**SOLD**YJ frame nice shape w/axles 3:55 $400.00 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 14th, 2008, 09:09 PM   #1
gmotox
gmotox's Avatar
Default **SOLD**YJ frame nice shape w/axles 3:55 $400.00
1991 YJ frame real nice shape (light surface rust), motor mounts have been cut off ( i have section of other frame with mounts if needed) rear cross member has light bend from moving around yard. no springs included.
$400.00 o/b pm if interested
Eric
gmotox is offline
Old July 16th, 2008, 06:25 PM   #2
gmotox
gmotox's Avatar
bump
gmotox is offline
Old July 17th, 2008, 11:48 PM   #3
gmotox
gmotox's Avatar
trades?
gmotox is offline
Old July 20th, 2008, 04:27 PM   #4
gmotox
gmotox's Avatar
ttt
gmotox is offline
Old July 22nd, 2008, 01:36 PM   #5
gmotox
gmotox's Avatar
will sell axles and frame seperate if needed!
gmotox is offline
Old July 23rd, 2008, 08:57 PM   #6
gmotox
gmotox's Avatar
bump
gmotox is offline
Old July 23rd, 2008, 09:15 PM   #7
itchy
itchy's Avatar
Take $100.00 for the frame?
itchy is offline
Old July 23rd, 2008, 09:20 PM   #8
gmotox
gmotox's Avatar
you should be able to buy a rusted out cj7 frame at the scrap yard for $100
gmotox is offline
Old July 24th, 2008, 09:26 PM   #9
itchy
itchy's Avatar
OK thanks smart ass.
itchy is offline
Old July 25th, 2008, 12:57 PM   #10
gmotox
gmotox's Avatar
Lowered to $400.00 for solid frame!
gmotox is offline
Old July 28th, 2008, 11:06 PM   #11
gmotox
gmotox's Avatar
bump
gmotox is offline
Old July 30th, 2008, 08:49 AM   #12
gmotox
gmotox's Avatar
nobody needs a yj frame?
gmotox is offline
Old August 1st, 2008, 08:05 AM   #13
gmotox
gmotox's Avatar
will seperate axles and frame!
gmotox is offline
Old August 21st, 2008, 09:20 PM   #14
gmotox
gmotox's Avatar
nice frame!!
gmotox is offline
Old August 25th, 2008, 08:20 PM   #15
TCP
Keep On Jeepin On
TCP's Avatar
Has anything else been added or deleted from the frame besides the mounts? Is it a 4 or a 6? Michigan frame? D 30 & 35 axles? Did you grind the mounts off or burn them?
TCP is offline
Old August 25th, 2008, 08:41 PM   #16
gmotox
gmotox's Avatar
No brake or fuel lines trans crossmember has long bolts thru frame, mounts were torched off on mount side and need finish grinding, it was a 6cyl. Michigan frame, the axles are dana 30 and 35 there are no springs. po started v8 conversion, did all the work i bought it for a cj conversion and have since started other projects! frame is solid!
gmotox is offline
Old August 25th, 2008, 08:48 PM   #17
itchy
itchy's Avatar
Take $100 for the frame, oh wait I already asked you that didnt I. Well?
itchy is offline
Old August 25th, 2008, 08:51 PM   #18
gmotox
gmotox's Avatar
Nope!!
gmotox is offline
Old August 26th, 2008, 05:38 PM   #19
TCP
Keep On Jeepin On
TCP's Avatar
Do the long bolts go thru the original holes? Were the old ones stripped out or broke? What about other mounts you have? Might want to come take a look at it this weekend your not to far from me. Can you post some more pics of frame, trans crossmember bolts, rear crossmember, motor mount area, Etc.
I can give you my e-mail if needed.
TCP is offline
Old August 26th, 2008, 05:56 PM   #20
gmotox
gmotox's Avatar
it looks like the long bolts go through the original holes, i have this tucked away and have to move another frame of it to see pics clear, the other mounts i have are still attached to small sections of frame rail so no damage has been done them! if you go in my public profile there is a set of pics that should show everything! the rear crosssmember has surface rust not rotten!!
gmotox is offline
Page generated in 0.36610 seconds with 83 queries
