just seized the motor...have some questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 27th, 2008, 04:57 PM   #1
stevelknievel
Fuck Cancer
stevelknievel's Avatar
Send a message via AIM to stevelknievel
Default just seized the motor...have some questions
ok my 125 just seized and it obviously needs a top end. when replacing the top end you just pull off the head, pull the cylinder, and replace the piston, pin, bearing, and rings correct?
with my motor seizing up is my cylinder gonna need to be machined?
stevelknievel is offline   Reply With Quote
Old July 27th, 2008, 06:33 PM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I am thinking you have the electroplated cylinder, so you can't machine it. Hopefully it survived teh seize.
Do you know why it seized? I would be sure to know why it happened so you don't replace the parts and have it happen again.
Sorry to hear your bike died.
@clarkstoncracker
Old July 27th, 2008, 07:41 PM   #3
stevelknievel
Fuck Cancer
i believe it is plated. im not sure why. its ran fine all week on the same tank of gas. ive been running 32:1 mix exactly. i just started it today to play around on a little and as i was heading back to the house i heard a little rattle noise then just seized up.
PS. i may take you up on your offer to borrow those case splitting tools sooner than i expected lol
Old July 28th, 2008, 09:19 PM   #4
newdodge
jeep life
newdodge's Avatar
piston pin went out my cr 250 did that little rattle noise then just seized up. come to find out i was running my oil mix to len got to hot
newdodge is offline   Reply With Quote
Old July 28th, 2008, 09:32 PM   #5
stevelknievel
Fuck Cancer
well im hoping thats whats happened. what mix were you running? ive been running 32:1
Old July 29th, 2008, 06:20 AM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Pull your plug and tell me what it looks like.
@clarkstoncracker
Old July 29th, 2008, 08:49 PM   #7
stevelknievel
Fuck Cancer
ill pull it as soon as this dodge is gone
Old July 29th, 2008, 09:37 PM   #8
kickstand
circling the drain
kickstand's Avatar
The more oil you run, the leaner you are running your motor, oil is not gas, make sure you did not run it lean. Isn't 32:1 kinda fat on the oil side?
Lotsa reasons it could have stuck.....
Old July 29th, 2008, 10:02 PM   #9
stevelknievel
Fuck Cancer
hmm sounds like i need to change my ratio
thanks man
Old July 29th, 2008, 10:08 PM   #10
jeepguy74
jeepguy74's Avatar
what oil are you running i run klotz or belray and run it one bottle to 5 gal of gas its like 40 to 1 never and i mean never had a prob with any bike even running in the middle of winter
i would doubt though that it is the oil but more like your case problem prolly got worse and shcked air and ran lean
Old July 30th, 2008, 06:39 AM   #11
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I believe 32:1 is the ratio recommended by Kawasaki, and honestly, the difference in the fuel content from 32:1 to say, 50:1 isn't enough for a seize.
I'm thinking the stator-side crankshaft seal failed or there's a (big) leak in the carb boot.
@clarkstoncracker
Old July 30th, 2008, 10:10 AM   #12
jeepguy74
jeepguy74's Avatar
yea but 32 t 1 is so ritch ....if you read the recomdations on the oil it is mix a bottle of oil to 5 cal and thats what most people do .....i wasnt saying that it was oil that caused the problem i was just stating that is what i was running with no problems .....i too also believe that there is a air leak somewhere that caused the problem like case seals carb boot or crank seals i would also clean the carb to rule out a clogged jet
Page generated in 0.29998 seconds with 59 queries
