TH350 vs 700R4... T-case adapters the same? (aftermarket ones) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 18th, 2008, 10:18 AM   #1
Default TH350 vs 700R4... T-case adapters the same? (aftermarket ones)
Basic question:
Can you use a (Novak) Dana 300 t-case adapter for a TH350 on a 700R4?
I think the 4 bolt adapter itself is identical, but not sure about the spud shaft....)
Old July 18th, 2008, 10:35 AM   #2
95geo
newbie
95geo's Avatar
I'm pretty sure you can since they both have 4 bolts on the back, as long as the output shafts are the same length.... I'm not positive though.
there is a factory adapter that came on the 700r4 and has the correct 6 bolt pattern on it you just have to open up one hole.
Old July 18th, 2008, 10:38 AM   #3
Well, I have a TH350 with a busted case. Already has the Novak Dana 300 adapter.
Just seeing if it would work on a 700R4 as well, since I have to find a replacement anyway...
Old July 18th, 2008, 10:40 AM   #4
Tom
Because racecar
Tom's Avatar
The 4 bolt adapters are the same. The output shafts are different.... so no.
Old July 18th, 2008, 11:43 AM   #5
Thats what I was thinking. Heard the 700R4 was a metric sized shaft..
thnx!
Old July 19th, 2008, 12:11 AM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
thnx!
no they are both 27 spline, but you can get an output shaft from AA for the 700r4. To make it bolt to any application a T350 was bolted to and have the same stick out from the back of the trans as a T350. With out having to use a 2" aluminum spacer.
Old July 19th, 2008, 08:35 AM   #7
I think I'm getting a late style 4L60e today... which I'll use a new adapter.
Old July 19th, 2008, 08:52 AM   #8
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
How much for the th350 adapter?
Page generated in 0.24063 seconds with 47 queries
