Starting trouble..need help fast. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 13th, 2008, 10:07 AM   #1
P.O.S.
P.O.S.'s Avatar
Default Starting trouble..need help fast.
WE are leaving for silver lake in 2 days. jeep is not starting. Recently did engine swap (SBC) & rewired jeep. Jeep has been starting ok but yesterday drove it to get gas turned it off & now it won't start.
Seems to be enough battery power, sounds like the selenoid isn't kicking in. Just that "clicking" sound. Took starter up to get tested...tested fine. Come back home & install.. Same thing. just clicking. Got battery on charger now. Could a 1.5 mile drive drain the battery enough to not start it? Could it be the battery? Need help fast. I am guessing that since I rewired it I don't know shat about rewiring its probably a bug somewhere. But, like i said its been starting fine for weeks now. This trip t the gas station was the first trip where i stopped & turned it off, then tried to start it again. But I had done it in the driveway a bunch of times for tuning & other stuff. Need help Fast. If any body knows electical out there HELP!!!!!
P.O.S. is offline   Reply With Quote
Old July 13th, 2008, 10:09 AM   #2
Fraser
Fraser's Avatar
is the alternator charging the battery?
Old July 13th, 2008, 10:14 AM   #3
P.O.S.
P.O.S.'s Avatar
I am going to say no. I've been having to put it on the charger every couple days. But it has always started. At least when i tried to crank no matter how low the battery was. That is why i am really concerned.
Old July 13th, 2008, 10:48 AM   #4
P.O.S.
P.O.S.'s Avatar
Damn thing just started.
Old July 13th, 2008, 11:16 AM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
the "just clicking" could be 2 things,
either a stuck solenoid on the starter, or not enough juice.
try a different battery and see what happens.
oh, and if you wouldnt have put a stupid fucking chevy motor in your jeep you wouldn't be having these issues
Old July 13th, 2008, 11:24 AM   #6
x2
Old July 13th, 2008, 11:32 AM   #7
mudd_jumper
mudd_jumper's Avatar
what he said have the battery tested I beat you have a dead cell and the alternator is not charging or just trickle charging.
Old July 13th, 2008, 12:10 PM   #8
P.O.S.
P.O.S.'s Avatar
Got a great deal on the motor (400sbc), Trans (th350) & transfe case (NP205). couldn't pass it up. I think you guys are right Its on the charger now. I am going to leave it on for the rest of the day & possibly just get a new one.
Opinion now..... Optima? Red top?
Old July 13th, 2008, 03:52 PM   #9
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
check your grounds as well ALL of them.
Old July 13th, 2008, 03:58 PM   #10
Freak
Wheelin the HD
Freak's Avatar
well your at it test the alternator, that way when it comes down to it you know if it is a grounding problem or the alternator.
Old July 14th, 2008, 11:44 AM   #11
P.O.S.
P.O.S.'s Avatar
drove around a bit & voltmeter stayed steady. No droppage. Could I tell that way? Has been no issue since the one time. Thinking its the solenoid.
Old July 14th, 2008, 11:51 AM   #12
max5p33d
slack jawed faggot
max5p33d's Avatar
Send a message via ICQ to max5p33d Send a message via AIM to max5p33d Send a message via Yahoo to max5p33d
Id bet you dont have the alternator wired to charge the battery properly.
max5p33d is offline   Reply With Quote
Old July 15th, 2008, 11:41 AM   #13
P.O.S.
P.O.S.'s Avatar
that's what I am figuring too. I bought a Summit universal wiring harness (piece of Shit) & wired it like it says. I have been looking at the painless site & just trying to use them as a guide. DO NOT BUY the summit set. Directions are horrible & very vague. I was trying to save money. silly isn't it..being a jeep owner & all.
Page generated in 0.32780 seconds with 62 queries
