Mall rated sheep build aka "the other gray LJ" - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 15th, 2015, 09:50 AM   #221
Old November 15th, 2015, 05:40 PM   #222
Well after taking the motor in/out 4 times I'm happy with mount location. Burned it in. Had to modify drivers side for steering shaft support.
Old November 15th, 2015, 06:21 PM   #223
firehawk
Live Action!
firehawk's Avatar
What is the criteria for placing an engine? As close to the firewall as possible?
On mine the PO hammered the fire wall a little, might have been for the exhaust manifolds but don't remember. It was down low on the passenger side I think.
And then 5-6 degrees of tilt for the engine/trans and T-case?
Old November 15th, 2015, 06:25 PM   #224
Whatever feels good.
I brought it up to get better ground clearance. It's not as far back as it could be. And I massaged the tub in two spots to clear the bell housing bolts.
Old November 16th, 2015, 08:30 AM   #225
ROXROES
cool story
ROXROES's Avatar
On the TJ I put an aluminum block 5.3/4l60e/231 in we just massaged a pinch seam on the firewall and there was around 1/2" clearance on the backside of the head. You could see the rust sling marks on the bottom of the tub from the balancer on the back of the factory t case and we were right in line with the factory position.
LS' fit like butter in TJ's, we went with hooker block huggers.
ROXROES is offline   Reply With Quote
Old November 16th, 2015, 08:56 AM   #226
I picked up some 2010+ Camaro manifolds. Looks like they will work pretty good.
Old November 16th, 2015, 10:51 AM   #227
I think my manifolds are OEM for my engine.
Old November 21st, 2015, 08:52 AM   #228
I have the truck manifolds, but the Camaro ones give me better options for routing.
Hoping to spend the day working on it. Got just about all I need minus a few pieces and parts.
Also ordered my replacement front axle..... Another 06 Ford 60. $109 + 100 core delivered to my shop .
Pretty much planning to build the same axle for the jeep that I built for the buggy with the exception of the buggy having a grizzly locker where jeep with have an air.
Old November 21st, 2015, 01:56 PM   #229
firehawk
Live Action!
firehawk's Avatar
What is the total cost of the axle when built? That is cheap to start off.
Old November 21st, 2015, 05:54 PM   #230
Depends on what you want to do with it.
Old November 22nd, 2015, 07:35 AM   #231
firehawk
Live Action!
firehawk's Avatar
So true.
Are you going to narrow this one too?
Artec truss and full hydro or hydro assist?
Chromos I'm sure at least
Re gear
Knuckle machining for high steer plus arms
Old November 22nd, 2015, 07:47 AM   #232
Passenger side narrowed 4"-matches wms of 80s Ford 60.
Regear w/air locker
Convert to 8x6.5
Right now same truss setup and full hydraulic like the buggy.
Metro fab high steer
Ballistic diff cover... Only company I've found that makes a cover for the newer 60 that fits correctly.
Probably only chromo will be pass side inner. A Chevy inner shaft fits in perfectly with the narrowed axle. No need for a custom cut and respline.
Loose plans. I need to decide on what I'm doing for suspension before committing to the truss.
Basically same axle as buggy.
Old November 22nd, 2015, 07:58 AM   #233
I'm kinda hoping not to sell my current axles before the Ls is done. I'd like to drive it with the 4.88s and see how it feels. Then I can decide on the new axles.
Old November 22nd, 2015, 09:03 AM   #234
What size tires are you planning to run?
T-case ratio?
I'm at 3.8 & 4.88 with my 40's. Since I only have a 3 speed trans, it's about as low as I can go. It gives me good wheel speed for sand & snow. If I was only running rocks, I would go lower.
Old November 22nd, 2015, 10:05 AM   #235
1TFROT
1TFROT's Avatar
T-case ratio?
and if it helps, the truggy use to have a 3.8 & 4.88s on 37s with the 4.3 and it was a really good combo. by the time I got the 6.0 it had 5.38s (in the 1 tons)
that was with a 4l60e so the OD was nice.
1TFROT is offline   Reply With Quote
Old November 22nd, 2015, 11:05 AM   #236
firehawk
Live Action!
firehawk's Avatar
Are you still running a 4l60e?
Old November 22nd, 2015, 11:59 AM   #237
Current axles are 4.88, 37s now bit feel 40" is in the future, whatever a 231j ratio is. 4L65e for transmission.
Old November 22nd, 2015, 02:16 PM   #238
Old November 22nd, 2015, 02:56 PM   #239
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Very nice! Way too nice to be home brewed.
Old November 23rd, 2015, 02:32 PM   #240
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Awesome work buddy
Similar Threads
The Kernel - 46 2a build - Broke Ground 11/27/15 Lousypirate Rig Builds and Pics 174 March 29th, 2019 01:49 PM
Go-Fast Inspired Colorado build RDK_YJ88 Rig Builds and Pics 274 March 19th, 2016 09:40 PM
Want to see your build sheet? blackbronco92 The Pub 43 February 16th, 2015 08:45 AM
blazer/jimmy sas build 2.2 OL RED Rig Builds and Pics 4 November 28th, 2014 05:00 PM
The Ultimate KJ Liberty Build RDK_YJ88 Rig Builds and Pics 12 October 19th, 2014 09:00 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.65656 seconds with 87 queries
