3 cylinders not firing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2008, 09:31 AM   #1
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
Default 3 cylinders not firing
Had the boat out 2 weekends ago and after about an hour of running, it all of a sudden sounded different and lost a ton of power. Couldn't get the RPMs up and it wouldn't get up on plane.
I went out and bought 6 spark plug testers (the inline light up kind) and all 3 cylinders on the left side are not firing. The 3 on the right appear to be fine. I traced the wires up to the box that is labeled as the "power pack" by the diagrams I have been looking at here http://www.evinrude.com/en-US/Access...htm?popup=true. Each cylinder has its own coil pack, but I doubt all 3 of them went bad at the same time on the same side.
Any ideas on which part could be bad before I start digging in? Is it the actual power pack or a part that sends the pulses (timing)? each part os like $300.
Thanks!
87'YJ is offline   Reply With Quote
Old July 21st, 2008, 10:05 AM   #2
deuce228
Redneck Poser
deuce228's Avatar
FWIW your link doesn't work.
Wouldn't there be a Ignition module of some sort that tells the coils to fire?
Old July 21st, 2008, 10:08 AM   #3
87'YJ
87'YJ's Avatar
That seems to be what this "power pack" is. Try the link again.
Page generated in 0.28686 seconds with 32 queries
