02 Tauras Need help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 31st, 2008, 03:26 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default 02 Tauras Need help
Running like crap, has a cel on. I found a broken vacuum line but can't find where the hell it goes, its an 02 taurus 3.0 ohv. If any oen has oen and can tell me where it oges, or even better yet take a pic of it.
Old July 31st, 2008, 03:32 PM   #2
howell_jeep
Last Free Man
howell_jeep's Avatar
Junk it and sell me your rims.
I SHOOT RAW!
Exercise your rights! Open Carry!
howell_jeep is offline   Reply With Quote
Old July 31st, 2008, 03:41 PM   #3
blownexploder94
Todd
blownexploder94's Avatar
are you positive its vacuum or is it pisser fluid line
Old July 31st, 2008, 03:57 PM   #4
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Use this
IFS SUCKS is offline   Reply With Quote
Old July 31st, 2008, 04:29 PM   #5
Bones
Bones's Avatar
it has a CEL.... find out for what. it's trying to tell you.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 31st, 2008, 04:39 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
P0136-02 circuit malfunction
P0156-02 circuit malfunction
P1131-manufacturer control fuel air metering
P1151-manufacturer control fuel air metering
P0171-System to lean
P0147-System to lean
Old July 31st, 2008, 05:13 PM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Originally Posted by booblinker View Post
I'd bet that's the passsenger side washer line. The kink in the line is caused by the hood closing while the line is attached to on of the front strut bolts (retainer on line shown in other picture).
Unplug it and use the washers to see what happens.
As for the codes, sounds like you have a vacuum leak, exhaust leak, or damaged O2 sensors.
Old July 31st, 2008, 05:50 PM   #8
Medic8
You call, we haul.
Medic8's Avatar
Yep, that's for sure the washer fluid line. I just replaced one on a 2001 Taurus about 4 hours ago.
As for the codes, and the running rough. Here's a few questions for you. Does it smooth out when you raise the RPMs? Is it worse under any particular conditions (engine hot/ cold, driving under load vs free-revving in park/neutral, when it's wet out vs when it's dry out, etc)? See if you can pinpoint any conditions when it gets worse and/or better.
To me, it sounds as if you've got an air leak somewhere, possible a bad intake gasket (common 3.0L OHV problem). It could be a dry rotted/ cracked vacuum line as well.
The circuit issues on the O2 sensor have me concerned though. If it was a vacuum leak, you'd just see the bank 1/2 lean codes without any circuit malfunction codes. Here's some additional info:
A code P0136 may mean that one or more of the following has happened:
* Faulty O2 sensor
* Leak in exhaust close to O2 sensor
* Short to voltage on O2 signal circuit
* Open in circuit resistance caused by corrosion in connector
The P0156 code is the same code, only on a different O2 sensor location. More specifically Bank 2, Sensor 2, meaning the sensor AFTER the catalytic converter. If I'm not mistaken, that car only has 1 after-cat O2 sensor, so I'm not sure why it would be throwing out both banks codes.
Regardless, I would start with the cheapest option, which would be checking all of your vacuum lines for cracks and dry-rotting. Buy a repair manual if you don't have one, that way you can see all of the routing and where all of the lines are. Then, if that's not the culprit, I'd start investigating an intake manifold leak, in which case you're probably better off taking it in.
Good luck! Sorry for the wall-o-text.
Old July 31st, 2008, 07:37 PM   #9
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
vacuum leak, that line is for the washer fluid.
Old July 31st, 2008, 11:05 PM   #10
Never_Evil
Check your PCV line. My Expedition flipped everyone of those codes exactly. I read up and supposidly it was a bad intake gasket, turned out my pcv line was melted through and causing the problem.
Page generated in 0.23889 seconds with 53 queries
