89 Bii - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 1st, 2008, 08:33 PM   #1
Jdc215
Jdc215's Avatar
Default 89 Bii
does anybody know if there is a kit on the market to rebuilt a factory ford 7.5 LS carrier. and is it worth putting a front locker in my stock d35? FYI i have factory 3.73 gears. and am running 30x8x15 tires. 1" lift. going to be mounting a good roof rack, brush guard to hold cb antenna and lights and will be mounting chevrolet k1500 tow hooks. what do you think. i will post pictures when i am done.
Jdc215 is offline   Reply With Quote
Old August 1st, 2008, 08:37 PM   #2
MiNi Beast
MiNi Beast's Avatar
when something breaks always upgrade.
Old August 1st, 2008, 08:37 PM   #3
spend the money on a 8.8 in the rear and lock that before locking the front
Old August 1st, 2008, 08:55 PM   #4
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
x2, the 8.8 will hold up much better than the 7.5 will
Bronco351 is offline   Reply With Quote
Old August 3rd, 2008, 01:23 AM   #5
Jdc215
Jdc215's Avatar
does anybody know what the ratings are for 7.5 and 8.8. is there that big of a difference?
Old August 3rd, 2008, 02:02 AM   #6
MiNi Beast
MiNi Beast's Avatar
difference is about 1.3, so yeah 8.8 is better
Old August 3rd, 2008, 02:33 AM   #7
Bronco351
Powered by Ford
Bronco351's Avatar
http://www.greatlakes4x4.com/showthread.php?t=719
lots of 8.8 info in this thread
as far as 7.5 info try broncoii.org, thats probably your best bet.
8.8s you get can w/ disk brakes and also have a larger amount of available parts.
overall its a much better axle and not overly expensive, great choice to swap into a bronco ii and from what i have heard it is not very difficult (relatively speaking)
Old August 3rd, 2008, 11:36 AM   #8
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
yeah its an easy swap to do i am going to be doing it in my b2
Bronco Ollie is offline   Reply With Quote
Old August 3rd, 2008, 05:04 PM   #9
ibleedblue1385
"god damn cam"
ibleedblue1385's Avatar
might as well find a set of EB axles.
ibleedblue1385 is offline   Reply With Quote
Old August 8th, 2008, 07:26 PM   #10
Bronco Ollie
so how is the b2 coming along?
Old August 10th, 2008, 09:53 PM   #11
Jdc215
Jdc215's Avatar
i think it has the factory traclock Limited slip carrier and i am looking for a kit to rebuild it. i have replaced the rear springs and bought front springs last week. i think i am going to put in 2" blocks and coil spacerswhile the hardware is off. the new springs raised it back to stock height more or less. just wondering if i would need new brake hoses or anything to do a really cheap 2" lift. ordered a roof rack to haul a spare tire and deer this fall. also going to order a cheap jcw full brush guard to hold my 6" KC hilights. finally i have two fullsize chevrolet tow hooks to mount up for a solid front tow point. working on gathering parts for a cb radio install and a home made tire carrier for the roof rack. when all this is done i should be done untill next summer. i wont have much extra money while at school. I'll probably save all year for a set of tires.
Page generated in 0.21642 seconds with 56 queries
