WOD Revolution 4 Seater Build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 10th, 2019, 04:58 PM   #1
B to C
Formerly 89TBIguy
B to C's Avatar
Default WOD Revolution 4 Seater Build
Figured id start a build thread for my current project. I used to be on here as 89TBIguy but after everyone had to recover their accounts a while ago I never bothered. Nobody cares, I know. During my hiatus i bought a house with a shell of a shop that needed literally everything so I had to do a lot of work there first. You can see it progressing in the back ground of some of the pics
Here it is when i first moved in
Ok into the buggy...
Build Specs are as follows:
Gen V l83 out of 14 silverado
th400 RMVB
NWF ecobox/205
front 609 with a TG housing and superduty outers/shafts
rear TG housing with weaver fab bearing cups
Coilovers/bumps TBD
First i picked up a 205 only to open it up and find a lot of water had been in the case, after some rust dissolver this is what the gears looked like. no bueno.
picked up another that was perfect, rebuilt that one with all new bearings and seals. While i was at it cut off the big mounting boss for that support bar they run in factory form to buy some more room under the seat.
Back to together and ready to go. Added a sight tube with some push connect fittings and fuel/oil rated 5/16ths hose (Mc master Carr P/N 51495K219 & 8359K15 if anyone is wondering)
B to C is offline   Reply With Quote
Old January 10th, 2019, 05:10 PM   #2
B to C
Formerly 89TBIguy
B to C's Avatar
Heres the day I brought the motor home. 2014 aluminum 5.3 with 19K miles on it. The two big hangs up with the "new" gen v stuff is the there aren't many options on headers and its looking like i may need a center dump. Im left with running corvette LT4 manifolds with their weird flange if i cant make the factory truck ones work. Other thing is because its direct injection it needs a healthy fuel pump in the tank to supply the DI pump. 72 psi @ 45 GPH to be exact, it needs to be capable of pulse width modulation (unless you want to run a regulator & return line) Hoping i can again use the factory stuff again there too but time will tell.
Old January 10th, 2019, 05:20 PM   #3
Welcome back
Can’t see all the pics.
Old January 10th, 2019, 05:23 PM   #4
B to C
Formerly 89TBIguy
B to C's Avatar
Putting the NWF ecobox together
mounted up to the back of the th400
Old January 10th, 2019, 05:25 PM   #5
B to C
Formerly 89TBIguy
B to C's Avatar
Welcome back
Canít see all the pics.
Thanks! and crap. Thats weird they show up when I preview post. Ill try again
Old January 10th, 2019, 05:57 PM   #6
They are there now.
Nice shop.
Old January 10th, 2019, 06:12 PM   #7
B to C
Formerly 89TBIguy
B to C's Avatar
Awesome. Thank you, Im glad the days of doing dumb things in college apartment parking lots, gravel floor buildings, and outdoor winter wrenching in are behind me
Old January 10th, 2019, 06:32 PM   #8
B to C
Formerly 89TBIguy
B to C's Avatar
Picking up some superduty goodies for me and my friends
This was a fun day. Adam and guys were super cool to deal with. I got crawl around all the sweet buggies they were working on there. We chatted for a good while shook hands and headed back to Michigan.
I even got a cool souvenir to remember the trip
Old January 10th, 2019, 07:03 PM   #9
B to C
Formerly 89TBIguy
B to C's Avatar
For seats I ended up ordering some +2" PRPs. I was only using one seat to mock up with and when i finally pulled the other out of the box it had a cut on the top of the headrest. PRP agreed to recover it for me.
Old January 11th, 2019, 08:28 AM   #10
Bones
Bones's Avatar
nice aerial tow shot! LOL
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 11th, 2019, 08:38 AM   #11
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
This looks interesting...subscribed! Looking forward to the progress.
Old January 11th, 2019, 10:03 AM   #12
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Nice start
Old January 11th, 2019, 05:45 PM   #13
B to C
Formerly 89TBIguy
B to C's Avatar
I ordered one 3rd that ill use for mockup on both front and rear axles. Initially the front and rear will be low pinion, ill package protect for a HP. Im already used to my LP chevy 60 dragging all over gods green earth anyway. Down the road when I can swing it, it'll be a Hi9 or gearworks 10 in the front.
Note to self: if you don't pay for the fancy 3rd member shipping case it will show up wedged in a bucket.
-billet steel pinion support
-yukon nodular housing
-35 spline grizzly locker
-5.43 gears
-Gearset & bearings are REM polished.
Old January 12th, 2019, 10:28 AM   #14
B to C
Formerly 89TBIguy
B to C's Avatar
Also I picked up two of these Spicer Cs from these guys
https://downtofab.com/collections/da...spicer-2023561
They fit the 1550 joints and are ready to accept a 3.5" axle tube. Which was nice in my case because it saved me from having cut the Cs off and then get them machined. Plus now I have a intact SD60 (minus knuckles) tucked away on the shelf for a rainy day.
Also fair warning, if you are opening that link at work, there is a big banner at the top that says DTF lol.
Old January 14th, 2019, 08:45 AM   #15
Bones
Bones's Avatar
new pics dont work
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 14th, 2019, 09:33 AM   #16
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Nice. I was wondering why you paid more for the inner Cs than what most are paying for the axle, but the 3.5" ID vs the stock 3.75" ID is nice. We had to make a shim on for a spidertrax 3.5 axle which worked but was kind of a pain.
I'm guessing they use stock ford 05+ knuckles and unit bearings?
Old January 14th, 2019, 10:11 AM   #17
siettas81
siettas81's Avatar
bad ass man hope to be on tube buggy level someday !!! also i like that k5 in the first pic !!!
siettas81 is offline   Reply With Quote
Old January 14th, 2019, 04:51 PM   #18
B to C
Formerly 89TBIguy
B to C's Avatar
Originally Posted by Bones View Post
new pics dont work
damn, google photos is killing me. Im about to make my own domain to host my pics. i think they are working now
Old January 14th, 2019, 04:53 PM   #19
B to C
Formerly 89TBIguy
B to C's Avatar
Yeah it came down more to a convenience thing, I was worried about having to do just that. And yep they bolt up to the stock knuckles and unit bearings.
Old January 14th, 2019, 05:13 PM   #20
B to C
Formerly 89TBIguy
B to C's Avatar
Appreciate it! Im just going to slowly pick away at it as time as money allows and keep wheeling the k5 in the meantime.
Here's a few of the walrus out and about
They don't expect a thing, I have been accepted as one of them
Similar Threads
Totaled 4runner build Cdyoung1985 Rig Builds and Pics 13 November 28th, 2017 08:46 PM
Project Rural Legend - a Second Gen Dodge Four Door Ramcharger Build kkodet Rig Builds and Pics 39 October 10th, 2017 10:02 PM
1tfrot's M&M Offroad 4 seater build 1TFROT Rig Builds and Pics 1054 February 20th, 2017 11:25 AM
Go-Fast Inspired Colorado build RDK_YJ88 Rig Builds and Pics 274 March 19th, 2016 09:40 PM
The Ultimate KJ Liberty Build RDK_YJ88 Rig Builds and Pics 12 October 19th, 2014 09:00 PM
Page generated in 0.77922 seconds with 86 queries
