Help with Transfer Case - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2014, 09:30 AM   #1
Cable810
Send a message via Skype™ to Cable810
Default Help with Transfer Case
Well I'm SAS my rig and I'm trying to figure out what year and Model Truck Transfer Case I need. I'm not all that familiar with transfer cases.
I know that I need a 231c Fixed Output, 27 spline Input, 5 bolt. What year and truck does this come out of? I called some junkyards and they said to come and look at it to see if it'll work. Well I'm not about to drive 2 hours just to look at a Transfer Case to have a 50 50 shot it'll work...
Cable810 is offline   Reply With Quote
Old December 18th, 2014, 09:49 AM   #2
jbsjunk
Little Member
jbsjunk's Avatar
S-10 4.3L is dandy. Have one in my XJ with a small block. A SYE kit will be the same if it says Jeep. 231 is the main part. It works fine. Been 2 years with zero problems.
Old December 18th, 2014, 09:49 AM   #3
Heepcreep77
I know my 91 s10 has the fixed front output and slip yoke rear
Heepcreep77 is offline   Reply With Quote
Old December 18th, 2014, 09:59 AM   #4
Cable810
Is it the 27 spline input?
Old December 18th, 2014, 10:00 AM   #5
Cable810
I know lots of people run the 231c with zero issues. That is not my concern.
Old December 18th, 2014, 10:04 AM   #6
jbsjunk
Little Member
jbsjunk's Avatar
Seems the most common. Mine is 27 spline.
Old December 18th, 2014, 10:46 AM   #7
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
From JB Conversions wedsite:
BACKGROUND:
"The model NP231 transfer case is a compact, chain-driven transfer case manufactured by New Venture Gear (New Process Gear) in Syracuse, New York. Since the early 80's, the model 231 has been used in many vehicles and is designated as follows: NP231C = GM S-10, S-15 trucks & Blazers 1983 - 1991, NP231D = Dodge midsize and fullsize trucks, NP231J = Jeep YJ's, TJ's, and some XJ's. This transfer case was first introduced in Jeep Wranglers in 1988 after replacing a 1-year run of NP207 transfer cases.
All "J" models of the NP231 are not created the same. There are internal differences among different year models and this kit has been designed to be compatible with each version. Our fixed yoke kit has been installed in hundreds of V8 equipped Wranglers (small block and big block) to date without a single shaft failure. Because of this success, the new output shaft carries a lifetime replacement warranty. "
Spline count is not mentioned but 27 is standard for auto's and manuals alike. I took my '91 231c off the back of an S10 manual and put it on a '85 700r4 K case without issues, just needed the appropriate adapter. And if you need a SYE JB conversions is the best one made.
Old December 18th, 2014, 09:19 PM   #8
Cable810
Okay makes more sense now. Its just bolting up to a Chevy Trailblazer 4l60E
Old December 18th, 2014, 09:29 PM   #9
Jayden1
Jayden1's Avatar
Yeah, My 91 S15 Jimmy came with a 231. Like BigBlockBlazer said, they came on "GM S-10, S-15 trucks & Blazers 1983 - 1991." And 27 is common on all of them.
Jayden1 is offline   Reply With Quote
Old December 19th, 2014, 01:31 PM   #10
Heepcreep77
Ya mines 27 spline
Old December 19th, 2014, 09:27 PM   #11
Cable810
Now how common is a 5 bolt 221c. From what I understand there is a 6 and 5 bolt!?!
Old December 19th, 2014, 10:03 PM   #12
Jayden1
Jayden1's Avatar
The NP231C's from S10's and variants are 5 bolt, and Jeep NP231J's are 6 bolt.
So, the 5 bolt style would be as common as an S10, S15, or blazer of the correct years. You need 27 spline, 5 bolt. So just find an S10. S15, Blazer, Jimmy, Etc.
I think the NP231J's that bolted up to like the AX15 Or AX5 were lower spline count. Like 21 or 23. I could be wrong.
Old December 20th, 2014, 07:40 AM   #13
Cable810
Makes a lot of sense. The guy that's done a swap on the vehicle I'm about to do said I needed a 5 bolt not a 6. He didn't Say that the 6 bolt comes from jeep.... That's where I was getting lost. I was thinking that there were different types of 231x for the s10 etc
Old December 20th, 2014, 10:22 AM   #14
BigBlockBlazer
Axle breakin' 101
The 231c has no vatiants, it was produced from '88-'91. Unlike the jeep 231 that had 6 or so diff models. The 231c was replaced in '92 by the 233c.
Old December 21st, 2014, 03:11 PM   #15
Cable810
Okay this seriously helps me a ton!!! He said around a 93 or so. That means that it would be a 233c according to the things posted. NP231C = GM S-10, S-15 trucks & Blazers 1983 - 1991
Old December 22nd, 2014, 07:22 AM   #16
BigBlockBlazer
Axle breakin' 101
It's easily verifiable by the tag on the tcase. And the 233c was electric shift where the 231c is lever shifted.
Similar Threads
Automatic 4x4 transmission and transfer case for 92 Chevy Mall Wheeler Parts for sale 1 December 9th, 2014 03:47 PM
01 GMC Yukon Transfer Case AJ Hall Chevy Tech 12 December 8th, 2014 11:05 PM
203 transfer case sandguy356 Parts for sale 0 November 4th, 2014 09:49 AM
BW1356 Transfer Case - Manual Shift - SOLD My91Ranger Completed Sales 24 September 1st, 2014 11:17 AM
Page generated in 0.42930 seconds with 74 queries
