades.
I need junk for this 96, 1500, 5.7, 2wd nv3500. Selectable rear any ratio, full aftermarket exhaust, 350+ carb or stand alone engines that will work with gm nv3500.
Other thing would be a good condition 271(manual select) drivers drop converted to a divorced setup.
The car needs a wash and a good scrubbing then I will take some pictures.
Last edited by cerial; March 2nd, 2017 at 06:59 AM. Reason: Clutch gone see below.
cerial is offline   Reply With Quote
Old September 5th, 2016, 01:47 PM   #2
cerial
Direct Drive FTW
cerial's Avatar
The old battery was tested and junk. I threw a newish (10/15) battery in it and $10 bucks in gas. It is on craigslist link below. Good driver. I want it gone.
http://grandrapids.craigslist.org/cto/5767207244.html
Old September 8th, 2016, 01:49 PM   #3
cerial
Direct Drive FTW
cerial's Avatar
Back in town. I want this gone.
Old September 10th, 2016, 12:18 PM   #4
cerial
Direct Drive FTW
cerial's Avatar
Went to the state office and got a fast title today it is a 1999 not 97 as I had before. No idea why I had 97.
Clean title in my name car is ready to drive home.
Made a new Craigslist add with more pictures;
http://grandrapids.craigslist.org/cto/5775483630.html
Old September 11th, 2016, 11:22 AM   #5
cerial
Direct Drive FTW
cerial's Avatar
Looking to put a carb or stand alone big block in this chevy 1500.
Good running engines. Not concerned with mileage.
Chevy 454 With different heads or 468
Bop 455
Cadillac 472 or 500
Bring it over. Lets give It some fuel and spark and shake on it.
What you got I want this car gone.
Old September 15th, 2016, 09:32 PM   #6
cerial
Direct Drive FTW
cerial's Avatar
Bump.
Open to offers.
Old September 16th, 2016, 02:12 PM   #7
cerial
Direct Drive FTW
cerial's Avatar
Fast fun car. Thing sits low and just goes. Good amount of low end torque considering dosplacment. Nice shifting car that could take you and 3 others to silver lake, the mounds, the badlands, and chicago on less then a tank.
Trade for a junkyard gantry crane(with car tires). Needs to be able to lift 1500lbs.
What you got?
Old September 17th, 2016, 01:09 PM   #8
cerial
Direct Drive FTW
cerial's Avatar
Want it gone.
Price dropped 200.
Now $700
New Craigslist ad.
Old September 18th, 2016, 08:30 AM   #9
cerial
Direct Drive FTW
cerial's Avatar
Thing has not been started in 12 days. Just went out and drove it around the yard. No shorts or draws or smoke. It started right up. Tires all hold air great, thing shifts strong.
Working on the jeep, chevy, and cadilliac all day today. Come on out and take this thing for a drive.
Old September 19th, 2016, 10:16 AM   #10
cerial
Direct Drive FTW
cerial's Avatar
I need 4 jeep 4.0 short blocks. Stock stroke.
Oil pan to head gasket. Good rotating condition. Good crank and cam bearings. Good oil pump. I need the damper, timing cover, and flywheel or flex plate.
I do not care about cam lobe wear or if the lifters ticked. But cam and crank bearings as well as cylinder walls need to be good. I cant stress that enough. I need good rotating assemblies to start with.
I need these blocks for a winter project and would like to get rid of this car in the process.
Bring out 4 good ones from the pile and lets make a deal.
Old September 23rd, 2016, 02:05 PM   #11
cerial
Direct Drive FTW
cerial's Avatar
Working on toys tonight and most of the weekend.
Want it gone
Trades? Cash. Hell, if you have a mill/metal lathe. I have two pieces that I need one milled down to fit into another with a keyway
Tight tolerance balanced assembly
Old September 24th, 2016, 07:56 AM   #12
cerial
Direct Drive FTW
cerial's Avatar
Started the car up after having it sitting for 3 days and drive it out by the road. Tried out the rear defrost on the dew covered back window. It works. Less scrapping for the new owner.
Old September 30th, 2016, 03:54 PM   #13
cerial
Direct Drive FTW
cerial's Avatar
Bump
Old October 9th, 2016, 07:35 PM   #14
cerial
Direct Drive FTW
cerial's Avatar
Took it out this afternoon and had some fun.
Old October 9th, 2016, 08:33 PM   #15
SS
Bananarama!
SS's Avatar
That thing actually scoots. Kinda surprised lol
-Jer
SS is offline   Reply With Quote
Old October 29th, 2016, 06:04 PM   #16
cerial
Direct Drive FTW
cerial's Avatar
Last 20 days.
$250 4 new AT tires from Walmart.
$300 Front Rotors and pads done at muffler man as preventive maintenance
$400 New EGR Vacuum Solenoid(code), EGR Valve, EGR Vacuum Modulator/controller, New cap, rotor, spark plugs. All quality OE or equivalent parts.
I de greased the entire engine bay and got some breast cancer wipers when I had a oil change done at Valvoline. I also fixed a few things such as a shiftier that rattled and hood latch that was a bit loose.
Windshield is still cracked and I don't see replacing it unless the crack spreads or I get leaks. Still no radio in the car at this point.
Driving this for the winter.
It will be for sale in March for $1400.
I will be in and out of Michigan through out the winter ans working on the jeep when it is not freezing outside when in town. If not that then I will be getting parts around for the C1500 Cadillac 500 swap in the spring between all the holiday family stuff.
But, if someone is serious with cash in hand I may sell this before March.
Old November 26th, 2016, 06:59 PM   #17
cerial
Direct Drive FTW
cerial's Avatar
Burnt up the clutch. Its like gone gone. Had to rev to 4k just to move the car this morning. It is parked.
I don't have a shop. I don't care enough to keep the car.
All the tires might have 3k on them less then 5 for sure. The drivers front is sure to have a good amount of tread missing at this point. I got into the habit of pulling it a foot or two to the right at least once a day off a light.
Engine is still strong and transmission shifts smooth, lots of good parts.
Looking for $300 cash. It can drive up onto your trailer.
Open to trades for any one thing below. Junk I could use currently;
13+ gallon fuel cell with 90ohm fuel sending unit.
96 c1500 good body short bed
96 c1500 good body standard cab.(Really need now Good floors and rockers. I am going to strip it and need a good base to start from)
96 c1500 fiberglass tilt front end or fiberglass fenders/stock looking hood
Drivers and passenger seats from a Yukon(seat belt in seat) with full control and butt heat
Aftermarket gauge cluster set(matching) that includes tach, gps compatible speedo, oil, temp, amp, and 90ohm fuel.
Mojave heater
454 full length headers for 96 2wd c1500 truck
Looking for 63 to 65" wms to wms below in a 5x5 bolt pattern.
SRW 12 or 14 bolt axle with 3.42 gearing
SRW 10 bolt with selectable locker with 3.42 or 3.73 gearing
SRW 10 or 12 bolt with upgrades that will handle 500lbs motor and a sm465 in 1st torque. Needs to be 3.42 or 3.73 gearing.
Engines;
Olds inline 8 engine(turns over)
Diesel 2 stroke 671 engine(turns over)
GMC 702 engine(turns over)
Cadillac 4.9 engine (with good short block)
Cadillac 500 or 472 engine(turns over)
Buick 350(Hei preferred)(need complete engine as starting point. It will have the dizzy up front & aluminum timing cover)(turns over)
Honda f22c1 from 2004-2009 s2000.(I will take entire salvaged car if engine/transmission are run-able)Might throw cash at you here for something I can drag onto a trailer.
Stanley 2 cylinder double acting steam engine(for restoration)
Jeep 4.0 (must be stock bore. HO or non does not matter. I do not need anything above the head gasket)(turns over)
Transmissions;
Rebuilt 2wd sm465
Any 3 speed brownie/watson transmission with overdrive(found in 60's chevy trucks)
Ranger overdrive meant to work with sm465
Switch pitch RWD TH400(with converter)
Switch pitch TH425(fwd)(with converter)
271 or 273 transfer case any drop.
Complete car shells to build upon;
Good Geo metro shell
Good classic VW bug shell
Good Geo/chevy prism shell
Good classic 60-70's mini cooper shell
Good classic MG/MGB shell
Good 85-87 Honda HF crx shell
Good 92-95 Honda VX hatch shell
Open to other trades also. What you got? I want this car gone.
No guns, bows, or hunting stuff.
PM me.
Thanks for looking.
Old November 27th, 2016, 02:13 PM   #18
cerial
Direct Drive FTW
cerial's Avatar
$300
Pepboys quoted me just under $700 to install a new clutch and flywheel(worst case).
This engine is fun to work on.
Watch poor eric as he tries to pull the intake gasket without pulling the engine
He manages to do it. But at one point he is turning two screw drivers to loosen a bolt.
If I end up doing the clutch the engine is getting pulled and new intake/exhaust gaskets are getting done.
This engine 2.4 was used in mid-late 90's Nissan trucks and will bolt up directly to the RWD transmission used in those trucks.
It makes 150hp and the same torque while being able to rev to 6500 and loves doing it.
Open to offers. If I pull this engine to do the clutch good chance I'm cutting the car in half and building something rear engine.
My impulsive butt does not need another project to dump $3k into. I have one that needs 2k thrown at it in the spring and another that needs 3.5k thrown at it in the summer.
Old December 15th, 2016, 05:42 AM   #19
cerial
Direct Drive FTW
cerial's Avatar
Bump.
Did a bit of playing in the snow with the thing.
Clutch smell was strong when I finally stopped. Going to need a trailer at this point.
Sno-drift is up in Atlanta,MI the end of January.
http://www.sno-drift.org/
Here are the rules
http://www.rally-america.com/rules
Basically it could be a B class-- 2wd, NA, with mostly stock parts.
Check.
You need license, insurance, cage, and a few other things to be safe.
Consult the rules
Then you can go road racing in the snow.
Cheap car as a starting point to get a taste of sno-drift racing.
Old February 25th, 2017, 09:36 AM   #20
cerial
Direct Drive FTW
cerial's Avatar
The car can sit for 8-10 weeks and fire right up apparently. Rental place 10ish miles north of where the car is in Caledonia that has trailer rentals if you have a truck and no trailer.
Clutch is gone car needs to rev something fierce to move. Good for parts or fix it.
Springs here and it is just kind of in the way.
To many projects right now and no time for this.
1997 Jeep TJ Streetable Trail Rig on 37's wakeboard76 Vehicles for sale 3 February 13th, 2016 01:09 PM
SOLD 1997 Jeep Wrangler TJ SOLD BUTLER Completed Sales 4 November 22nd, 2015 08:53 PM
1997 Jeep TJ 4.0L stick, hard top Tj02 Vehicles for sale 2 October 31st, 2015 06:58 AM
Nissan Trail, Beater- $800 OHIO Bwdeaton Vehicles for sale 2 October 12th, 2015 09:43 AM
1997 Polaris XLT 600 Hunter9 Vehicles for sale 7 November 19th, 2014 12:06 PM
Page generated in 4.02958 seconds with 88 queries
