efi 460 swap into 79 ford bronco - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 13th, 2008, 07:19 PM   #1
greenbronco79
greenbronco79's Avatar
Cool efi 460 swap into 79 ford bronco
Hey I have a 79 ford bronco. My 351m has crapped out on me. I found and bought an efi 460 out of and 89 F-250 4x4 with an electronic overdrive transmission in it. I would love to put this motor in my bronco. I would like to keep it fuel injected. I have heard that if i keep it fuel injected I have to use the electronic transmission. Does anybody know if this is true. Thank you.
greenbronco79 is offline   Reply With Quote
Old July 13th, 2008, 08:09 PM   #2
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
I dont think you have to use the electric trans. Use the C-6 that is in the bronco now. Im going to be swaping in a 351w that is injected soon. Let me know how it goes.
Old July 13th, 2008, 08:10 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
dunno.
I do know you can build a very heavytruck by stacking a 460/C6 in the front of a short wheel base truck. tthe idea is good, but you have to have the suspension to back it up. 460 is 690lbs by its self. C6 is around 250lbs full of fluid. if you have a 351m they fall in around 540lbs so if you can make it light, it will help the short wheel base and the cost of moding your suspension to handle weight.
Yetti
Old July 13th, 2008, 08:53 PM   #4
Fraser
Fraser's Avatar
my buddy is running a stroked 460 in his '79, it is carb'd tho. prob run stiffer springs in the front? i can ask him about it if you would like
Old July 14th, 2008, 02:40 PM   #5
greenbronco79
I think I have the suspension to back it that shouldn't be to big of a problem. I have a six inch suspension lift with two struts and one coil. The front of the truck sits up a little higher than the rear now. I don't mind having a big heavy truck. I m just wondering about the electronic aspect with the Efi.
Old July 15th, 2008, 10:16 AM   #6
Fraser
Fraser's Avatar
ill ask a couple ford nuts that i know, but i wouldnt think youd have to run the electric trans just for the efi
Old July 15th, 2008, 11:06 AM   #7
TurdBronco
You could switch the computer out for one that came from a truck with a manual. The auto may work as well.
Old July 16th, 2008, 09:29 AM   #8
jackal
jackal's Avatar
i doubt the suspension will be an issue. i did a 460 swap just a few months ago and im having no problem. as my truck sits, i only have coil and 1 shock on each side with no issues.
jackal is offline   Reply With Quote
Old July 17th, 2008, 09:20 AM   #9
greenbronco79
Ok so I have decided to make my life a whole lot easier and I am just gonna go with carburated
Old July 17th, 2008, 10:54 PM   #10
masterbeatty
masterbeatty's Avatar
you can bolt the c6 up to the efi. and i do infact belive it will work. check out fullsizebronco.com thats a great site. your anwser will be on that site. good luck though
Old July 17th, 2008, 10:57 PM   #11
MISHOWJEEPER
NSFW
MISHOWJEEPER's Avatar
As long as you can hook up a kickdown cable to the throttle of the efi, otherwise, a c-6 doesn't need to be told what to do
MISHOWJEEPER is offline   Reply With Quote
Old July 18th, 2008, 03:11 AM   #12
deathbypsi
Brian R.
deathbypsi's Avatar
My buddy swapped a 89 efi 460 into his 79 Supercab. What a mess. The engine harness goes thru the dash because of the trans wiring so we had to cut and splice tons of wires to get the harness down to a bare minimum.He used a AOD with a UltraBell to bolt up to the BB,had a few converter issues along the way. Wiring the fuel pumps to still work off a switch to retain his dual tanks was another pita.
In the end it turned out pretty good just lots of hair pullin to get right. Gets pretty MPG and makes a good tow rig for his drag car.
I believe at one point he wanted to just slap a carb on it also but I dont think there is a carbed intake out there that will work with the efi BBF heads.
Old July 18th, 2008, 04:26 AM   #13
bigblockford79
Big Block Ranger
bigblockford79's Avatar
You don't even need the kickdown cable if you don't want it. The c6 reads vacuum to sense the load on the engine. The only downfall of no kickdown is when you stomp the pedal to pass on the road it doesn't drop down and come to life. I have been running without a kickdown on my 79 f350 with a carb'd 466 and have had no problems at all with drivability whatsoever.
The only thing you will need is a good source on manifold vacuum and an adjustable modulator to correct the possible difference in vacuum strength from carb to efi. Any new modulator you buy from the local parts depot should be an adjustable type.
Page generated in 0.35836 seconds with 62 queries
