Newbie to SD60/TJ questions - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Axle Tech
Old December 19th, 2019, 02:40 PM   #21
green50gt
Got rocks?
green50gt's Avatar
John, thanks so much! That is the thread I found! Embarrassingly enough, I didn't notice there was more than one page.
Anywho, so other than the max gear being 4.88, it looks like these will not burst into flames if you leave 12 volt on them?
So I see you yourself have one of these axles in your truck. Would you put one of these under a Jeep? It looks like I will walk away for a couple hundred bucks for one.
Pros:
Big disk brakes
E locker
Cheap
No need to convert front SD to different bolt pattern
Cons:
pretty wide
Only goes to 4.88 gears
Not sure what else. How about it how far it hangs... Does it hang lower than a 14 bolt?
I heart Jeeps
green50gt is offline   Reply With Quote
Old December 19th, 2019, 07:36 PM   #22
Idk about in a jeep. Maybe rich can answer better on that one.
Mine has a tcm bypass on it, so it stays locked over 25 mph. I didn't realize the bypass stays on after ignition is off. Killed both my batteries. Did this twice before I knew what was happening. That was last or year before, still works lol.
Old December 20th, 2019, 07:01 AM   #23
I can vouch for it killing dual batteries
Old December 20th, 2019, 08:13 AM   #24
green50gt
Got rocks?
green50gt's Avatar
Ok, noted. It looks like this axle has considerable* more ground clearance than a 14 bolt. It's at least 35 spline but I see something about 37 spline also so I dont super understand that. (more research to do).
*I am using this term loosely.
@frdtrckmnrich Rich what do you think about using one of these 11' and up Ford 10.5's under a jeep? Have you done one?
I heart Jeeps
Old December 20th, 2019, 09:43 AM   #25
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Send a message via AIM to Jeepaholic Send a message via MSN to Jeepaholic
The 37 spline is the new pinion size ie bigger diameter in the last few years of production which is only available down to 4.88 I believe. Older design goes down to 5.38
99-04 rear is 67-68” wide from research, 05 up is 70-71”
Jeepaholic is offline   Reply With Quote
Old December 20th, 2019, 11:03 AM   #26
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
I see no reason not to if you can make the gear options work. I have not used one of those axles in a build yet.
frdtrckmnrich is offline   Reply With Quote
Old March 13th, 2020, 12:29 PM   #27
green50gt
Got rocks?
green50gt's Avatar
Gents,
I believe that I am a step closer to this somewhat of a midlife crisis build, as I have the LJ on it's way in from Texas as we speak.
So let's get back on topic!!
I have a source that has Super Duty stuff coming out their ears. I had all but decided on the 11' and up rear axle per recommendations here, and the 05 and up SD60. Turns out that 11' and up rear axle is a good bit more, so I am kinda now leaning towards that 99-04 setup.
I can get myself into a set of 99-04's complete end to end for $500. That's in either 4.10 or 4.30. The 4.30 set the rear has a LS. My thought is that I could tool around in some 4.30's and maybe add a lunchbox to the front, while I save up for gears and a good rear locker.
Thoughts?
I really don't want to have to mess with narrowing, and the 99-04 on the bonus needs far less labor to get all the yuck off.
I was hoping to save a buck on the rear and not include a truss, just basic axle brackets but it doesnt seem that artec does that sort of thing - I should check barnes. But then that's a 4 link setup - was kinda thinking factory style. But im staring at a solid $1000 in just bracketry.
Here is a shot of the Jeep.. I havent actually seen it with my own eyes so I am not sure if this is really my keeper or not..
Name:	2020-03-13 13_28_47-Photos.jpg
I heart Jeeps
Old March 13th, 2020, 12:37 PM   #28
green50gt
Got rocks?
green50gt's Avatar
Looks like Undercover Fab has the bracket kit minus truss I was after..
https://undercoverfab.com/tjjk-axle-...asterling.html
I heart Jeeps
Old March 13th, 2020, 10:15 PM   #29
Are you thinking 99-04 front or rear?
Morris rose in Kalamazoo has a 12 rear 4.30 with elocker for $795
Old March 14th, 2020, 08:16 AM   #30
green50gt
Got rocks?
green50gt's Avatar
Both front and rear 99-04. I can get the pair for $500. They have 05 and up fronts for $450. I’ll have to ask about the 11 up rears but they had several of those too - sounds like those might be a bit more pricey.
I heart Jeeps
Old March 16th, 2020, 09:12 AM   #31
green50gt
Got rocks?
green50gt's Avatar
Yall are about to be locked in your houses so there is no excuse for this not being 10 pages of long of good data!!
Said Jeep is here, and thankfully it is 1000.5% rust free. Good builder. Lets talk tons.
I heart Jeeps
Old March 16th, 2020, 09:15 AM   #32
$795 for an axle that's already geared correctly with an elocker in it is not a bad price at all. You'll spend that much putting gears and a lunchbox in one. If you go with the 05+, you can put 1550 shafts in for $350 or so. Food for thought.
Old March 16th, 2020, 10:11 AM   #33
And search car-part. Com for a front. I've found 05+ for as little as $200.
99-04 have weaker bearings & 30 spline outer,
Old March 16th, 2020, 02:16 PM   #34
xj4life
xj4life's Avatar
Any way to upgrade those?
Project Midlife Crisis - Tube Chassis Crawler
xj4life is offline   Reply With Quote
Old March 16th, 2020, 06:17 PM   #35
They make 35 spline stub replacements.
But the 05+ is already 35 spline. And imo the stubs themselves are significantly stronger oem. Plus you can get relatively cheap replacement 1580 jointed shafts for the 05+
First time trailering my jeep - questions Catnip 0_o Tow rigs and trailers 40 August 31st, 2016 12:34 PM
not a newbie.... jeeperjoe65 Introductions 5 July 23rd, 2016 06:23 AM
1940-49 Willy's Jeep Questions Cool Hand Luke Jeep Tech 0 June 17th, 2016 07:34 PM
Figured it out please delete...Ls swap wiring questions GMAN79cj7 Chevy Tech 4 May 11th, 2016 04:47 PM
Fox 2.5" internal bypass shock tuning questions.. Deuling General Tech 7 August 13th, 2015 09:29 PM
Page generated in 0.41312 seconds with 73 queries
