TJ Check Gages light - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech > Jeep tech FAQ
Jeep tech FAQ Look here first!
Old July 25th, 2008, 07:47 PM   #1
rocibrky
Default TJ Check Gages light
I have a 97 Wrangler 5 spd 4.0. As I was driving today the speedometer shot up to 100 mph and then dropped back to the speed I was driving (40mph). This happened a couple of times and then the check gages light came on and the volt gage dropped to 9 volts and stayed there until I turned off the engine and restarted. After I started the Jeep again the check gages light was off and the volt gage went up to 12 volts. I took it for a test drive and the the problem occured again. A couple months again I had a puddle of coolant under the Jeep and when I started it the check gages light came on and the volt gage dropped to 9 volts. I had the alternator checked at Autozone when I bought my new water pump and it checked out fine and it hasnt been a problem until now. Please give me your thoughts on what to look for and possible causes. Thank you!!
rocibrky is offline   Reply With Quote
Page generated in 0.18303 seconds with 26 queries
