I bought this truck on e-bay for the engine (7.5) to put in another project. When I got it home and started working on it I decided I liked the truck and didn't want to tear it apart. It was an old fire truck so it was low miles and I felt pretty confident that it was maintained well. I drove the truck for a year before starting the transformation. In this time I sourced all the parts I needed to convert to 4wd (t-case, driveshafts, trans adapter and output shaft, etc.) I built a 6" lift for it (did i say cheap conversion) and used some 3" lift blocks I already had, since 2wd fords sit high in the rear already this leveled the truck. For coil springs I heard through grapevine that superduty springs were a 6" lift for F150's. Turns out it was only 5" so my camber is a little off (typical ttb). I will correct this with the 4wd swing arms (not installed yet, story on this later). Going to pull the trans to switch out the output shaft soon. Will post pics of progress as soon as I get a new cord to attach my old phone to pull those pics. I wanna start pics at beginning.
