couple ?'s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 15th, 2008, 01:45 PM   #1
2fst4you
2fst4you's Avatar
Default couple ?'s
im getting a winch for a jeep wrangler tj 1998
how much does a wrangler weigh lbs wise??
and two im getting a 6000lb winch for free will that be enough rated line pull or do i need something bigger?? how big??
Old July 15th, 2008, 01:50 PM   #2
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Weighed my 97 TJ with dana 44's and 33" tires with aluminum wheels just last week at the gravel pit. It was 4,040 lbs. with me in it and 3/4 tank of gas. I am 190 lbs. That was with no top on it.
Old July 15th, 2008, 01:54 PM   #3
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
Gross Vehicle Weight x 1.5 = Minimum Rated Line Pull.
I also found this chart that'll help you find the weight of your TJ using your VIN #
http://www.jeepfan.com/tech/tech_vintj.htm
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old July 15th, 2008, 01:57 PM   #4
I wouldn't use a 6000# winch for a jeep for anything other than a rare emergency. Even then I would figure on snatch blocking it most of the time.
Old July 15th, 2008, 02:03 PM   #5
Bishop
Bishop's Avatar
8000# seems to be the most used. never really see anything lower than that on a tj.
thats what i have, however i have not had the chance to use it other than to pull me up a slight hill just for fun when it was first put on
Page generated in 0.18140 seconds with 38 queries
