Any Briggs & Stratton experts here? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 13th, 2008, 10:33 PM   #1
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Default Any Briggs & Stratton experts here?
On my 111 lawn tractor I upgraded from a 11hp to a 12hp I/C engine. The old 11hp had one wire coming out of the charging system going to the wire harness. The 12hp I/C engine has 2 wires both with 13v output when running. I have one hooked up to where the original 11hp wire went, but it doesn't seem to charge enough beacause th battery will be dead after a mowing. Should this other wire be connected too, or should it be run to the pto to spare the load on the charging system? I'm not ruling out a junk battery here yet either. Basically what I'm wondering is, can this 2nd wire help with charing/power load in some way.
Old July 13th, 2008, 11:02 PM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I would get the alt. checked as well.
Old July 14th, 2008, 02:00 AM   #3
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
It puts out 13 volts out of both wires.
Old July 15th, 2008, 12:47 PM   #4
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Wouldn't really hurt anything to run the PTO off the other wire, I'd give it a shot at least. (if it's 12V DC)
I didn't work on I/C motors, just standard ones though years ago.
Old July 15th, 2008, 01:54 PM   #5
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
If I remember right,..........the I/C units actually run the headlights off from AC current (there is something they do funky with the mag)..............There is a special 6 prong key switch that you will need to purchase which will isolate the wires correctly. Otherwise you will have to add a toggle switch. This is what I believe the extra wire is for.
I have a wiring diagram somewhere, I will post an image of it tonight.
Page generated in 0.30889 seconds with 38 queries
