welding aluminum - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 27th, 2008, 03:41 PM   #1
JUSS10
4given4x4.com
JUSS10's Avatar
Default welding aluminum
alright, i punched a small hole in my engine side cover the other night when i dumped my bike. i have a small 220 Hobart wire welder that has the ability to weld aluminum granted a change out the wire and gas. my question is this. if i get the right wire can i use my 75/25 tank of argon or do i need 100% argon like the welder says. i just need to fit a small hole approx .25"x.75".
JUSS10 is offline   Reply With Quote
Old July 27th, 2008, 03:59 PM   #2
JK4x4
JK4x4's Avatar
you will need the argon!
JK4x4 is offline   Reply With Quote
Old July 27th, 2008, 04:01 PM   #3
JUSS10
4given4x4.com
JUSS10's Avatar
thanks. found out a spool of wire is nearly $20 anyways. I'm hoping the local metal shop can do it for less than that.
Old July 27th, 2008, 05:15 PM   #4
CreativeFab
used to be Ironman
CreativeFab's Avatar
If the local welding shop does it for under $20 I am closing my doors and taking everything there. Except for the drive, it will be be worth it.
Old July 27th, 2008, 05:26 PM   #5
JUSS10
4given4x4.com
JUSS10's Avatar
really? to fill a hole? i dont want it to look good i just want to fill the hole. if its more then that, i guess I'll just wait till my new cover shows.
Old July 27th, 2008, 05:55 PM   #6
firehawk
Live Action!
firehawk's Avatar
JB Weld?
Old July 27th, 2008, 09:35 PM   #7
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
My welder is set up with 4043 wire and the full argon tank right now........was planning on changing it over to steel wire next weekend. If you can get it up here, I can probably patch it for you before I make the switch....................that is if this other place doesn't work out for you.
Old July 27th, 2008, 09:44 PM   #8
JUSS10
4given4x4.com
JUSS10's Avatar
well i found a jb weld that is suppose to work for oil pans and gas tanks so i gave that a try and it seems to be holding up well. i'm hoping the guy on ebay that I'm getting the replacement cover from will get back to me so i can just get a new one. thanks for the offer. if stuff falls through i may still be willing to swing that way to fix it. guess i would have to factor in gas, like everything in life now a days.
Old July 27th, 2008, 10:21 PM   #9
FORD FLARESIDE
Gas would be your only cost, I don't charge anymore for repairs.
Just trying to help a Brother out.
Old July 27th, 2008, 11:51 PM   #10
scotte
i'm in zeeland and can weld aluminum (tig)
scotte is offline   Reply With Quote
Page generated in 0.21743 seconds with 53 queries
