97 Wrangler TJ 5.3L - Page 72 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 15th, 2019, 07:44 PM   #1421
Agreed, a lot of oem are mounted in a similar orientation.
Old July 15th, 2019, 07:58 PM   #1422
Originally Posted by Plato2k5 View Post
I wouldn't think the trans cooler was the cause of failure. I use to have a remote cooler on the back of my YJ above the rear seats mounted on the cage. Ran it like that for a few years and never had any issues. Probably just due to a worn trans with miles on it.
Did you mess with the transmission calibration at all?? Or is it not computer controlled?
All shift points were moved a touch higher, line pressure is bumped slightly higher than stock. I rebuilt this trans 3ish years ago. Went back to my instructions for the cooler and they clearly stated do not mount it like I did, although my fluid really wasnt burnt when i drained it. Was full throttle second gear when it let go so I'm thinking it was something mechanical like the sprag. Probably time for a 4l80e but with another freshly built 4l60e already in the barn and the limited amount of free time I have the 60 will do for now.
Old July 16th, 2019, 07:57 AM   #1423
BLZR
That's what I tried to do with 4L60E's too... went through 6 of them. Will never touch another in my own vehicles! 80E all the way
BLZR is offline   Reply With Quote
Old July 16th, 2019, 08:52 AM   #1424
Strange, 2nd gear in a 60e then 4 neutrals Mine's due as well. It's when not if
Old July 16th, 2019, 09:28 AM   #1425
Had a buddy send me this after I broke it haha
Old July 16th, 2019, 09:34 AM   #1426
And this one
Old July 16th, 2019, 09:59 AM   #1427
Toyfish
Toyfish's Avatar
Heres another one for you
Sent from my VS988 using Tapatalk
Toyfish is offline   Reply With Quote
Old July 16th, 2019, 10:10 AM   #1428
I'm working on installing a new cooler in my marauder, it's designed to have the inlet/outlet facing the ground. Fwiw.
Old July 29th, 2019, 10:28 PM   #1429
The Jeep has to take over DD duty soon while my truck is at the body shop, so I decided it was time to finally paint some of the bare steel.
Old August 7th, 2019, 10:18 AM   #1430
Looks good Ryan!
Old August 7th, 2019, 10:24 AM   #1431
Originally Posted by sterlingfire View Post
Looks good Ryan!
Thanks!!
Old August 10th, 2019, 10:41 AM   #1432
Been putting some street miles on it and getting used to the full hydro steering. After I got an air bubble worked out it has been tracking nice and straight, still takes a little getting used to though compared to the mechanical set up.
It takes corners extremely well with basically no body roll, and I haven't even installed my anti rock back on yet. Pretty excited about that.
Old August 23rd, 2019, 11:07 AM   #1433
Logged about 150 miles over the course of 8 days while my truck was in the body shop with no issues. Felt good to be driving it a lot. Now time to fix the leaky rear axle and transfercase, and figure out why my driver side axle shaft didnt seal worth a crap on the front 9". My barn floor has been successfully oil stained all over the place
Old August 23rd, 2019, 11:20 AM   #1434
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Oil stains and leaks are the worst
#makingbuildthreadsgreatagain
Old August 23rd, 2019, 11:45 AM   #1435
Yep, and I wasnt smart enough to coat my floor after I had it poured...
Old August 26th, 2019, 10:36 AM   #1436
Meh, they're like scars, reminders that you've lived.
Old August 26th, 2019, 12:39 PM   #1437
Scored a set of 14" fox coilovers to replace my air shocks in the back. Now I need to decide if I back half the frame or just notch it to fit the coilovers.
Old August 27th, 2019, 09:37 AM   #1438
Stared at the jeep for a while last night and this morning trying to figure out what I want to do. Based on the dimensions off my front coilovers I should be able use the current shock hoop, laser cut 4 new tabs for each side, notch the frame and I can make the coilovers fit in place of the air shocks still with 6-7" of up travel. My worry is how much I need to notch the frame to keep the coilover away from the tire. I'm going to pursue this route first, but if something comes up that is going to make it too much work to fit I will back half the frame.
Old August 27th, 2019, 11:36 AM   #1439
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Notch it or French in a new shock tower
Old August 27th, 2019, 11:44 AM   #1440
My shock hoop is already tied nicely into the cage so ideally that stays put and I can notch the frame out to clear the coil. Worst case I could add some wheel spacers to keep the coil away from the tire but I would really like to avoid that.
sold - 5 Wrangler 30x9.5 15 Wrangler GSA hase Completed Sales 5 June 25th, 2011 07:51 PM
SOLD:Jeep Wrangler spare tire Goodyear Wrangler RT/S - $25 Big_daddy_75 Completed Sales 0 June 6th, 2010 02:27 PM
1990 wrangler 6 cyl. into 95 wrangler 4 cyl Darkskye19 Jeep Tech 2 March 14th, 2008 10:36 PM
SOLD 4 Stock wrangler rims with Goodyear wrangler GS-A's 30x9.50 15 ryancornell Completed Sales 1 January 28th, 2007 02:59 PM
'80 Wrangler reddeviltj Vehicles for sale 16 November 22nd, 2006 10:27 AM
Page generated in 0.99312 seconds with 88 queries
