IFS Lift and Tires - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 15th, 2005, 11:00 PM   #1
KetteringRedneck
KetteringRedneck's Avatar
Send a message via AIM to KetteringRedneck
Default IFS Lift and Tires
I have a question for those of you out there who may be running an IFS lift. Yes, I know IFS isn't the greatest option for a lift but I get a good discount on Rancho lifts and I got an IFS Chevy for free. So I am gonna stick with the IFS.
That being said, does somebody have some experience on how big of a tire can be run on a IFS lift of say 4-6 inches before having to worry about puting the suspension components at risk? I have read 35 is as large as you should go, but then I know a guy who swears up and down that 33 is as large as you can go. 35s may give me clearance issues but I am more interested in what the increased risk may be in running a 35 instead of a 33. Is it nothing to worry about or does that extra 2 inches of tire really spell bad news for an IFS?
Thanks for any help.
KetteringRedneck is offline   Reply With Quote
Old November 15th, 2005, 11:40 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Do a front axle swap.
Old November 16th, 2005, 12:53 AM   #3
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I take its a 1/2 ton. I have a few buddies that I have wheeled with in the past with IFS 1/2tons. One running a 4-6" Skyjacker w/35" Thornbirds. The other a 6" ProComp with 35" Boggers. Both have had nothin' but problems with cv shaft, ball joints, tie rods, and idler arms. They would have to change parts after every trip. Most of the time is was a warrantied part, but still the pain of breaking and changing things sucks.
One guy gave up on wheelin, he could stand to put money into his Chevy anymore after a trailride. Now he just wheels during hunting season. The other Chevy has sat for 6 mos...same thing guy is tired of fixing it.
Old November 16th, 2005, 01:56 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I have done a ton of IFS lifts on the chevy's. 6" is the minimum to run 35's and still be able to wheel happily. It would get by as a DD
I had to use 3/4 tortion bars with the 6" dick cepec lift to run 35's comfortably on a customers truck.
Old November 17th, 2005, 06:47 PM   #5
Mclovin
"The Situation"
Mclovin's Avatar
i would not go any bigger than a 35.. but u know it wouldnt be that hard to stick a dana 44 or 60 under the front of that rig ?
Old November 17th, 2005, 06:58 PM   #6
KetteringRedneck
There are a few reasons I am sticking with the IFS setup. The first being this isn't going to end up being my dedicated off-road truck. The worst this will see is some mild trails and mud bogs. So I wanna keep the IFS for the improved road manners. The company I work for is the parent company of Rancho, so I get 50% off all kits. I looked into a solid axle swap and it would just be a lot more work and money.
I am eventually going to get something else to do some hard wheeling with. Right now I commute about 100 miles a day total to get to work, so a full-size daily driver isn't the best idea for mpg. So this is gonna be my second vehicle and be for lumber yard trips, trips up north hauling my atv and camper (when I buy one), etc. Down the road I will get something with a solid front axle to beat up off-road.
Basically the question comes from the fact that I had this guy tell me that 35s will cause suspension failure and to run 33s because he knew a guy who broke stuff on 35s. My contention was that 2 inches of tire didn't cause the failure, wheeling IFS like you would a SFA truck more likely was the reason he broke parts.
35s seem like they are gonna be a problem unless I trim up the fenders so I will probably go with 33s.
Some day I will get a K5 Blazer to really beat hard off-road.
Old November 17th, 2005, 08:37 PM   #7
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Wow 100 mile a day commute and you want a fullsize on 35's to commute with? You and the gas companies will eventaully be best friends.
Old November 17th, 2005, 10:27 PM   #8
KetteringRedneck
HA, thats what I get for writing a post and making dinner at the same time. I was trying to say this is gonna be my second vehicle because I have a smaller more fuel efficient vehicle as my daily driver.
Sorry about that.
Old November 17th, 2005, 10:31 PM   #9
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Ah, that does make more sense........for your pocket book
Old November 17th, 2005, 11:19 PM   #10
Mclovin
"The Situation"
Mclovin's Avatar
you could run 33's on fullsize IFS parts all day long !
Old November 18th, 2005, 12:00 AM   #11
Tonka
Tonka's Avatar
3" body clears 33's on stock rims
my roommate runs that on a 97 ext. cab chevy short bed 4x4
DON'T crank the torsion bars!!!!!!!!!!!
it will wear everything steering related, and the cv's fast!
Old November 18th, 2005, 12:42 AM   #12
Mclovin
"The Situation"
Mclovin's Avatar
Ditto !!! I can vouch for it personally !!! i woldnt even go more than 1/2 turn !
Old November 18th, 2005, 07:28 AM   #13
mrclean
Silver Lake
mrclean's Avatar
I run a 92 Gmc with 9" of lift and 38.5's. Had good luck with it so far and it drives great. just my .02!
mrclean is offline   Reply With Quote
Old November 19th, 2005, 08:08 PM   #14
Tonka
Tonka's Avatar
isn't yours a 2500?
Old November 21st, 2005, 08:56 AM   #15
mrclean
Silver Lake
mrclean's Avatar
isn't yours a 2500?
oh yea :miff:
Page generated in 0.24985 seconds with 68 queries
