#racetruck New 4600 class build - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2018, 10:47 AM   #41
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Send a message via AIM to RDK_YJ88
I know seats have been a topic thats been beaten to death... But right now we are looking at the Sparco Evo2's. That's what we have in the mega truck and like them. Although we didn't buy those new.
My gut says, buy the nice seats (evo2's), but do we really need a higher end seat for a stock class rig? Not looking at suspension seats at all.
RDK_YJ88 is offline   Reply With Quote
Old March 9th, 2018, 03:23 PM   #42
Alex456123
Durango-space-division
Alex456123's Avatar
I'd say that you would want high end seats in a stock class truck. The suspension will be beating the shit out of you way more than a buggy with long travel, so something comfortable would be nice
#Durangoclan
Alex456123 is offline   Reply With Quote
Old March 9th, 2018, 03:44 PM   #43
I would buy whatever won't break your back.
Old March 9th, 2018, 05:39 PM   #44
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
These are gonna look good. 35x12.50r17 Maxxis Razr M/T. They look alot bigger than the 285/70r17 Falkens on the ZR2, and the pattern is more aggressive than I was anticipating from online pics.
Old March 10th, 2018, 09:26 AM   #45
fabricator
throttle jockey
fabricator's Avatar
Do they not run any races at the badlands anymore?
fabricator is offline   Reply With Quote
Old March 10th, 2018, 06:16 PM   #46
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Doesn’t sound like it.
Old March 10th, 2018, 07:37 PM   #47
TREC folded like 3-4 years ago, and no ultra4 race at Badlands this year.
Sent from my SM-T710 using Tapatalk
Old March 11th, 2018, 12:52 PM   #48
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Getting ready for the frame shop tomorrow.
Old March 13th, 2018, 08:59 AM   #49
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Upgraded the rear drive shaft to thick wall steel to replace the factory aluminum shaft that is super weak. Should have this upgrade and more details on our website today.
1350 Spicer U-joints and yokes
Old March 13th, 2018, 12:02 PM   #50
busyfixin
Balls Deep
busyfixin's Avatar
I can't imagine building anything off road related without suspension seats. That seams not just illogical, but idiotic and irrisponsible if not ignorant.
busyfixin is offline   Reply With Quote
Old March 13th, 2018, 12:06 PM   #51
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Suspension seats can be dangerous in off-road racing. The movement that the seat allows causes your seat belts to loosen up and won't let them hold you in properly. A lot of back injuries with suspension seats.
If you do a google search you can find a lot more info about it. That is just one of the highlights on why not to run them.
Old March 13th, 2018, 12:14 PM   #52
bbaXJ
Yooper In Training
bbaXJ's Avatar
Send a message via AIM to bbaXJ
This. I used to be of the same mindset as busyfixin, but a back injury at Silver Lake(minor injury thankfully) changed my mind. For rock crawling I'll take suspension seats all day, for anything high speed with lots of extended and unpredictable movement and dynamic hits, fixed seats and harnesses are much safer. It's arguable that they're better for big hits rockcrawling too, but there are pros and cons to both.
bbaXJ is offline   Reply With Quote
Old March 13th, 2018, 12:21 PM   #53
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
For reference we run Sparco EvoII composite tub seats in this. They are extremely comfortable even on a jump like this. We will most likely end up with these again.
Old March 14th, 2018, 09:40 AM   #54
busyfixin
Balls Deep
busyfixin's Avatar
I agree that the seat discussion has been beaten to death. To each his own, but I'd be fool not to give my opinion on it as I feel strongly one way. After seeing someone become paralyzed from spinal impact/compaction due to using a solid seat instead of a suspension seat, my opinion became pretty one sided. Reading about numerous others has only reinforced my position.
Sure, your suspension should take most of the hit. But when your chassis takes the hit before the tires or axle hits the ground, it's just you, your back, and the seat that absorbs the hit.
My single seater has a fixed seat in it, a Corbeu FX1. It's a nice seat. It's just not a nice seat for an off road rig. It will be coming out and be replaced with a suspension seat.
Maybe some sort of break away seat bracket could be built with shear pins or something that lets the seat break free into a shock absorber or something. Then a solid seat could be safely used.
Use whatever you feel safest with and you won't second guess your choices later. Unfortunately there is a lot of grey area in everything so we don't really know anything for sure. Some people think stiff boots with high tops are safest for your ankles, others think soft pliable low tops are better. Who knows. All we can do is make choices based on both our own and others experiences.
So, next debatable topic...
2" or 3" lap belts in your harness?
2" are supposed to fit in your pelvic void and tighten up snugger which is suppose to be safer.
3" are wider and suppose to spread the load better.
I find the 3" belts rub me the wrong way and are hard to keep positioned right. I'll be switching to 2" at least on the lap belts.
I think this is some info about this debate. My internet works about as well as stock seats in a race car so I can't get it to load. This *should* be info about the belt width.
https://www.schrothracing.com/technology
Old March 14th, 2018, 09:54 AM   #55
I see the importance of a hard seat but prefer a suspension seat for what I do. I have dropped hard on my frame a couple times (hard enough to bend/dent the frame) and even with a suspension seat it hurts.
I switched to 2" belts for the exact reason above. Soooo much more comfortable.
Old March 14th, 2018, 10:23 AM   #56
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
You're the first person I've come across that has been a proponent of suspension style seats in off-road racing. My statement of not looking into suspension seats at all, was to avoid the conversation of telling me not to run them. I didn't expect this argument
This is an older thread, but was a good discussion with some good tech on why to not run suspension seats.
I haven't even gotten into seat belts yet, but will read over that link. I think I remember seeing in the rules that 3" belts were required, but some high end 2" belts were later allowed. More research to do....
Old March 14th, 2018, 10:40 AM   #57
busyfixin
Balls Deep
busyfixin's Avatar
I'm full of surprises!
Old March 14th, 2018, 10:42 AM   #58
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Ooops, here is the link:
https://www.race-dezert.com/forum/th...n-seats.58050/
Old March 14th, 2018, 12:22 PM   #59
I know @hosejockey4506 switched over following the lead of many of the top tier teams.
For my rec buggy with air shocks I'll stick with my springy seat, but it looks like if you're racing then the suspension seat is no longer the go to.
Old March 14th, 2018, 12:56 PM   #60
suspension for trail wheelers, solid for racers. As long as your belts are properly tightened, you'll stay glued to the seat, basically being one with it, moving with it, and letting the seat take the hit. In a suspension seat, when you compress the seat, the belts become loose, and make compressing your back much easier, and in most cases, make the compression worse.
On another note, @RDK_YJ88 , I was looking at the sparco evoII seats, and saw that the evo line is basically sized according to the series. How tall are you, and how much do you weigh? I'm trying to decide if the evoII will fit me comfortably for my next build. Hoping to get a rig built for the RBOR series and technical wheeling.
Project Rural Legend - a Second Gen Dodge Four Door Ramcharger Build kkodet Rig Builds and Pics 43 September 26th, 2019 11:22 AM
Koh 2018 JohnnyJ Trail Rides & 4x4 Events 133 February 18th, 2018 08:46 PM
Go-Fast Inspired Colorado build RDK_YJ88 Rig Builds and Pics 274 March 19th, 2016 09:40 PM
4800 class ultra4 build 618 Gilbert Brothers Motorsports hosejockey4506 Rig Builds and Pics 13 February 23rd, 2016 08:15 AM
Page generated in 1.22924 seconds with 87 queries
