B2 build up advise wanted - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 15th, 2008, 02:11 PM   #1
deathbypsi
Brian R.
deathbypsi's Avatar
Default B2 build up advise wanted
Hey guys, I have a 84 B2 I am slowly goin to turn into my new trail rig cuz my 99 Ranger just aint up to the job anymore. I am pullin most of my stuff off my Ranger for the B2 and will just daily drive the Ranger.
My B2 has a decent body and I just replaced all the floors. The motor and trans are Jasper remans with less than 6k on both so it runs like a champ....weak as hell but good runner anyway still pullin 18mpg.
I am lookin for some advice on what would be the best upgrades to do to my truck to make it a decent rig. I wont be doin any crazy mud bogs or runnin Moab anytime soon.I like to hit trails and the Mounds a few times a year so I just need it to survive places like that.No straight axle swaps or Dana60's.
So far I am planning on swapping my 16x8 Ultra wheels with 265-75-16 Buckshots to the B2,I will trim the fenders.
I am building my own winch bumper as we speak and will put my winch on B2.
It will get a CB,lites front and rear,remove rear swaybar,Rancho AAl off Ranger,I was lookin into a James Duff rear bumper with the tire carrier and one of his stage 1 or 2 lifts.And I will build my own sliders.
I am collecting parts to do a stock 5.0 efi swap. This I will need a lot of info on as far as hookin up trans,mounts,rads,etc....The 2.8 is just too weak and if I am swappin I aint gonna waist my time on a 4.0 when I could do a 5.0 just as easy.
So any tips,info or advice would be great guys!
Here is what I am starting with.
Old July 15th, 2008, 02:16 PM   #2
find a donor explorer and swap in the 31 spline 8.8 and TTB Dana35
make some extended radius arms and use either EB coils or XJ coils up front for max lift
Old July 15th, 2008, 03:39 PM   #3
deathbypsi
Brian R.
deathbypsi's Avatar
What years are the best donors? How is the width on the 8.8 for the b2?
Whats a EB coil and are you talkin stock XJ coils or aftermarket?
Old July 15th, 2008, 03:45 PM   #4
boggin-machine
boggin-machine's Avatar
eb= early bronco
Old July 15th, 2008, 09:43 PM   #5
91-94 are the only year explorer donors you can take both axles from
eb=early bronco=softer spring rate and better flex
XJ= depending on lift you want will determine what size coil and smae with the EB the xj coils are softer and flex better
Old July 15th, 2008, 09:49 PM   #6
xj97sport
atv rider
xj97sport's Avatar
listen to b2 .... he knows
Old July 15th, 2008, 09:53 PM   #7
88mudder
In the band!
If your going to wheel a few times a year then keep the stock axle in the truck. 4" suspension lift with some 31" muds will get u anywhere at the Mounds..except for the big mud pits. Thats about the cheapest way to do it, but if u wanna put more money into it do the d35 and 8.8 swap.
*I still got the Lund visor here..you were the guy interested in it right?
Old July 15th, 2008, 09:57 PM   #8
deathbypsi
Brian R.
deathbypsi's Avatar
#@&%$ my buddy just scrapped a 91 about three weeks ago...........
What are my gear choices for the front dana?
Old July 15th, 2008, 10:02 PM   #9
Shotgun
I only wheel with boats.
Shotgun's Avatar
the sploder should be 3.73 gears
Old July 15th, 2008, 10:04 PM   #10
from like 2 something up to atleast 5.13's
i ran 4.88's in my old explorer sport on 36's Iroks, the 4.88's were considerably cheaper then the 5.13's. Depending on tire size you wnat to end up at will determine your gear choice, but you can find stock explorer axles with up to 4.10's in them. But finding a stock D35 pig with 4.10's is pretty hard.
Old July 15th, 2008, 10:09 PM   #11
deathbypsi
Brian R.
deathbypsi's Avatar
I will only be using a set of 265/75-16 Maxxis Buckshots...just under 32".
With a efi 5.0 3.73's mite not be so bad...you think?
Please tell me these front 35's are stronger than the cv shafted 35 in my 99 ranger!
Old July 15th, 2008, 10:15 PM   #12
the D35 uses the same size ujoint as a D44 (use dana 5-760x ujoints), but you'll want to get the Warn Jeep hubs, the stock hubs are pretty weak, broke more then my share.
3.73 will do just fine with that combo, i have 3.73s in my 91 explorer and its on 4"s and 32s and it gets around just fine with the stock high mileage 4.0L and A4LD
Old July 15th, 2008, 10:19 PM   #13
spend some time here reading, should answer ALOT of questions
http://www.therangerstation.com/tech_library/index.php
Old July 18th, 2008, 04:01 AM   #14
deathbypsi
Brian R.
deathbypsi's Avatar
mudder...sorry bout that,I am passing on the visor cuz my roof is too messed up from the last one getting ripped off so I am just tryin to get it to stop leakin now.
Well I put some real gauges in it this week since it started to bury the stock temp gauge for no reason.It goes from stone cold to 220 in about 2min.I put a new rad,t-stat and waterpump on the 2.8 the week before. Does that seem too hot? Anyway,I am picking up the pace on a 5.0 swap. Tryin to pick up a 96 Exploder 5.0 tomorrow just dont have a harness yet. Since my truck has the C5 in it I am hopin it will be an easy swap that will live a while. I have a c4 bell off a 70 Mustang to use but no converter yet. Prolly use stock shorties and I am hopin to use the stock motor mounts with a little work.
Here are my next round of questions.
Can I just go to a junkyard and grab a efi sending unit out of a 86+ bronco2 for my efi swap? Are all B2 tanks the same?Lines I will make myself.
My 99 Ranger has a Aussie Locker in the front D35.....could I swap it into a TTB D35?
And what Jeep hubs am I lookin for? I have seen some cheap Warn hubs for B2 on ebay,not good?
Old July 18th, 2008, 07:48 AM   #15
good luck on the Explorer 5.0 swap, only know one person to have done it and it was major work and a royal in PITA to get it wired and get the comp working with everything.
88+ sending units are better, 86-87 used two fuel pumps, the 88-90 used a single pump that puts out the same PSI as the explorer pumps
no, the aussie from a 96+ ranger will not work in a TTB
The jeep hubs are Warns, their just a stronger hub then the warn hubs for a D35, they are an exact fit just better, read my lilnk i posted earleir in the thread
Old July 18th, 2008, 09:52 AM   #16
deathbypsi
Brian R.
deathbypsi's Avatar
The motor I am picking up is just a longblock. I plan to use all stock efi parts off a foxbody mustang. Not sure if I will go speed density or mass air ,that will depend on what mustang harness I find. I figure if I use a mustang harness I can put the ecm in the same location as mine and most of the wiring will just lay right into place.
I thought about just going with a carb to mke it easier but I dont have any intakes, carbs,dizzy or ignition parts. I have so many friends with Foxbodys they drag race the amount of free stock parts laying around is endless. The motor itself will be 75.00 and I can get intakes,injectors,throttlebody,fuel rail,egr,valvecovers,maf and bell for free.The only major part missing is a harness.
Old July 19th, 2008, 08:54 PM   #17
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
The 5.0 swap should be sweet if and when you gte through it, alot of ponies for a light vehicle, from what i have seen its a major pain though. depending on which trans you use i from what i have read, you will have to do a body lift but that should also allow the motor to fit better. also some year mustang motor mounts should bolt right up for you, 88mudder knows the specifics, im just recalling stuff from when i was planning a v8 swap into my old b2
Bronco351 is offline   Reply With Quote
Old July 20th, 2008, 12:47 PM   #18
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
yeah you either have to do a body lift or smash back some of the fire wall bronco sally has but 2 5.0 in 2 of his b2's its not to bad
Bronco Ollie is offline   Reply With Quote
Old July 20th, 2008, 07:03 PM   #19
deathbypsi
Brian R.
deathbypsi's Avatar
Well since the hammer is my favorite tool I think I will skip the body lift.
I ended up helping a friend in a pinch saturday and in return he is giving me a 100% complete EFI 5.0 out of a 92 LSC Lincoln with 87k on it.Throttlebody to oil pan and fan to flywheel. Now all I need is a ecm and harness!
So other than the $200.00+ mounts everyone sells what are my other options on the cheap side?
I also scored nice new seats,center console and roof rack off a 89 B2 today.
Old July 20th, 2008, 07:49 PM   #20
try B2bomber here on GL, he has a set of mounts and oil pan i do beleive
Page generated in 0.30131 seconds with 83 queries
