Towin with e85? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2008, 12:28 AM   #1
Gunsworth
Gunsworth's Avatar
Default Towin with e85?
We just turned in our 06 150 for an 08 (it has the e85 gas cap so I assume it takes it, my dad that leased it has no idea wtf e85 is)
Anyways how is it for towing a trailored jeep in comparison to the 06 super-duty I normally use?
Old August 11th, 2008, 01:44 PM   #2
firecat
firecat's Avatar
I would run 89 mid-grade, not E85 for towing. E85 produces less hp and mileage than regular or midgrade, and the lower price doesn't offset the difference. Unloaded expect 20% less mpg, I don't know about loaded.
firecat is offline   Reply With Quote
Old August 11th, 2008, 02:41 PM   #3
Bones
Bones's Avatar
just run 87 towing, no need for 89
how much weight are you towing?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 23rd, 2008, 04:07 AM   #4
2kids=nojeepmoney
my wifes commander 4.7l V8 gets the same mileage on E85 as with 87.... i heard there was a big difference, too, but we've run 50+ tanks through it and the milage is the same (give or take a tenth or two)
2kids=nojeepmoney is offline   Reply With Quote
Old August 25th, 2008, 11:38 PM   #5
FAS4DOR
FAS4DOR's Avatar
True story, same as a buddies E85 08 Silverado. It gets the same mileage between E85 and 87
FAS4DOR is offline   Reply With Quote
Old August 25th, 2008, 11:40 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
E85 has more octane :)
Old August 26th, 2008, 10:47 AM   #7
scottie
Eye candy
scottie's Avatar
it also isn't as efficient. I'd tow with real gas, not corn squeezin's
and for those of you that say you get the same with E85 as with 87, that may be possible, because i've heard rumors of stations selling E20 and not actually telling you. (which is illegal, kind of like the whole gallon vs slightly less)
Old August 26th, 2008, 11:24 AM   #8
Bones
Bones's Avatar
you have no experience towing
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 28th, 2008, 11:44 AM   #9
MudOnTheTires
MudOnTheTires's Avatar
I tow my jeep with my 02 1/2 ton burban and I use e85 whenever I get the chance. I can't notice any difference power wise. As for fuel mileage, I lose about 1-2mpg depending on the mix of city vs. highway.
There is an e85 station on the way to the wheelin spot so more times than not I run it.
-Sean
MudOnTheTires is offline   Reply With Quote
Old August 28th, 2008, 11:54 AM   #10
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Is it safe to run E85 in the older engines?
Old August 28th, 2008, 12:05 PM   #11
greygoose
I'm the dude
greygoose's Avatar
Why do people keep asking this?
No, it is not safe. You must run regular old gasoline if your vehicle doesn't specifically say E85 capable.
Old August 28th, 2008, 12:05 PM   #12
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
http://www.autobloggreen.com/2007/08...y-car-use-e85/
Don't try this! We mean it. DO NOT TRY THIS! The American Coalition for Ethanol ran a 2000 Chevy Tahoe, not a flex-fuel vehicle, exclusively on E85 for 100,000 miles. Then they stripped down the engine and took a look. Everything looked fine. Fuel lines, fuel pumps, etc. In fact, they say a few things looked better than normal. The video includes a look at the parts of the engine from that Tahoe.
Again, DO NOT TRY THIS but car companies know they must comply with small percentage blends of ethanol. So most cars made since the early '90s can handle ethanol. The only problem is that non flex-fuel vehicles don't have the sensors necessary to detect ethanol content. They also don't have the control software to manage the air fuel mixture properly. So your car might run on E85, it just won't run well. It could also cause major damage and using E85 usually voids your warranty. So that's why you should not try it.
This leads to an interesting potential. What if a private or public group went to car manufacturers or did tests on their own to find out which cars could withstand E85? Then this was made available to the public. This would be great for the ethanol market. Many people think ethanol is bad because it's more polluting and less efficient. The creation of a mild or soft flex fuel standard won't make them happy.
from http://www.e85fuel.com/e85101/faqs/anycar.php
The Energy Policy Act of 1992 also recognizes E85 (a blend of 85% ethanol and 15% unleaded gasoline) as an alternative fuel. In order to operate on E85, vehicles need to be compatible with alcohol use. The conversion cost to make FFVs compatible with E85 typically includes upgrades to the fuel system components, the addition of a fuel sensor, and reprogramming the EPOM (computer chip) in the ECM/PCM (electronic control module/power train control module).
Old August 28th, 2008, 12:14 PM   #13
Ridin Dirty
Sorry. I asked because I didn't know the answer.
Old August 28th, 2008, 12:43 PM   #14
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
i am glad you asked becuz i was going to!! iwas wondering because the station by my house now sells e85 for $2.99 / gal. i was going to try running it in my 94 f250 wood hauler, i dont know though, it gets like 8 miles to the gallon if it would be worth it.
jeepster95 is offline   Reply With Quote
Old August 28th, 2008, 12:51 PM   #15
Ridin Dirty
Yeah, I didn't know. Apparently it has been discussed before but I never saw it so when I saw that mudonthetires said he was running it in a 02 it made wonder so I asked. Oh well. I saw that at the station you must be talking about. Got diesel there for $3.96 the other day.
Old August 28th, 2008, 12:54 PM   #16
greygoose
I'm the dude
greygoose's Avatar
If your vehicle is not setup to run E85, you COULD cause serious damage. In my humble opinion, I would never run E85 in a vehicle that isn't specifically designed for it... .02
Old August 28th, 2008, 04:21 PM   #17
firecat
firecat's Avatar
My mom's 07 Grand Cherokee 4.7 gets 12 with E85 and 17 with regular 87. Both are long-term averages, several consecutive fill-ups.
Current engines are not designed to take advantage of E85's high octane rating. The compression ratio is a compromise since you can run regular or E85.
High Octane Does NOT equal performance or economy, just that it helps high-performance engines perform best.
Old August 28th, 2008, 05:51 PM   #18
scottie
Eye candy
scottie's Avatar
TOwing with underpowered Pieces of shit is experience
Old August 28th, 2008, 08:08 PM   #19
2kids=nojeepmoney
there's nothing funnier than watching people put premium in their new car (or their '86 Cavalier) "to help keep it clean" or "for better performance"
Page generated in 0.38180 seconds with 80 queries
