power washers? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2017, 06:22 PM   #21
BlooMule
Old School
BlooMule's Avatar
I spent $30 at the coin op Monday, neither dirtbike came home clean and I had a line 10 deep behind me.
Damn. I can remove paint at the one down the block.
-rw-rw-rw
Old January 6th, 2017, 10:09 PM   #22
Fatty Matty
Fatty Matty's Avatar
Flow over psi every day.
I have an 8gpm machine at 3kpsi and a 6gpm machine at 2500 psi. The only time I use full pressure is when doing concrete, almost everything else is knocked down to well under 700psi. Wood is around 700 and houses are down around 100 or so. But... We can wash a 3-story building from the ground because of the flow.
Washing my quads and Jeep.... 1200 psi or so, but I'm pushing 6-8 gpm.
Almost every box store machine isn't going to last but a good machine is $1k minimum for 4gpm. A very good machine with 5.5gpm is $1500, an 8gpm machine is $3k and up
'12 JKU
'14 1500
www.midwest-abs.com
Old January 7th, 2017, 10:22 AM   #23
REEDracing94
REEDracing94's Avatar
We have a briggs thats 2700psi 2.3gpm. Seems to work well. Id imagine i use it for same thing you would be
REEDracing94 is offline   Reply With Quote
Old January 7th, 2017, 04:56 PM   #24
joe_jeep
welfare wheeler
joe_jeep's Avatar
years ago, i had a husky 1750psi electric.
it would not remove mounds mud from my tj.
Old January 7th, 2017, 08:38 PM   #25
GerkTJ
GerkTJ's Avatar
Originally Posted by GerkTJ View Post
best bang for the buck is the Briggs & Stratton VSPW 3000 psi with a 5GPM pump @ $399. Also has what they call PowerFlow which is great for cleaning tall objects
So buy a big garden hose!
GerkTJ is offline   Reply With Quote
Old January 9th, 2017, 07:52 AM   #26
kickstand
circling the drain
kickstand's Avatar
Lots of mud, dried/frozen on for a full day and 2 nights after 3 days of southern clay. Lots of nooks and crannies, etc. Pressure wasn't the problem, volume of mud was the problem.
Old January 9th, 2017, 01:32 PM   #27
Lousypirate
Whoop Whoop
Lousypirate's Avatar
When i finish the basement plumbing i plan to run a hot water supply to one of my taps to get hot water pressure washing
The Kernel (46 CJ2a)
Mary Jane
Old January 9th, 2017, 02:18 PM   #28
firestorm
I thought about doing that, but mine says not to run hot water through it.
firestorm is offline   Reply With Quote
Old January 9th, 2017, 03:25 PM   #29
Lousypirate
Whoop Whoop
Most are rated to 100, but if you just want to quick do, say an engine. It would prolly be fine
Mary Jane
Old January 10th, 2017, 11:36 AM   #30
kickstand
circling the drain
kickstand's Avatar
I can't see tap water being hot enough to cause an issue. Plus, at 3-5 gpm you aren't going to have hot water for all that long anyway.
Old January 19th, 2017, 08:36 AM   #31
phazer42
I wheel, therefore I am
phazer42's Avatar
I purchased one of these from homedepot online. It was on sale for $50 off (end of march 2016).
I also found that the quick disconnects are very handy. And, the Turbo nozzle is awesome.
phazer42 is offline   Reply With Quote
Old January 19th, 2017, 08:41 AM   #32
BlooMule
Old School
BlooMule's Avatar
I''ve thought about using one of the 'on demand' water heaters for this purpose.
-rw-rw-rw
Old January 19th, 2017, 08:49 AM   #33
AJ Hall
offensive 2 the sensitive
AJ Hall's Avatar
I'm sure you blow harder than any power washer on the market.
If you dont like it, get out.
AJ Hall is offline   Reply With Quote
Old January 19th, 2017, 09:33 AM   #34
Really AJ? Just.............. fucking............... stop.
Old January 19th, 2017, 10:19 AM   #35
Sandals
Fucking Zen as Shit
Sandals's Avatar
Thats not a bad idea. I was going to put an on demand in the shop for that bathroom anyway, I could put another tap off of that to be a pressure washer line.
Old January 19th, 2017, 10:21 AM   #36
Sandals
Fucking Zen as Shit
Sandals's Avatar
But to the thread, I had a cheapy electric one for a while, did ok, but eventually went kaput.
When that died (2?) years ago, I bought This Ryobi http://www.homedepot.com/p/Ryobi-310...940B/203615829
Mainly because of the honda engine, and I've had good luck with Honda engines in lawn equipment. It's been awesome so far.
Old January 19th, 2017, 10:44 AM   #37
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
So, is there a consensus on either gas or electric?
I've used both, found the gas to be to pretty finicky, but portability was only limited by the hose; electric was nice and smooth but had to worry about power along with water.
I've been needing a new PW for a couple years, the pump went out on my gas one (still have the motor), and i've just been borrowing my (soon-to-be) father in-law's. Looks like flow is more important that psi.
@kickstand did you make a choice on one yet?
-2011 Ford Fusion SEL 3.0L
-2006 Jeep Grand Cherokee Laredo 4.7L 65th Annv.
-1996 Chevrolet K1500 5.7L Vortec- Dirty mall queen
Old January 19th, 2017, 10:51 AM   #38
GearDrive
A little slow
GearDrive's Avatar
If you had an outdoor wood furnace and a separate water heater tank, that would be the hot setup.
GearDrive is offline   Reply With Quote
Old January 19th, 2017, 11:56 AM   #39
firestorm
FWIW, I found my old electric to be more convenient for general vehicle washing, simply because the motor would automatically shut off a few moments after you released the trigger on the wand. On a gas machine, the the unloader valve recirculates water, and any more than a couple minutes could result in damage to the pump.
For everything else, the gas machine is far better. Using the wide nozzle for low pressure jobs, you can finish much quicker, simply because of the increase in the volume of water. I'd guess I can work with a fan of about 8-14" wide with the better effectiveness than the old machine at 2-3" wide. For the driveway, there's just no comparison; the electric was pointless, aside from spot cleaning. For deep cleaning under my truck, I'd choose the gas machine as well.
Also FWIW, my electric died because the unloader valve jammed. I regularly use a treatment to prevent hard water deposits in the new machine. I imagine the old one would still be working had I realized the potential for that happening.
Old January 20th, 2017, 07:26 AM   #40
kickstand
circling the drain
kickstand's Avatar
I'm leaning towards the Generac that was posted for $279 at the home depot/menards/etc.
Though, I'm still considering the simplicity of an electric unit as I estimate most of my useage will be within an extension chord length of my spicket.
In a little less of a rush to grab one right now than I was, but will probably grab one in the next couple of weeks. I'm not in any hurry to go wash things in the cold.
Similar Threads
tow truck not getting power to fuel pump BIGBADJMY General Tech 29 January 7th, 2016 09:41 PM
1986 jeep cherokee 2.8L v6 loose power picks power back up while driving MINISTER Jeep Tech 5 November 12th, 2015 10:03 AM
Power issue. any ideas? mymizzery Jeep Tech 1 October 26th, 2015 03:44 PM
2012 Dodge Power Wagon Hughiam Vehicles for sale 2 February 6th, 2015 07:38 PM
Vintage Power Tools For Sale - Craftsman / Power Kraft / B&D (SOLD) Bow_Extreme Completed Sales 0 October 20th, 2008 12:34 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.62492 seconds with 85 queries
