Hyd. Steering Orbital - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > General Tech
Old March 31st, 2016, 02:40 PM   #1
XJay
XJay's Avatar
Default Hyd. Steering Orbital
Looking for some help on an orbital valve selection. I just changed my steer cylinder from 2" to 2-1/2" dia. X 8" stroke, 1-1/8" rod dia., single-ended.
I had a Danfoss orbital on the shelf (part #B 200 ON) that I hooked up and the displacement was about perfect, 3.5 to 4 turns lock-to-lock). Probelm is there's an issue with the valve as it will only turn to the left, and I'm not a nascar driver...
Long stroy short, I found out the displacement on that valve is 12.2 cu.in. (200c.c.) So I'm trying to find a Char-Lynn (Eaton) valve with similar displacement and have not had any luck dealing with parts stores or searching the web.
Thx, Jay.
XJay is offline   Reply With Quote
Old March 31st, 2016, 03:17 PM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Surpluscenter.com usually has a good selection.
BigBlockBlazer is offline   Reply With Quote
Old March 31st, 2016, 03:39 PM   #3
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Last time mine did that I had the tank and right side mixed up.
Mr. Beefy is offline   Reply With Quote
Old April 1st, 2016, 07:42 AM   #4
XJay
XJay's Avatar
Done that before too. That's what I figured was wrong, proceeded to try plugging the lines in every possible combination lol... No workee.
Maybe I'll see if it can be repaired instead of trying to source a new one.
Old April 7th, 2016, 02:38 PM   #5
XJay
XJay's Avatar
Thanks for the head's up, ended up finding the exact one I was looking for on their website;
11.3C.I. displacement Char-Lynn, part #211-1011.
Now to plug it in and try it out...
Old April 8th, 2016, 07:53 AM   #6
XJay
XJay's Avatar
Really scratching my head now! New orbital is doing the same thing, turns left no problem, absofrickenlutely won't turn right. The p-steering pump instantly goes into bypass as soon as you try and motion the steering wheel to the right.
Even tried switching the 2 lines going to the ram at the orbital and it will still only turn left (but steering wheel direction is now backwards).
The only thing I can think of at this point is that the orbital is not letting the return fluid to exit the cylinder when trying to retract the cylinder (turn right). It's just odd that 2 different orbitals would do this...
Or possibly my p-steering isn't suppling enough GPM to properly operate the new orbital? It is a PSC P-pump.
At a loss...
Old April 8th, 2016, 08:19 AM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Is that out on your ram or in? Not that it helps but I'm trying to picture the problem to help
Maybe the orbital is a self centering and isn't liking the single ended ram?
@feva4u
Old April 8th, 2016, 08:38 AM   #8
XJay
XJay's Avatar
Ram is mounted behind the axle so out on the ram, or left turn, works properly. In on the ram, or right turn, no workee...
Steering wheel is hard as a rock and you can hear the pump bypassing as soon as you touch it to the right.
The wheel won't even turn right with the engine off, it'll turn left though.
Also tried cracking the lines at the ram and manually cycled it just to make sure it's working properly. This is the only way I can get the cylinder to retract, but of course it leaks all the fluid out.
Old April 8th, 2016, 08:48 AM   #9
Mr. Beefy
BFT!
Mr. Beefy's Avatar
To my uneducated brain it seems like you either have a line crossed on the orbital or your ram is bad. Can you swap the lines at the ram and make it go the opposite way? If not then your ram has to be the issue in my brain at least.
Old April 8th, 2016, 08:51 AM   #10
Sounds like your ramrod is bent.
Old April 8th, 2016, 08:53 AM   #11
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Put the old ram on for a second and see if it behaves the same?
Old April 8th, 2016, 08:54 AM   #12
XJay
XJay's Avatar
Here's a quick sketch of my system and how it's hooked up. I can't see it being an issue with the ram or a line because it works with the other orbitals I tried. They were all just too slow for the 2-1/2" ram, not enough fluid displacement.
I did try swapping the L & R lines at the orbital, cylinder will still only extend, it just opposed the direction of the steering wheel.
Old April 8th, 2016, 08:56 AM   #13
According to the diagram I got with my orbital from psc, you should have it hooked up right.
Old April 8th, 2016, 09:21 AM   #14
XJay
XJay's Avatar
Ya pretty sure it's hooked up right. Also the orbital is a "non load reactive" type so it's not a "self-centering" vavle.
To me it can only be 1 of 2 things:
1. The orbital is not oppening the port to let return fluid back out of the cylinder on the piston side, when adding fluid to the rod side (turning right).
2. The power steering pump isin't generating enough pressure or flow for the orbital to work properly. Although it works perfectly with a "slower" orbital, it just takes 9 turns of the wheel to turn.
Old April 8th, 2016, 10:18 AM   #15
BigBlockBlazer
Axle breakin' 101
Call PSC they have great customer support.
Old April 8th, 2016, 10:51 AM   #16
XJay
XJay's Avatar
Just spoke to Kevin at PSC, he's never heard of such an issue lol. He verified that the PSC pump that I'm running is plenty adequate for my set-up. He also said he doesn't think it can be an issue with the orbital itself since it works properly in one direction and that all lines are hooked up correctly. He said only thing it can be is an issue with the cylinder itself.
I'm going to try putting my old cylinder back on.
One other thing I just remembered from when I was originally setting up my hydraulic system is that I had to put shims (washers) in between the mounting bracket and the orbital itself to space the steering shaft out of the orbital a bit. Without the shims, it wouldn't allow me to turn right or left for some reason??? Almost like the steering shaft splines were bottomed out in the orbital, and not allowing it to turn.
Old April 9th, 2016, 07:54 AM   #17
XJay
XJay's Avatar
Welp, I found the needle in the haystack last night. Not gonna lie was a stupid mistake on my part. Put my old ram back on that I know is good, same issue, can't turn right. Decided put a different orbital on, and while transfering the fittings from the new orbital I just happened to check the fittings over and found that the one on the RH turn port was different than the other 3. For some reason it only had 4 tiny holes inside to allow fluid flow rather than being "hollow" like the rest. See pic below.
BTW thanks for everyone's input!
Anyway, now that it's running, steering ratio is about perfect; 3-1/2 turns left, 2-3/4 right. I find it way slower than my old set-up though and takes more effort to turn the wheel. Can't just spin it with one finger anymore. Not really happy with it. I assume the only fix would be a higher output p-steering pump???
Old April 9th, 2016, 09:25 AM   #18
lgottler
lgottler's Avatar
Not sure about the higher output pump. I'm running a factory ps pump and a smaller ram and can turn the wheel with one finger. Is there a minimum input load type of spring inside the orbital?
lgottler is offline   Reply With Quote
Old April 11th, 2016, 09:20 AM   #19
XJay
XJay's Avatar
I have no idea about the internal function of the orbital but the question was asked when I spoke to PSC and he said that the pump I'm running is plenty strong for my orbital.
When I was running a smaller 2" ram and smaller displacement orbital, I too could turn the wheel fast with one finger. Approx 3/4 of a second per revolution maybe.
Now with the new set-up it's like 2 or 3 fingers on the wheel and like 1.5 seconds per revolution. I was thinking steering effort would be easier with s bigger ram, guess not I'm hoping it'll be better with the fluid at op. temp too. Will take some getting used to I guess.
Old April 14th, 2016, 07:43 AM   #20
XJay
XJay's Avatar
OK took it for a quick ride and I'm really not happy with it. The orbital ratio to steering wheel revs is perfect, but steering is way too slow though. Can't turn the wheel fast enough to keep up with which direction you want to go while driving around.
One thing I found interesting is the more reading I do and the more people I talk to, I'm finding that actaul PSC pumps aren't all that great and lots of people easily burn them up.
A buddy of mine has gone through 2 of them. He switched to 90's chevy P-style pump off of a truck with hydro-boost and hasn't had an issue since. He said he took the upgraded spring and stuff out of the PSC pump to boost pressure, and used the PSC can cause it has the single AN output for the pressure line.
Anyone have any experience with a hydro-boost power-steering pump?
jeep cj steering box swap Ben stroker Jeep Tech 1 March 9th, 2016 06:54 AM
*SOLD* Trussed HP 30, Ford 8.8 Rear, 1 ton steering, trackbar Cool Hand Luke Completed Sales 4 November 15th, 2015 03:05 PM
Steering box /pitman arm help. Badmunky Jeep Tech 7 August 23rd, 2015 07:26 AM
Barnes 4WD HD Steering Barnes 4wd Vendors 0 January 14th, 2015 01:43 PM
CJ Steering Box? wildweaselmi 4x4 Product reviews and how-to's 8 December 23rd, 2014 09:44 PM
Page generated in 1.01302 seconds with 88 queries
