Engine block heater - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2016, 08:10 AM   #1
scottie
Eye candy
scottie's Avatar
Default Engine block heater
I've never had a car with one before, my ram has one.
At what temperature do you use this at on a gas engine? I figure I will plug it in on the few single digit days we have. \_(ツ)_/
Old November 22nd, 2016, 08:36 AM   #2
koochman450r
koochman450r's Avatar
really I plug mine in whenever it get below freezing. Mainly because I love the instant heat I get and I feel better about my truck sitting warm. If I plug It in while its warm it'll keep the coolant about 100 degrees. keeping underhood temps warm also helps your battery life and starting. But that's me.
you won this battle.
Old November 22nd, 2016, 10:14 AM   #3
airforce26yrs
It also helps on MPG. A cold engine uses more gas until it warms up to operating temps.
airforce26yrs is offline   Reply With Quote
Old November 22nd, 2016, 10:25 AM   #4
Bones
Bones's Avatar
better put the block heater on a timer or DTE will thank you.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 22nd, 2016, 10:27 AM   #5
Coyote Red
Coyote Red's Avatar
For my diesel they recommend using below 35-40. I know you said for a gas engine which usually doesn't have a problem with cold starts. I would recommend getting a programable timer and setting it to come on about 3 hours before you plan to leave. It is also recommended that you wiating a minute after unplugging it for the element to cool down so if there is an air bubbles in your cooling system it doesn't get to the element and burn it out prematurely
Coyote Red is offline   Reply With Quote
Old November 22nd, 2016, 11:58 AM   #6
scottie
Eye candy
scottie's Avatar
I just have to find a way to keep the neighborhood kitties from sleeping under the hood too.
Old November 22nd, 2016, 12:29 PM   #7
TrevT1
TrevT1's Avatar
I have one on my Jeep and I use it on most really cold days. I don't have auto start, but if if I plug it in, I have heat almost right at startup. Mines on a timer, set to start 2 hours before I leave. Mines plugged in when it's in the 20's and below.
TrevT1 is offline   Reply With Quote
Old November 22nd, 2016, 06:01 PM   #8
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I have never plugged in any of the 3 cummins powered Rams i have owned. I don't see the point, they don't start hard even down below 0. Actually neither my 09 nor my current 14 actually had a cord to plug them in.
Old November 24th, 2016, 08:33 AM   #9
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
Send a message via AIM to Trailrig
This
Trailrig is offline   Reply With Quote
Old November 24th, 2016, 07:14 PM   #10
scottie
Eye candy
scottie's Avatar
Originally Posted by Trailrig View Post
This
Cold trans shifts make me angry.
Old November 24th, 2016, 08:17 PM   #11
hondadirtracer
Skymaster
hondadirtracer's Avatar
The current dte rate is 8.772 cents per kwh. A cummins block heater is rated at 750 watts. Running it for 8 hours a day would cost 52 cents per day or $16 a month if you have it plugged in every night.
hondadirtracer is online now   Reply With Quote
Old November 24th, 2016, 08:37 PM   #12
I've never plugged in my dmax either. Starts fine down to single digits. Re being warm at the get go, I enjoy parking in a heated garage. 👍
Old November 24th, 2016, 09:41 PM   #13
1TFROT
1TFROT's Avatar
I typically won't plug in, always use the power service instead and zero issues all winter
1TFROT is offline   Reply With Quote
Old November 25th, 2016, 11:45 AM   #14
montecarlo33
The Violator
montecarlo33's Avatar
This. Did this all last winter cause my block heater cord was broken and never had an issue on my dmax in northern michigan.
Sent from my SM-G930V using Tapatalk
Old November 25th, 2016, 12:57 PM   #15
Powerman 5000
Previously cj65
Powerman 5000's Avatar
I don't plug in my Dmax, use no fuel additive and have had zero issues. The last 9 trucks I have had I have done the same with and only one ever failed to start when it was cold. I blame that on being a Ford 6.ohno.
Powerman 5000 is offline   Reply With Quote
Old November 25th, 2016, 02:45 PM   #16
I've used fuel additive in really cold weather............ just cuz people tell me I should.
Old November 26th, 2016, 09:39 AM   #17
scottie
Eye candy
scottie's Avatar
Aren't they also kind of self regulating, once they get a certain temp wouldn't the resistance change???
Old November 28th, 2016, 05:37 AM   #18
9T4YJ
9T4YJ's Avatar
You don't really need it until temps start dipping below 0. Like, in the range of -20 to -40, but when it's that cold, who goes out?
If you really want to use it, as said, you'll spend a few extra bucks on electricity every month. If you have a long commute, your fuel savings will be small. If you're commute is short, like, the vehicle is finally up to temp by the time you get to work, it might balance out in fuel savings to heat the block every morning. I know I hate driving with winter gloves on.
9T4YJ is offline   Reply With Quote
Old November 29th, 2016, 12:52 AM   #19
shawn
Resident HVAC/R Jambi
shawn's Avatar
The only time I ever needed one was while living in North Dakota, your junk would not start very nicely without one, it was stupid cold up there.
Then, about 2 winters ago while up near Lewiston there was a night that hit around -10 and my jeep would not start. it would turn over just fine but would not start, a block heater would have been nice at that moment.
Old November 29th, 2016, 06:10 AM   #20
tonka toy
It's got a HEMI!
tonka toy's Avatar
I have never plugged in my '12 F350 I just hit the remote start when I wake up and by the time I walk out the door most of the snow is off the truck and it's warm inside
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Similar Threads
Looking for a V8 Engine Block Swampdog02 Wanted 0 October 26th, 2015 03:22 PM
600 HP Chevy Race Engine - small block FORD FLARESIDE Parts for sale 1 May 18th, 2015 12:40 PM
4.2 258 engine block 89cjwftw Wanted 5 May 17th, 2015 02:21 PM
SOLD Ford 4.0L Engine Block .040 Over BLZR Completed Sales 3 December 27th, 2014 07:49 PM
6.0L LS engine block. Strangler Wanted 4 December 11th, 2014 12:03 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.54398 seconds with 85 queries
