Painting question... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2006, 07:17 PM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default Painting question...
White primer or Gray primer for a bright green paint job?
For some reason I'm thinking white.
Old April 23rd, 2006, 07:20 PM   #2
BMFmike
meh.
BMFmike's Avatar
Is the green a secondary color or the base, eh, either way I would believe white or grey would be fine, I have never used a white primer before, just different shades of grey.
Old April 23rd, 2006, 09:31 PM   #3
scottie
Eye candy
scottie's Avatar
I used light gray primer on my zuk, but its not exactly Bright Green
Old April 23rd, 2006, 09:32 PM   #4
shawn
Resident HVAC/R Jambi
shawn's Avatar
why does it matter? either one lease paint all over your backyard!
Old April 24th, 2006, 07:41 PM   #5
Blackjackbender
white primer, it will make the green brighter i believe.
Old April 24th, 2006, 11:37 PM   #6
PavementPounder
PavementPounder's Avatar
What would you prefer show through after you scratch the fukc out of it the first time out? :tonka:
Old April 25th, 2006, 07:47 AM   #7
AshieK
Got my Jeep!!
AshieK's Avatar
Another Vote for White making it brighter
(I have no idea, my husband (body shop dude) told me....)
:tonka:
AshieK is offline   Reply With Quote
Old April 25th, 2006, 07:50 AM   #8
Just a Spouse
Motrcytman's spouse
Just a Spouse's Avatar
Just a Spouse is offline   Reply With Quote
Old April 25th, 2006, 09:20 AM   #9
Deaner
lost
Deaner's Avatar
Send a message via AIM to Deaner
First of all. what brand of paint is it ? im wondering becouse in automotive paints there is a value shade system to paints and matching primers and sealers to go with that shade. to are you going to cover the entire thing in primer before you lay the green? if so I would use a sealer instead of primer for one it has beter sealing properties to it. to insure that any body work and scratches dont bleed through over the years and helps agains corrosion from underneath. two you dont have to sand it before you paint. It jsut gives a better overall end product. I would use a light grey sealer ( value shade 1 ) and put a white base coat on that then your green. or just the sealer and the green its all personal preferance. If you need help get ahold of me and ill do what I can for ya.
Originally Posted by Toolmakerprevo View Post
Well at least I can screw comfortably in a bathtub!
Originally Posted by Nuggets View Post
Half you guys bitchin' about these women are probably dragging home snow cows and tundra pigs from the bar.
Deaner is offline   Reply With Quote
Old April 25th, 2006, 09:25 AM   #10
Sandals
Fucking Zen as Shit
Sandals's Avatar
mmm this would be a great thread in a paint and bodywork forum :D
Old April 25th, 2006, 11:36 AM   #11
BMFmike
meh.
BMFmike's Avatar
OK since the original poster wont get back, I guess it depends on what your base is, are you going to seal it before you paint blah blah blah! Let us know dewd!
Old April 25th, 2006, 11:42 AM   #12
Toivo
Feel lucky?
Toivo's Avatar
Default Tint er'
I would grey primer it, and tint your primer sealer white or green. If you tint your primer sealer, it wont take nearly as much base coat to cover the vehicle, costing less, and the end result will be brighter. The end results are only based on whats underneath! Let us know, CC.
Old April 25th, 2006, 09:12 PM   #13
Deaner
lost
Deaner's Avatar
Very good point but pending on how light the color green he is useing for top coast or how translucent it is. with the sealer tinted green, you will change the color from its original, slitlley. but it works like a charm
Old April 25th, 2006, 09:16 PM   #14
Toivo
Feel lucky?
Toivo's Avatar
Default k
I was just going on the fact that the top coats will be a brighter hue if tinted than if just sprayed over grey k-36 primer or equivalent.
Old April 26th, 2006, 01:35 AM   #15
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
Default Questions
1- Are you still planning on using the glow in the dark powder?
2- Is the Glow going in the paint, clear or both?
If the glow is anything like chromalusions (sp) / Flip-Flop paint you need to use a black primer for maximum effect. I would check with the glow powder manufacturer before making any final descisions
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old April 28th, 2006, 11:35 PM   #16
low900rr
low900rr's Avatar
I always use white under certain colors for quick coverage and a brighter color. Yellow is one of the worst.
low900rr is offline   Reply With Quote
Page generated in 0.43554 seconds with 71 queries
