Silverado 3 link - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2015, 04:04 PM   #141
sterlingfire
You are wrong...good try at being civil though.
sterlingfire is offline   Reply With Quote
Old January 11th, 2015, 04:07 PM   #142
sterlingfire
Originally Posted by Alex456123 View Post
Got any more flex pics? This thing does seem to perform pretty well.
Not atm. I still have to gear the front to match the rear. It's hard to flex without 4x.
Old January 11th, 2015, 04:11 PM   #143
cmetzg03
FORMER BULLET CATCHER
cmetzg03's Avatar
“In my experience, Marines are gung ho no matter what. They will all fight to the death. Everyone of them just wants to get out there and kill. They are bad-ass, hard-charging mothers-fuckers.”
― Chris Kyle, American Sniper
cmetzg03 is offline   Reply With Quote
Old January 11th, 2015, 05:42 PM   #144
Mr.Green
I can levitate!
Mr.Green's Avatar
Originally Posted by sterlingfire View Post
My home built shackle flip.
Bent
Old January 11th, 2015, 05:44 PM   #145
Mr.Green
I can levitate!
Mr.Green's Avatar
My factory plastic fender wells even fit, they need a small cut where the white lines are.
I fired up the tractor and lifted it up to check flex and check for clearance issues.
Straight
Old January 11th, 2015, 05:46 PM   #146
Mr.Green
I can levitate!
Mr.Green's Avatar
Are these pictures rong? BTW, when was I not civil? Lets forgive and forget bud. Left side tubes have 90 deg bends, right side is straight tubes.
Old January 11th, 2015, 05:56 PM   #147
sterlingfire
There are no bends in the left side tubes, you're seeing it from 2 completely different perspectives in the pics. Btw, this is the first decent thing you've posted in this thread. Thank you for at least looking over the whole build.
Old January 11th, 2015, 06:13 PM   #148
Alex456123
Durango-space-division
Alex456123's Avatar
Those shackle flip brackets are really the only thing I don't like about this build. Other than that it seems pretty well executed. I like SAS projects that sit close to stock height.
#Durangoclan
Alex456123 is offline   Reply With Quote
Old January 11th, 2015, 06:18 PM   #149
sterlingfire
It really is stronger than you think. Did you get to read my post about how they're built before it got deleted?
Old January 11th, 2015, 06:20 PM   #150
sterlingfire
Originally Posted by shawn View Post
such a baller
Nice truck, time to start wheeling it.
Thanks, we have a bit in 2x, but don't want to get into trouble without 4x. I can use it, but there's such a difference in gearing, that even keeping the tires spinning binds the tcase chain and makes it pop.
Old January 11th, 2015, 06:23 PM   #151
kickstand
circling the drain
kickstand's Avatar
practical illusion, the photo appears to have been photomatic'd and only appears to be bent when in fictionality they're not
Old January 11th, 2015, 06:37 PM   #152
sterlingfire
All of these pics were taken with my phone, so some are better than others.
Old January 11th, 2015, 07:54 PM   #153
Mr.Green
I can levitate!
Mr.Green's Avatar
I will say this as cautiously, gently and civil-ly as I possibly can....... I agree with Alex. The shackle mounts look questionable.
Old January 11th, 2015, 08:07 PM   #154
sterlingfire
As questionable as they might look from the pics, I've had more weight on them than I ever had on the stock setup. Still not broke or bent. My only issue with them atm, is my shackle angle. I need to drill new holes 1" back from the holes they're mounted in currently, and that will be fixed. Just have to get it in the garage so I can tie up some loose ends.
Old January 11th, 2015, 08:18 PM   #155
Alex456123
Alex456123's Avatar
just remember, Mr. Green may be a huge asshole (lol), but he is also a suspension engineering genius.
take his suggestions.
#Durangoclan
Old January 11th, 2015, 08:26 PM   #156
Alex456123
Alex456123's Avatar
and here comes another famous alex drawing.
the reason why it will break is because there isnt anything there to limit it from flexing outward.
so in the space i drew the arrows, it needs to be connected to limit outward flex. it isnt the welds or bolts that are necessarily going to break, its the material around the weld that will break. welding on a material makes the surrounding metal weaker and more brittle, so the less abuse that surrounding metal will take without cracking. I suspect the first large impact you have on that rear suspension will break that bracket. its an easy fix, so id fix it before it breaks.
#Durangoclan
Old January 11th, 2015, 08:28 PM   #157
Mr.Green
I can levitate!
Mr.Green's Avatar
From the pics it looks like if you went back any more on the shackle mount it could flip the reverse direction on accident. Maybe you just need a little longer shackle.
Old January 11th, 2015, 09:16 PM   #158
Strangler
Strangler's Avatar
From the pics it looks like if you went back any more on the shackle mount it could flip the reverse direction.
That's why they call it a shackle reversal, dumbass. Gosh.
Old January 11th, 2015, 10:09 PM   #159
jbsjunk
Little Member
jbsjunk's Avatar
I like it.
Old January 12th, 2015, 05:49 AM   #160
sterlingfire
Well,I thought about longer shackles, but that would raise my ride height, and we all know how I feel about this things height by now...I also thought long and hard about building slider boxes, but not sure that will happen either. What I really want to do is hold out for the rear 4 link. I'm not too worried about the hangers atm,I will, and have been keeping a close eye on everything I welded. Been checking for cracks at least once a week since I built it, not just on the shackle hangers, but everywhere I welded. You see, my wife drives this thing with our kids in it once in a while, plus she's 9 months pregnant. To me, that's no joke, their safety is more important than anything.
Similar Threads
trail gear 3 link front kit and 4 link rear kit pearce440 Parts for sale 7 July 3rd, 2013 01:33 PM
silverado for sale or trade CL link posted Dego Ebay / Craigslist / Auction Links 7 August 28th, 2012 01:47 PM
The missing link has been revealed today! The link from us to the animal kingdom clarkstoncracker Politics, Government, or Religion Chat 875 November 10th, 2009 12:33 PM
3 Link (upper link) question....which side? Haggar General Tech 21 January 5th, 2009 11:26 AM
TJ drag link/tie rod link with steering stablizer FREE OR ITS IN THE TRASH prostock3 Freebies 2 July 16th, 2006 10:32 PM
Page generated in 0.49356 seconds with 87 queries
