97 Wrangler TJ 5.3L - Page 19 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 16th, 2016, 11:26 PM   #361
VAhasnoWAVES
Dirty South
the stamped housing of the 9" is nice in the fact that you can easily weld to it... but its also not very thick. id consider a small truss and mounting your link mounts to that before you get too far ahead. but i have to admit that ive never seen anyone mount to the stock housing, so i cant say ive seen it fail either... just food for thought, its something id be weary of.
planning to shave it while your at it?
VAhasnoWAVES is offline   Reply With Quote
Old January 16th, 2016, 11:47 PM   #362
Ryanw10
Ryanw10's Avatar
I got a back bone truss laser cut and it is out at the sheet metal shop right now getting bent in the press brake. As soon as I get that back I will weld it in place and tie the uppers mounts to it
Sent from my SM-G920V using Tapatalk
Ryanw10 is online now   Reply With Quote
Old January 17th, 2016, 05:58 AM   #363
They look too close to the end of the axle. Make sure you have a tire mounted up and flex it out 100% before you burn in the welds. Mine clears when I flex it and my tires still rub the shock when wheeling.
In hindsight they look about the same location as mine.
I can't find a good pic with trail tires on it.
Old January 17th, 2016, 08:06 AM   #364
Ryanw10
Ryanw10's Avatar
My first time welding the driver side it was too close to the end of the axle. Got it right the first time on the passenger side and then fixed the driver side. So far the only clearence issue is the cross member but that is gone now, going to flex it out again today and make sure everything clears
Old January 17th, 2016, 03:32 PM   #365
Ryanw10
Ryanw10's Avatar
Well, after a ton of time after checking clearances, everything fits.
Lower arm clearance
Tub clearance
Tire clearance
Looks like I forgot to take a picture of the frame to air shock clearance but at full droop on one side and full bump on the other side the air shock is about .5" away from the frame.
I ended up with just under 6" of up travel
Old January 17th, 2016, 06:00 PM   #366
bbaXJ
Yooper In Training
bbaXJ's Avatar
I suspect in real world use you're gonna have shock contact with both frame and tires
Old January 17th, 2016, 06:17 PM   #367
Toyfish
Toyfish's Avatar
ill second this only because ive already been down this road. my shocks rub my tires and i ruined a shock shaft this summer when it made contact with my bump stop, it was clear when i flexed it on the hoist but hit during wheeling.
Old January 17th, 2016, 06:17 PM   #368
Ryanw10
Ryanw10's Avatar
The picture is kind of from a funny angle but there is an inch of clearance to the tire. The frame there is about a 1/2" so the only way I see that contacting if my rod ends develop play
Old January 17th, 2016, 08:18 PM   #369
Your tire will rub your shock but that's not a big deal. Mine have always rubbed when wheeling with no negative results.
Old January 18th, 2016, 05:21 AM   #370
Ryanw10
Ryanw10's Avatar
Cool, and if after my first time out I see evidence of the shock hitting the frame I can always just spend an afternoon and notch the frame.
Old January 24th, 2016, 08:29 PM   #371
Ryanw10
Ryanw10's Avatar
Im getting closer...Transmission cooler and lines are hooked up, driveshafts lengthened and my cross member is almost built, just waiting on 2 more laser cuts.
With the new cross member I don't see it at all possibly to fit an exhaust tube on the drivers side. So I'm going to ditch my dual 2.25" set up for a single 2.5"" system that runs all the way out the back.
Other than that I'm waiting on a few more parts and it should be fired up next week sometime!
Old January 30th, 2016, 03:18 PM   #372
Ryanw10
Ryanw10's Avatar
Truss
Radiator mounts
And I came up with a pretty cool way to make dual exhaust still work
Old January 31st, 2016, 06:46 PM   #373
Ryanw10
Ryanw10's Avatar
Test fire was a no go tonight..
Fuel cell is pumping gas but I'm not getting spark. I'll plug a code reader in tomorrow but hopefully I just missed a sensor to plug in
Old January 31st, 2016, 07:21 PM   #374
Ryanw10
Ryanw10's Avatar
Anyone know if it could possibly be the nuetral safety switch? It wasn't an issue before because there was no auto there. Now that the computer sees there is an auto transmission in place it won't let it fire?
Old January 31st, 2016, 07:23 PM   #375
I would think That should prevent crank, not loss of spark.
Old January 31st, 2016, 07:25 PM   #376
Toyfish
Toyfish's Avatar
this but i guess its possible
Old January 31st, 2016, 07:26 PM   #377
Toyfish
Toyfish's Avatar
check crank sensor behind starter
Old January 31st, 2016, 07:30 PM   #378
Ryanw10
Ryanw10's Avatar
Crank sensor is plugged in, camshaft sensor is good. Read something online about a coolant sensor on the side of the block that could cause it. Otherwise I wouldn't be surprised if I missed a ground somewhere
Old January 31st, 2016, 07:36 PM   #379
Toyfish
Toyfish's Avatar
there is a ground on the back of the head which i believe is for the coils
Old January 31st, 2016, 07:37 PM   #380
Ryanw10
Ryanw10's Avatar
Ok, I'll have to check that. I have power at the fuse but didn't check anything after that
Similar Threads
sold - 5 Wrangler 30x9.5 15 Wrangler GSA hase Completed Sales 5 June 25th, 2011 06:51 PM
SOLD:Jeep Wrangler spare tire Goodyear Wrangler RT/S - $25 Big_daddy_75 Completed Sales 0 June 6th, 2010 01:27 PM
1990 wrangler 6 cyl. into 95 wrangler 4 cyl Darkskye19 Jeep Tech 2 March 14th, 2008 09:36 PM
SOLD 4 Stock wrangler rims with Goodyear wrangler GS-A's 30x9.50 15 ryancornell Completed Sales 1 January 28th, 2007 01:59 PM
'80 Wrangler reddeviltj Vehicles for sale 16 November 22nd, 2006 09:27 AM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.56114 seconds with 87 queries
