Chernobyl Cherokee - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2016, 06:37 PM   #201
VAhasnoWAVES
Dirty South
dont have argon this weekend... so i have just been prepping the rear for stiffeners and the rear axle. but i got some parts in the mail today, so i decided to do a little mock up.
i think this is going to work pretty good. the other end of the limit strap is bolted to the lower control arm bolt. right now im at about 10" of travel, split 50/50. ive been looking at getting 7100s to be tunable... i could probably squeeze some more droop with a 14" short body and relocating the axle side shock mount. a 12" short body gets me nothing, as these 11" 5125s have the same extended length. that extra inch of travel would be past full bump. but as it sits the coil just barely unseats at full droop.
VAhasnoWAVES is offline   Reply With Quote
Old March 27th, 2016, 11:26 PM   #202
VAhasnoWAVES
Dirty South
rear stiffeners are all prepped. even prepped the shackle relocation brackets to be permanently welded on as well. alas... no argon. maybe tomorrow, probably not.
also pulled the axle. chopped off the ram skid.
started mocking up the ram in a new spot. i think this is where it is going to have to live. i didnt chop off the old ram mount because im going to have to weld to it.
extended:
shouldnt have a problem interfering with the coil:
collapsed:
clears the diff:
lines end up in a good spot:
axle side mount.... i can get the bolt out with the wheels strait:
now i just need that damn argon...
Old April 15th, 2016, 10:48 PM   #203
VAhasnoWAVES
Dirty South
little update. things have been hectic... we are getting ready to release our project at work for prototyping, and ive had an offer that i put in on a house accepted. but the jeep needs to roll in 45 days (or less).
welded this gizmo out of the scrap from my trackbar... 1.5x.25 DOM.
i didnt want to mess around with making a plate skid... just tacked for now.
been having a fit trying to run the lines for the ram. mounting the ram under the tie rod isnt ideal, ultimately you wan the ports for the ram to be vertical. right now ive got them at about 45 degrees from vertical.i think i need an extra 90 degree fiting to make it work, but im going to have to live with this at the steering gear.
put this in, dodge 2500/3500 master cylinder
got the wheel studs out without messing up the axles
lastly, i needed a little lift... so i splurged on boostwerks comp shackles
(for those unfamiliar with their product: http://www.boostwerksengineering.com...les-_p_24.html)
lastly, ran into this issue
Old April 17th, 2016, 09:57 PM   #204
VAhasnoWAVES
Dirty South
not a whole lot going in this weekend. spent a lot of time cleaning up loose ends, dialing things in, routing lines, cables, and linkages, etc... also, got rid of the factory Tcase linkage. it was never an issue, but hell, while im in there...
whats that cable? oh just this... pretty sure i was a factory option. idk...
main reason i didnt get anything done... was watching the first of the SAE Baja races this for this year. CMU had a really good showing.
Old April 22nd, 2016, 10:08 PM   #205
VAhasnoWAVES
Dirty South
for the first time in 8 years my speedo will be correct.
new springs
shackles at almost 45 degrees. the springs should settle, and the jeep isnt loaded.
it sits level now! i wouldnt have been able to stand it if i spent all this time and money on it, only to throw my old leafs in and have it not sit level. you can also spy the power steering cooler i added.
full bump and full droop
tight, but everything fits. the coil is JUST starting to unseat, and ive got a .75" spacer i am going to put in. brake lines are captured now too.
ordered rear shocks. they will be here tomorrow.
best part is... the lists are getting much shorter. i am almost ready to push it into the driveway for paint/rebuild and reassembly.
Old May 27th, 2016, 11:26 AM   #206
VAhasnoWAVES
Dirty South
been pretty busy and havent updated in a while... long story short...
disregard the rake. it levels out when i throw the bumper, spare tire, and a few tools in the back.
also... reason i have been busy. closed on a new house.
Old June 20th, 2016, 08:50 AM   #207
VAhasnoWAVES
Dirty South
shakedown run happened last Saturday at the mounds. started out slow and worked my way up:
by the end of the day I had worked up the courage (with a little bit of encouragement) to tackle the big rock pile:
jeep went everywhere I pointed it with zero complaints. a couple bugs, but no major failures or issues. beyond happy for the time being.
Old June 30th, 2016, 09:02 PM   #208
VAhasnoWAVES
Dirty South
hmmmm....
Old June 30th, 2016, 09:30 PM   #209
Toyfish
Toyfish's Avatar
Originally Posted by VAhasnoWAVES View Post
hmmmm....
Nice! I got one of those! I love it
Sent from my XT1585 using Tapatalk
Toyfish is offline   Reply With Quote
Old July 14th, 2016, 07:36 PM   #210
VAhasnoWAVES
Dirty South
got the other piece i need...
mmmm... that feeling when your shaft slides right in.
Old July 31st, 2016, 03:52 PM   #211
VAhasnoWAVES
Dirty South
suspension is starting to break in and work nicely.
got a little stuck.
got a little ballsy.
it is time for tube.
Old August 3rd, 2016, 08:01 AM   #212
VAhasnoWAVES
Dirty South
big ugly is a lot tamer than it has been in years past.
Old August 3rd, 2016, 03:52 PM   #213
Cool Hand Luke
Jeep looks like it performs well
Cool Hand Luke is offline   Reply With Quote
Old August 3rd, 2016, 05:45 PM   #214
Wramblerguy
Wramblerguy's Avatar
Looking awesome
And yeah all the big obstacles on big ugly are spread out
I did it all in 3 wheel drive haha
3rd generation jeeper
04 gmc Sierra 2500 crew cab quadrasteer tow pig
87 yj Laredo amc360/ax15/231 amc20/dana30 410s and truetracs
90s Wrambler efi 2.5, t5, built231HD (atlas soon),d44s with 4.88s and detroits
Wramblerguy is offline   Reply With Quote
Old August 4th, 2016, 09:19 AM   #215
VAhasnoWAVES
Dirty South
thanks, beyond happy.
Originally Posted by Wramblerguy View Post
Looking awesome
thanks.
the gate keeper to big ugly has been knocked down and the giant undercut water hole/ledge has been drain. still a fun trail, and easy to dive right into hump trail... which is still just as muddy and stinky as ever.
slab is doable... ron was saying the magic number is 22mph. i really want tube. but im going to enjoy it some more first.
Old August 4th, 2016, 11:22 AM   #216
Toyfish
Toyfish's Avatar
thanks.
22mph is the magic number according to @Mr. Beefy second gear pinned is how my Jeep likes it lol
Old August 4th, 2016, 01:39 PM   #217
Alex456123
Durango-space-division
Alex456123's Avatar
I saw a guy crawl it last time I was there with a jeep on 40" trep stickies
#Durangoclan
Alex456123 is offline   Reply With Quote
Old August 4th, 2016, 02:22 PM   #218
VAhasnoWAVES
Dirty South
haha.
2nd gear and all of the loud peddle felt like it would make it.
Old August 4th, 2016, 03:49 PM   #219
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Yes the wall works well at the rev limiter in 1st with my buggy which is about 22 mph My buggy still has the fastest time up sadly I wasn't driving 7 seconds from the trees to out the top
Mr. Beefy is offline   Reply With Quote
Old August 5th, 2016, 07:26 PM   #220
VAhasnoWAVES
Dirty South
my old slugs were 1980 something factory slugs with a press (dead blow) on cover that did not have a seal. they let a little water in. i addressed that.
also... the more i look at this, the more i like.
Misc Jeep Part(s) jeep service manuals/cherokee/wrangler/grand cherokee/liberty rubicon 1 Parts for sale 4 September 18th, 2009 07:15 PM
98 cherokee 33 long arm Trade for cherokee or grand cherokee bdavid Completed Sales 28 May 26th, 2009 06:57 PM
stalker, shadow of chernobyl steveo The Pub 0 April 13th, 2007 04:29 PM
Greenpeace overestimates chernobyl deaths by 199,950 people. clarkstoncracker Politics, Government, or Religion Chat 2 April 27th, 2006 05:50 PM
Page generated in 0.65613 seconds with 87 queries
