Powertrax Lockrite - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2008, 11:20 PM   #1
Kawierider
Kawierider's Avatar
Default Powertrax Lockrite
Vehicle:
XJ w/ 4 inches of lift, Ford 8.8, cut fenders, locked rear, limited slip front. Was carrying heavy weight in spares and camping equipment most of the time.
Tires:
Super Swamper Truxes MT
33x12.5r 15
Trail pressure 8-12 PSI depending on conditions.
Street Pressure 35 PSI
I ran:
Routine Street Driving
Drummond Island Mi, Turtle Ridge OHV Park
Lake Havasu Arizona, OHV trails
Moab Utah, "Moab Rim" and "Pritchet Canyon"
The Rubicon Trail
Penrose Colorado, The Independence Trail System
Terrain Types:
-Rock (slick rock or pretty grippy sandstone)
-Some gravel, sand, and mud.
The Good:
Amazing traction increase.
No need to replace the carrier
The Bad:
Some Noise on the street
Maybe bad in the ice/snow (don't know yet)
The Installation:
It was easy. There are a couple of write-ups else where online on this installation so I will not detail it unless someone asks for it. The installation took about 3 hours. Now that I have done one I could do it again in half that time. This is definitely qualifies as an "easy mod" that I should have done A LONG time ago.
Does the Locker Make Noise:
Yes, when I am looking for noise I can find it. If I make a quick, tight turn in a parking lot, or make "michigan left" into the left lane, while on the gas I can hear the inside tire chirp a little bit. Once or twice I have heard a couple of clicks from the locker, but I have to really TRY to hear it.
When I first put the locker in I didn't believe it was working as I couldn't hear any noise from it until I really really tried to make it make noise. I was very impressed. (note:extra impressive as I had my doors off at the time)
How does the locker handle in two wheel drive:
One pavement it's pretty much transparent except for the occassional chirp of the tires.
On Gravel, or sand the truck handles like before but gets much better grip. The rear end likes to rotate much, much more easily than before. My first time out I spun it on accident while trying to 'drift' a fast, sandy turn. I got used to it very quickly though.
How does the locker improve 4 wheel drive:
AMAZING. I can now approach a rock from other directions but straight on, and let my suspension flex out while still moving forward. This modification allowed me to crawl over things that I used to have to Hammer down through and break parts on. This locker has been nothing short of amazing. On my recent "outwest trip" to Moab, The Rubicon Trail, and The Independance Trail system in Colorado made it very aparent that I wouldn't have been able to do these trails without the locker.
The Bad Offroad:
Sometimes, especially off camber, the rear end wants to rotate around more than it did, but usually this was only if I was hung up on my trans crossmember.
I can post videos or pictures of most of these examples and a quick write-up if anyone is interested or needs the information.
Old August 6th, 2008, 11:20 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
im running one in my front axle soo far no problems with mine
Old August 6th, 2008, 11:22 PM   #3
xj97sport
atv rider
xj97sport's Avatar
got on in my jimmy ... works like a charm
Old August 12th, 2008, 07:22 PM   #4
Cherokee23_98
Cherokee23_98's Avatar
I have one in my Cherokee. It clunks a little when I reverse. Normal?
Cherokee23_98 is offline   Reply With Quote
Old August 14th, 2008, 07:16 PM   #5
Kawierider
Kawierider's Avatar
sounds about right if you are turning tightly. I've never noticed a difference between forward and backwards though.
Old August 14th, 2008, 10:45 PM   #6
Cherokee23_98
Nope. Just backing straight...no turning
Old February 16th, 2009, 06:34 PM   #7
rraymond
nuh thats a space pnut
rraymond's Avatar
Just put one in the front of my Cj. love it
rraymond is offline   Reply With Quote
Old February 17th, 2009, 08:28 PM   #8
liftedlq9
Dune Slut
liftedlq9's Avatar
I did one in my 86 a few years ago, the 12 bolt chewed it up and spit it out, lol. I also did one in a 97 k1500 and it didnt work well either. I have talked to several people that love them and never have any issues, must be my luck, lol.
liftedlq9 is offline   Reply With Quote
Old March 21st, 2009, 09:30 PM   #9
Strider
Strider's Avatar
Send a message via Skype™ to Strider
I ran one in the Chrysler 8.25 of my XJ back in 1996 or 97 and it was a POS. I went through a set of pins EVERY trip to Silver Lake and usually had to limp out to change them in the parking lot. The thing would go off like a shotgun in parking lots around town too. My wife HATED that! The same exact problems were found in a buddy's Bronco but that was in the front if I remember right.
I upgraded to the no-slip and loved it. I am actually in the market for a no-slip for the front of my TJ right now.
Strider is offline   Reply With Quote
Old April 20th, 2009, 05:36 PM   #10
Jt91bronco
Jt91bronco's Avatar
could that excessive noise be caused by improper clearance?
Jt91bronco is offline   Reply With Quote
Old July 12th, 2009, 03:32 PM   #11
07gixxer600
Powertrax products are JUNK!
I had the lockrite, and the "no-slip". Both gave me very good traction, but the they just are not durable. I broke the lock rite in 2 weeks (with 31in tires in a chrysler 9.25!!) I broke the pins and it split the entire right side of the unit right down the middle. The clearances were right. Powertrax gave me a new one but I oped for the no-slip version. The no slip was much better, quieter and lasted me about 2 months. When It broke it grenaded metal everywhere and took out my ring and pinion.
I regeared my axles myself to 4.56 gears 10,000 miles ago. Gear instal is much much more complicated than a powertrax install. I know what im doing and it was not a installation error. Im running just a lsd now and its doing great.
07gixxer600 is offline   Reply With Quote
Old October 21st, 2009, 08:39 AM   #12
88sbcyj
Broke ass college kid
88sbcyj's Avatar
i have one in my v8 dakota 2wd and i love it, got sick of the one wheel peel burnouts at the track and spinning for the first 50ft, but put in a powertrax in the spring and i dropped almost a whole second off my times...untill i blew out my trans that is
88sbcyj is offline   Reply With Quote
Old October 22nd, 2009, 10:10 AM   #13
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
One more data point for the the no-slip being a great locker. Wheeled for 30K in my DD with no problems. Trips included CO, Moab, Badlands, D.I., and what-not.
@clarkstoncracker
Page generated in 0.37607 seconds with 62 queries
