Ford 400 Big Block - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 29th, 2008, 05:48 PM   #1
sufferingant
sufferingant's Avatar
Default Ford 400 Big Block
Hey guys, my dad has a 1984 Ford F150 but I believe it's on a '79 Bronco frame. I could be totally wrong, don't quote me on that . Anyways, it's 4x4 and the engine is a 400 big block, which as I've read its a 351M stroked to 400?
I have no idea about the truck, but I was hoping someone could give me some insight? I'm having trouble finding parts for it, specifically a carburetor. I'm going to price it out and see if it's worth it to turn into a plow truck for the winter, but it definitely needs some work haha.
It's sitting in the driveway so I can get as many pictures as necessary.
Any help would be greatly appreciated, thanks guys.
Here's some pictures. Yeah I have to move it so I can weed whack, haha. And I tried to get some engine bay shots but there is so many active bee's nests and I'm allergic. I'll wait til dusk and spray them down.
sufferingant is offline   Reply With Quote
Old July 29th, 2008, 07:00 PM   #2
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
From the small glimse of the radius arm it looks like it is a 70's frame unless somebody did a SAS. It also looks like the the body doesn't quite line up.
fordlovinfarmer is offline   Reply With Quote
Old July 29th, 2008, 07:06 PM   #3
sufferingant
I believe you are correct. Where do you think I could find parts for this 400 engine?
Old July 29th, 2008, 07:58 PM   #4
TurdBronco
You should be able to buy parts anywhere for it.
The carb should be a basic motorcraft 2150 2 barrel.
Old July 29th, 2008, 08:02 PM   #5
MISHOWJEEPER
NSFW
MISHOWJEEPER's Avatar
How much for the bed?
MISHOWJEEPER is offline   Reply With Quote
Old July 29th, 2008, 08:02 PM   #6
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
most places should carry stuff Jeff's Bronco Graveyard should have motor parts, other than that i would say NAPA
Bronco351 is offline   Reply With Quote
Old July 29th, 2008, 09:21 PM   #7
sufferingant
Cool, thanks guys! I'll check around and see what I can do. I know a thing or two about cars, but I'm used to working on fuel-injected fwd four bangers
Old July 29th, 2008, 09:37 PM   #8
sufferingant
Oh, and if I was going to fit this truck with a plow, I'd have to get a late 70's Bronco plow, correct? If so, is there a good place to find a used plow? I'm going to try to Craigslist one.
Basically, what plows will fit on this truck if it's a late 70's bronco frame and an '84 F150 body? Thanks
Old July 30th, 2008, 03:14 PM   #9
oilburner350
oilburner350's Avatar
Going by the VIN nummber that truck was 2wd when it started it's life in a Canadian factory.
oilburner350 is offline   Reply With Quote
Old August 6th, 2008, 09:36 PM   #10
sufferingant
Here are some engine bay shots, feel free to chime in and tell me anything you know about it, and/or if it's a worthy build to keep :)
Old August 6th, 2008, 10:59 PM   #11
blownexploder94
Todd
blownexploder94's Avatar
i would just throw a new intake on it like an edelbrock intake and put a 4 barrel carb on it... but even just your carb summit can get
Old August 6th, 2008, 11:00 PM   #12
blownexploder94
Todd
my brother might even have the old 2 barrel off his 78 ill do some digging
Old August 6th, 2008, 11:04 PM   #13
sufferingant
Yeah, the carb is going to run me about $329.95 + shipping from Summit.
http://store.summitracing.com/partde...5&autoview=sku
Old August 6th, 2008, 11:08 PM   #14
sufferingant
Alright, thanks! I guess my dad tried a holley rebuild kit on it, but it never ran right. He had to retard the timing to start it, then put it back to normal once it started.
Old August 7th, 2008, 03:11 AM   #15
88mudder
In the band!
check your fuel pump pressure
Old August 7th, 2008, 07:35 AM   #16
oilburner350
I would check the distributer. I had a 360 that I had to do that with. The mechanical advance was stuck and I was too lazy to fix it.
Old August 7th, 2008, 11:51 AM   #17
caveman
GeoDude
caveman's Avatar
buy this stuff, http://www.greatlakes4x4.com/showthread.php?t=89862, i'll give ya a holley that should be easy to rebuild, keep the rest for spare parts or sell what ya don't want
Old August 24th, 2008, 08:58 PM   #18
75v8cj
Just 1 ques. If that is a 400, why is the dipstick by the coil? Every 400/351m I have seen is drivers side.
75v8cj is offline   Reply With Quote
Old August 24th, 2008, 09:07 PM   #19
sufferingant
Your guess is as good as (likely better than) mine. Is there any way I can tell the difference?
Old August 25th, 2008, 03:09 PM   #20
bj house
bj house's Avatar
I have had several 351M's and the dipstick was in the exact location that your picture shows.
Page generated in 0.35267 seconds with 83 queries
