55 willys pickup - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 18th, 2009, 08:49 AM   #21
jeepers48
jeepers48's Avatar
I finally finished my steering upgrade. No more, 9:00 to 5:00 slop in the steering wheel. I fab'd it some what like what would be found on a TJ frame.
I used a steering column from a 94? XJ. I cut the mount off the end of the tube and welded my own tabs on to the end of the tube and bolted the column to the floor. The fun will be wiring everything up.
jeepers48 is offline   Reply With Quote
Old August 18th, 2009, 09:26 AM   #22
jeepers48
jeepers48's Avatar
Forgot to mention the front end. I lengthened the frame by about 4" so i could use wrangler YJ springs and out boarded the springs to 32" C to C. Ill be running with a Ford HD D44 up front but for now im using a HP30(big U-joints) from a 94 XJ.
Old August 18th, 2009, 11:33 AM   #23
stinkpickle
bitter clinger
stinkpickle's Avatar
looking good. keep it up.
stinkpickle is offline   Reply With Quote
Old April 9th, 2010, 07:45 PM   #24
jeepers48
jeepers48's Avatar
I finally found a set of "old School wheels for the Willys, A set of faded Turbine style wheels 10 X 15's. Im looking forward to getting them sand blasted and Powder Coated.
I also got around to swapping in a Ford 9" rear and the front HD D44 is ready to put in as soon as I get around to pulling the HP D30 out.
Old April 9th, 2010, 09:24 PM   #25
gladiator18
66' Gladiator
gladiator18's Avatar
looking good, like the wheels
gladiator18 is offline   Reply With Quote
Old May 28th, 2010, 02:09 AM   #26
Dean
Default willys pickup truck
hi every one, I m restoring a Willys pick up truck.
when i bought it, it just has the front cabin but not the rear pickup part.
so can anyone please give me the dimensions for the rear portion.
thanks
Dean
Dean is offline   Reply With Quote
Old May 28th, 2010, 08:07 AM   #27
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
thanks
Dean
you can try to find a bed locally or these guys have used west coast parts as well as brand new
http://www.willysamerica.com/
Old May 28th, 2010, 08:32 AM   #28
jeepers48
jeepers48's Avatar
I finally got the F250 D44 hooked up, steering done, brakes bleed. For now there's just minor stuff to be done, front shackles, shock upgrade. Here's the latest pics.
thanks
Dean
Ill get some dimensions and pm you some other info.
Old May 28th, 2010, 08:38 AM   #29
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Looks like the width turned out pretty good to match the rear.
Looking good
Old May 28th, 2010, 08:51 PM   #30
jeepers48
jeepers48's Avatar
Looking good
"THX" to "YOU"!!! Thx for narrowing the front D44 Adam and advice too. I used the Grand waggy linkage and found an old neighor that had the tapered reamer I needed so I could flip the tie-rod linkage over and then ream the linkage that goes to the pitman arm.
Now I can start gathering parts so I can swap in either my Brothers motor/1969 351W or throw a crank into my amc401. Both motors need the same amount of input/time/money/more....money/more.....time.??!
Maybe I should skip that for now and raise the garage door header so I dont have to pull the wheels off every time I want to put the willys back into the garage?
Old June 1st, 2010, 03:21 PM   #31
bigwalton
Postal Scrambler
bigwalton's Avatar
One of my dream rides.... someday!
Love the look of it, love the rims. Doesn't look like you did anything to the rims? I'd have left them like you got them, it goes with the paint. I love the "patina" look of good old paint.
bigwalton is offline   Reply With Quote
Old June 1st, 2010, 11:37 PM   #32
jeepers48
jeepers48's Avatar
All I did to the rims was to scuff the fins with a scotch bright pad to add a dull shine so they stand out more. My plans were to have them sand blasted and powder coated a dull black or charcoal grey. The rims can wait. Im lining parts up to get a motor in it within this month or next month.
Some of the sheet metal/fenders, has stress cracks about an inch long that need to get welded up, no big deal except ill have to make up a batch of mud/paint to blend in with the rest of the faded, peeling paint.
Old June 1st, 2010, 11:47 PM   #33
creeping death
I'm that guy.
creeping death's Avatar
i love your rig and would very much like to hump it.
Old June 1st, 2010, 11:55 PM   #34
redneck942
redneck942's Avatar
all i can say DANG!!!!!!!!!
redneck942 is offline   Reply With Quote
Old April 26th, 2011, 10:18 PM   #35
jeepers48
jeepers48's Avatar
Well heres the latest. The amc 360/temp motor I had under the hood of my willys sold so I could finish building my Amc 401. I should have the block back from getting bored .030 over, in a few days. This time, instead of 10:1 pistons im going with 8.9:1 pistons so I can run on reg pump gas. As it stands now i wont be using the other 401 thats already punched out, im debating on sellng it or keep it for a backup{if I ever can find a Gremlin to drop it into...}. Im hoping to drop the 401 into the willys within the next 2 weeks if not sooner.
Old April 27th, 2011, 08:34 AM   #36
joe_jeep
welfare wheeler
joe_jeep's Avatar
i have seen this willys up close while picking up some parts. its is very clean!
good choice on the 401, screw that 351 stuff. keep up the good work!
Old April 27th, 2011, 09:26 AM   #37
Quiefinator
go'til itsounds expensive
Way to go on the build .
x2 on Joe_Jeep's comment, this thing looks great in person
BTW, i needed that radiator back a few months ago, fit perfectly in my '79. Thanks again!
Old April 27th, 2011, 07:19 PM   #38
pistol pete
I do vinyl stickers
pistol pete's Avatar
theres nothing wrong with taking a vintage truck and putting a modern drivetrain in it to make it preform better. Why preserve it for the next guy? build it and enjoy it! Nice truck id love to own it.
pistol pete is offline   Reply With Quote
Old April 28th, 2011, 05:43 PM   #39
jeepers48
jeepers48's Avatar
Thx guys.
Old December 11th, 2011, 09:50 PM   #40
jeepers48
jeepers48's Avatar
Well, it has been a wee bit of time since my last update so heres some pics of what I did to the willys over this past summer, And this was while working 12 hour days, 7 days a week. Right now im off of work for 3 months because I just had hip replacement 3 weeks ago. I picked up a amc 401 from a close friend of mine for $200. sludge included for free.
I sent the block out to D&S in Clawson and had it dipped,bored, and pistons pressed to the connecting rods.
Heres the motor complete. Block bored .030 over, Reg pump gas 8.9 to1 Pistons, comp cam 280, and air gap manifold w/670 holley on top.
I finnally got to drop the motor and rebuilt 727 trans in on the 4th of July weekend.
Page generated in 0.72238 seconds with 84 queries
