WTF did I do Wrong with video - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2008, 11:46 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default WTF did I do Wrong with video
Just rebuild the motor, Won't start and sounds weird when turning over. No loud noises just not right and it won't even try to fire. I think I might have timed it 180 0ff. Here is a video.
Old July 28th, 2008, 11:58 PM   #2
bigcountrysg
Countryboy
bigcountrysg's Avatar
If you are 180 off on your timing you would still have popping. As the engine would be trying to fire and sending the exhaust through the intake.
To me it sounds like your not getting any type of firing from the cylinders. Is this fuel injected or carburated.
bigcountrysg is offline   Reply With Quote
Old July 29th, 2008, 12:07 AM   #3
booblinker
Sore and Tired 24/7
booblinker's Avatar
F.i.
Old July 29th, 2008, 12:08 AM   #4
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
is it getting spark? fuel? double check you timing.
Old July 29th, 2008, 12:13 AM   #5
junk90xj
ALLPRO AUTO
junk90xj's Avatar
what motor and x2 on do you have spark?
also what about injector pulse. is the crank sensor or cam sensor hooked up.
i would be looking at the electrical as its really easy to forget to plug somthing together.
http://www.apalansing.com/
Old July 29th, 2008, 12:20 AM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
I'm gonna check all the connections tomorrow, but it just doesn't sound right when it is turning over.
Old July 29th, 2008, 12:23 AM   #7
bigcountrysg
Countryboy
It doesn't sound like your getting any type of spark at all. I have to say it is related to ignition and not timing. Could be fuel related as well. But need more info to determine that. Does it smell like it is flooding out. Are the spark plugs wet.
Old July 29th, 2008, 12:33 AM   #8
booblinker
Sore and Tired 24/7
booblinker's Avatar
Forgot to connect the crank sensor, runs now, just makes a whirring noise, I think the timing belt is rubbing, I hope that's it.
Page generated in 0.21517 seconds with 47 queries
