1979 Chevy Suburban mud truck....$2000 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2008, 10:22 AM   #1
PolarYJ
Throttle control?
PolarYJ's Avatar
Send a message via AIM to PolarYJ
Default 1979 Chevy Suburban mud truck....$2000
so here's the deal, i bought this truck not too long ago and its still in the UP at school. i will have it downstate labor day weekend. i really hate to sell it but have backed myself into a corner with toys and if someone is really interested we'll talk.
1979 Chevy Suburban, 350, SM465, NP205, 6" suspension lift, 38.5x11x16 TSL Boggers, 3/4 ton Eaton 10 bolt rear axle (welded, new hub bearings & seals May'07) 4.10's, 3/4 ton Dana 44 front axle (with Spicer Hubs, Moog tie rod spring '07), 4.10's, Suburban tub is from an '88 Suburban with Silverado trim (AM/FM digital radio, A/C heater, carpet, cloth seats, headliner). Engine was rebuilt a few years ago with flat tops, low end torque cam, Weiand X-CELerator aluminum intake, high vol oil pump...crank was polished, with all new bearings and seals and a hone job, has a Holley #4777 650 cfm manual choke double pumper and K&N air filter. Has new heater core, roof mounted spot light, school bus fan (2-speed), Midland 40 channel CB radio with antenna (no cable), Auto Meter 8000 RPM Street Tach, WARN front winch bumper, '88-'98 full size Chevy tow hooks(front), new rear window motor last fall, rear step bumper, new radiator 2 years ago, new belts and heater hose, new spark plugs, wires, cap and rotor, Dynomax dual 2.25" exhaust with Thrush Boss Turbo mufflers, new clutch, flywheel ring gear and flywheel resurfaced in Oct. '06., new battery box, 94 Amp single wire alternator (spring '07),
$2000 obo
Also comes with extra parts:
Dana 44 axle shafts
Dana 44 external lockout wheel hub
Dana 44 spindles
Dana 44 diff cover and hardware
pair of drive flanges for Dana 44, with springs and caps
good used tie rods
draglink with stock steering arm
front driveshafts-spares need u-joints
misc. trim parts
extra grille
extra set of front door shells
passenger side fender (rust free)
several cab, engine, and front clip wiring harnesses
used clutch and pressure plate
Eaton 10 bolt shafts
4 extra gauge clusters (one with factory clocks)
door panels
extra lockout hubs (Spicer, MM and WARN)
spare alternators and starters
misc. engine brackets
SBC engine parts, air cleaner bodies
set of hub caps
door glass
mirrors and parts
master cylinder (core)
extra belts
factory gas tank skid plate
4 or 5 power steering pumps all with brackets, dual and single groove pulleys
1 steering gear box
auto trans linkage
master cylinder/brake booster combo
Auto/Cruise steering column with steering wheel
transmission crossmember
many many more parts
PolarYJ is offline   Reply With Quote
Old August 8th, 2008, 10:06 AM   #2
PolarYJ
Throttle control?
PolarYJ's Avatar
i know its not down here to look at yet... but no one even has any interest or questions??
Old August 16th, 2008, 08:39 PM   #3
PolarYJ
Throttle control?
PolarYJ's Avatar
possible trade for street or dirt bike or quad
Old September 16th, 2008, 08:28 AM   #4
PolarYJ
Throttle control?
PolarYJ's Avatar
btt, new price
Old October 12th, 2008, 05:55 PM   #5
XLJetsFan52
Just a good ole' boy
XLJetsFan52's Avatar
Any other trades?
XLJetsFan52 is offline   Reply With Quote
Old October 25th, 2008, 08:31 AM   #6
Jodyota
Jodyota's Avatar
Send a message via Yahoo to Jodyota
interested in a 68 kawasaki w-1 650 very rare needs restored but wouldnt be hard to get on road again it is well worth 3k plus lemme know
Jodyota is offline   Reply With Quote
Old February 23rd, 2009, 03:53 PM   #7
n8presler
you wouldn't happen to be going to the mud run in gillman labor day weekend would you?
n8presler is offline   Reply With Quote
Page generated in 0.31304 seconds with 44 queries
