Dana 30, Expl 8.8, '78 4.10 geared 9".. All sold! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2008, 02:54 PM   #1
Pete M
Comanche Addict
Pete M's Avatar
Default Dana 30, Expl 8.8, '78 4.10 geared 9".. All sold!
A complete 78 Ford Bronco 9" (fullsize, 31 spline shafts, factory 4.10s, drums, posi) that was under my Comanche. About 58k miles on it. About 4k miles on new tapered axle bearings/seals. Somehow I hurt it on the last wheeling trip. The Yoke wobbles a little bit. No idea what happened. But I pulled the yoke off today and I'm confident it's the culprit in the wobble. I found another 9" (with disks and a spool) so I have no need of this anymore.
$140 Sold!
Thanks,
--Pete
A non-CAD XJ Dana 30 axle. 3.55 gears. Was going to use it for a project, but lost interest. No brakes. The passengers side axle shaft was gone when I got it. The drivers side is there and the Unit bear seems fine. I have a stubshaft and bearing for the passenger side. They came with the axle, but weren't from the axle. And the cover bolts are missing.
$40 SOLD!!!
A 9" housing from a fullsize F-150. The 31 spline shafts and bearings are there. The 3rd member and most of the brakes are gone (drum backing plates are there). Leaf perches were removed. YJ shock mounts were welded on.
$50 SOLD!
Very nice Explorer 8.8. I was hanging on to this for a project but decided it'll never happen, so screw it. 4.10 gears, posi, disk brakes. Brakes and brakelines are in good shape. Very little rust.
$290 SOLD!
Pete M is offline
Old August 7th, 2008, 03:03 PM   #2
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
hmmmm anyone have $290 they can loan me??? lol
mudviper is offline
Old August 7th, 2008, 03:19 PM   #3
bjgolfpro
bjgolfpro's Avatar
PM sent on the 8.8, thanks
bjgolfpro is offline
Old August 10th, 2008, 10:52 AM   #4
bjgolfpro
bjgolfpro's Avatar
Trying to get ahold of you. I would like to get that 8.8 from you, got cash waiting. Thanks
Old August 10th, 2008, 10:56 AM   #5
jeepxj_boy_21
linked
jeepxj_boy_21's Avatar
still got the 30?
jeepxj_boy_21 is offline
Old August 10th, 2008, 11:13 AM   #6
jeepxj_boy_21
linked
just need the axle housing and gears buddy has a dana 30 and it has way to much play in it. rather just find a cheap axle then take it in to get geared
Old August 10th, 2008, 02:22 PM   #7
joe_jeep
welfare wheeler
joe_jeep's Avatar
whats the width on the 31 spline shafts in the bare 9 inch? thx
joe_jeep is offline
Old August 12th, 2008, 02:26 PM   #8
Pete M
Comanche Addict
Pete M's Avatar
Explorer 8.8 and Empty 9" are sold
Pete M is offline
Old October 11th, 2008, 08:04 PM   #9
Pete M
Comanche Addict
Pete M's Avatar
Bump for new info.
I pulled the yoke off and I'm confident it's the culprit in the wobble. The pinion shaft looks fine. Needs a new yoke.
Pete M is offline
Old October 21st, 2008, 10:29 AM   #10
Pete M
Comanche Addict
Pete M's Avatar
You can buy a 'Jeep" yoke for it too. The 9" I got to replace this had a 1330 yoke on it.
--Pete
Pete M is offline
Old October 21st, 2008, 07:00 PM   #11
rdj59
what's the wms to wms measurement of the $140 9"?
Thanks,
Jeramie
rdj59 is offline
Old October 21st, 2008, 07:34 PM   #12
Pete M
Comanche Addict
Pete M's Avatar
The drums aren't on it at the moment, but I measured about 65". It's from a fullsize Bronco.
--Pete
Pete M is offline
Old November 3rd, 2008, 09:37 PM   #13
jeepers48
jeepers48's Avatar
What kind of posi does the 9" rear have. Did the the rear have a vibration and thats the reason you pulled it?/yoke?
jeepers48 is offline
Old November 3rd, 2008, 10:10 PM   #14
Pete M
Comanche Addict
Pete M's Avatar
It's the stock Ford clutch posi. No vibrations were ever felt in the truck. The only reason I even noticed was that the dust cover ring thingie (a technical term) popped free when wheeling and it made a ringing noise as it spun around on the way back to the campground. When I crawled underneath to check it out I noticed that the yoke was a tiny bit sloppy. For all I know it could have been like this ever since I bought that old Bronco. I'm not sure I would ever have noticed if that ring hadn't popped off. And if I didn't have another axle already, I'd probably just reassemble it and keep wheeling. I've been keeping an eye on the local pull-your-parts, but 9" axle have suddenly become scarce (isn't that always the case when I'm looking for something in particular).
--Pete
Pete M is offline
Old November 9th, 2008, 10:31 PM   #15
Pete M
Comanche Addict
Pete M's Avatar
Pete M is offline
Page generated in 0.31348 seconds with 68 queries
