Ram v4.5 - updated 4/19/07 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 10th, 2006, 09:36 AM   #21
PavementPounder
PavementPounder's Avatar
The 241HD has now been installed. During that job it was discovered that the Skyjacker clocking ring was already in there. :tonka: Unfortunately, nothing else can be done with it at this time and I'm going with the new front driveshaft. The 241HD has a different shift pattern, but it works with my 98's shift lever and the interior didn't have to be disturbed. All the related parts were secured from the donor vehicle, so we just popped the shift pattern cap off the knob and replaced it with the other one.
Old May 12th, 2006, 09:39 PM   #22
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Is it at Koz's again? I talked to him a couple weeks ago about your Ram.
Old May 12th, 2006, 11:56 PM   #23
PavementPounder
Yes, it was. The 241 was making bad noises and the cost to repair it would have been close to that of the upgrade. I'll get the bearing replaced later and then have a spare case.
Old May 13th, 2006, 01:59 PM   #24
Blackbeast2
Hardcore since 84
Thats one of the looking rams I have seen.
Blackbeast2 is offline   Reply With Quote
Old May 15th, 2006, 09:16 AM   #25
PavementPounder
Brought it home on Saturday. The 241DHD is working nicely, but it has changed the range of movement of the shifter due to the linkage rod being a different length. The shifter is rotated too far forward in the cab now, so I'll have to have a longer one fab'd to being it back upright. The shifter trim can't be installed with the lever at its current angle. The new rear output is quite a bit larger than the 241DLD.
Have lots of other issues to work on now that the truck can be driven again. When the lift was installed, two of the exhaust hangers that existed on the drivetrain crossmember were eliminated. As a result, there is increased weight at the manifold that has started a leak, most likely stretching the studs. The pipes also flex way too much now and make lots of noise above 45mph. I still have the rubber isolators, so a couple new hangers welded to the new crossmember should solve the problem. I'd really like to go to headers along with the new exhaust, but the manifold bolts look pretty scary.
I'm sure a few would break off. I'm just going to get some new studs in the manifolds to stop the leaks for now and weld braces between the pipes to keep them from rattling while I address other mechanical issues. I need to put in some better plugs for the long-term, install the Viper ignition wires, replace a few sensors to get the speedo/odometer/ABS working again, and play musical tires/rims this week to swap the MT/R's onto the Ram rims for street driving and the Nittos onto the H2's I picked up.
Old December 20th, 2006, 04:11 PM   #26
2003ranger
2003ranger's Avatar
Send a message via AIM to 2003ranger
Bad Ass Looking Truck!
2003ranger is offline   Reply With Quote
Old December 20th, 2006, 04:25 PM   #27
bigtruckman
One shot, One Kill
bigtruckman's Avatar
Any updated photos of this truck??? It looks like it will be very nice with the bigger tires on it. BTM.
bigtruckman is offline   Reply With Quote
Old December 20th, 2006, 06:49 PM   #28
PavementPounder
I've been waiting on someone who has some 40" MT/R's since I drive it on the street frequently, but I am considering springing for some aggressive rubber depending on how the holidays go.
Old December 20th, 2006, 10:19 PM   #29
Grandman
do i look old !
Grandman's Avatar
You leave me wondering how large of tire i could put under the 3500 dually . Damn fenders openings are big in these trucks .
Your truck looks good , v 10 is a strong motor but does it sound like crap ? Mine did with duals on it .
Old December 20th, 2006, 11:01 PM   #30
PavementPounder
We addressed this here previously. I believe what we ended up with was that you sounded like crap.
The bigger the muffler chamber, the better it sounds. I've gotten accustomed to it, but the small 2-in-2-out that's on it now has a higher pitch than what I would really prefer. It'll improve when the headers go on and the pipes are changed.
As for the tires, larger than 40 would probably fit for driving, but I prefer to allow for full flex.
Old December 20th, 2006, 11:42 PM   #31
dune coon
do work
dune coon's Avatar
x 2
dune coon is offline   Reply With Quote
Old December 21st, 2006, 12:07 AM   #32
boggin-machine
boggin-machine's Avatar
when you put headers on there if the manifold bolts snap or break off in the block most of the time its in the middle so you can still get a good pair of vise grips in there to twist them out... eather that or jsut cut all the heads off with a torch and then just pull the manifold off and twist the studs out with vise grips....
great looking truck pp.... badass rig no dought about it
Old December 21st, 2006, 07:07 AM   #33
PavementPounder
How many Dodge V10's have you actually worked on?
Old March 7th, 2007, 09:36 AM   #34
PavementPounder
Uh-oh.
Bought 40's last night.
Old March 7th, 2007, 09:52 AM   #35
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Wpwp
Old March 7th, 2007, 09:56 AM   #36
PavementPounder
Originally Posted by 99grandtj View Post
Wpwp
I was too tired and it was too cold to even unload them from the Suburban last night, so you and your pics.
Old March 7th, 2007, 10:02 AM   #37
Jeepaholic
Jeepaholic's Avatar
That is fine I just wanted to know what you got, but your for sale post solved that.
Old April 16th, 2007, 11:11 AM   #38
PavementPounder
Installed the new unit bearing assemblies this weekend and the 40's are now on. Looks much more in proportion. I'll have a new pic up soon.
Old April 17th, 2007, 09:41 AM   #39
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Waiting.....
Old April 17th, 2007, 10:10 AM   #40
roll-bar Bob
roll-bar Bob's Avatar
Originally Posted by GreaseMonkey View Post
Waiting.....
X2
Page generated in 0.38606 seconds with 83 queries
