Name that part - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2008, 07:29 PM   #1
Snowman43
Snowman43's Avatar
Default Name that part
Having trouble finding out what Ford calls this part, in my opinion it is a TCM but doesn't appear to be called that. Control Module of some sort, TV cable runs into it.
On a '93 Lincoln Mark VIII if it matters.
Thanks in advance,
Brian
Snowman43 is offline   Reply With Quote
Old July 21st, 2008, 07:36 PM   #2
blownexploder94
Todd
blownexploder94's Avatar
part of the cruise control ?
Old July 21st, 2008, 07:59 PM   #3
curt1656
Praise the lowered
curt1656's Avatar
Flux capacitor.
Old July 21st, 2008, 08:00 PM   #4
Ready4Wheelin
Ready4Wheelin's Avatar
Originally Posted by curt1656 View Post
Flux capacitor.
Damn, beat me to it.
Ready4Wheelin is offline   Reply With Quote
Old July 21st, 2008, 08:17 PM   #5
Snowman43
Snowman43's Avatar
Flux capacitor.
If that's the case I am not getting the required 1.21 Gigawatts
Shouldn't have anything to do with cruise, I think it controls the auto trans kickdown, shift points determined by throttle position.
Old July 22nd, 2008, 11:33 AM   #6
blownexploder94
Todd
where does the other end of the cable run to..... looked on aldata and mitchel earleir today the only thing it shows up there that looks similiar is called air suspension/ EVO or steering module
Old July 22nd, 2008, 11:42 AM   #7
Bratworst
Bratworst's Avatar
I still think is looks like a cruise control actuator.
Could always unplug it and see what doesn't work!
Bratworst is offline   Reply With Quote
Old July 22nd, 2008, 11:44 AM   #8
blownexploder94
Todd
thats what i thought looks just like one .... just dunno what its plugged into. it doesn;t make sense for a trans kick down to be way over there. and fords normal the kick down on the trans is driver side mounted thats on passenger side
Old July 22nd, 2008, 11:49 AM   #9
Flexin' XJ
Flexin' XJ's Avatar
Probably the hold in cable for the throttle. Not the TV cable.
Flexin' XJ is offline   Reply With Quote
Old July 22nd, 2008, 11:51 AM   #10
buddha
playing life by 'ear'
buddha's Avatar
there aren't any numbers/letters on it?
i.e. E3.....
good old ford part numbers...
buddha is offline   Reply With Quote
Old July 22nd, 2008, 11:54 AM   #11
blownexploder94
Todd
deffinitly looks like there are numbers on it from the pic and on the sticker
Old July 22nd, 2008, 06:08 PM   #12
Snowman43
Snowman43's Avatar
I guess this is the part of the thread when I have to admit I'm a dumbass... Yeah, it's the cruise control module. Back to square one.
Old July 22nd, 2008, 06:13 PM   #13
Freak
Wheelin the HD
Freak's Avatar
should have admitted that when you said "TV cable" unless you have your Lincoln all tricked out with h8ter vision....
Old July 22nd, 2008, 09:02 PM   #14
Bones
Bones's Avatar
93 is full electronic... ie not a kickdown cable.
I would also guess cruise. Where do the cables come from and go to?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 22nd, 2008, 09:04 PM   #15
blownexploder94
Todd
he got it figured out
Old July 22nd, 2008, 10:00 PM   #16
Freak
Wheelin the HD
Freak's Avatar
he didn't get the problem figured out, just the name of the part.
Old July 22nd, 2008, 10:02 PM   #17
blownexploder94
Todd
Thats all that his question was. just asking what the part is
Old July 28th, 2008, 12:21 PM   #18
Snowman43
Snowman43's Avatar
I did actually get the car fixed. Once I got past my initial wrong direction I started digging into it, found someone had unhooked the IAC (or at least what I think is Idle Air..), I reconnected it and that made the car idle about 2000 RPM's. Coulple that and the high shift points and having to let off the gas to get it to shift, traced it down to a TPS. Changed out the sensor, put it back together and it shifts perfectly.
Thanks to all for trying to help me out,
Brian
Page generated in 0.38871 seconds with 77 queries
