1993 Suzuki Samurai. DONE for now!!!!!!!!! - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 31st, 2009, 09:41 AM   #161
cruiserjg
dodge man
cruiserjg's Avatar
Originally Posted by 4Bangler View Post
I can't read this anymore, I can't take the suspense, I'm old and I will probably pass out.
Will it do wheelies when it's done? Please just tell me it will do wheelies when it's done so I can sleep at night. Hurry up and finish it so we can see some wheelie shots.
No seriously, nice work, hurry up and finish it.
NO wheelies i am going to have like 140 HP but it is better than the stock 95hp.
Going to work on it now.
cruiserjg is offline   Reply With Quote
Old May 31st, 2009, 10:47 AM   #162
VonDirt
VonDirt's Avatar
nice progress, great work
its coming together, good to see . . .
VonDirt is offline   Reply With Quote
Old June 2nd, 2009, 09:31 PM   #163
cruiserjg
dodge man
cruiserjg's Avatar
Default update 6/2/09
Working tail lights
Old June 11th, 2009, 10:36 PM   #164
cruiserjg
dodge man
cruiserjg's Avatar
Default Update 6 11 09
guage pod
4.7 tcase gears
motor and trans ready to go
Old June 13th, 2009, 07:52 AM   #165
pfreer
old newb
pfreer's Avatar
That mount looks better, more underside protection.
pfreer is offline   Reply With Quote
Old June 17th, 2009, 08:13 AM   #166
cruiserjg
dodge man
cruiserjg's Avatar
charger going back together
I still need to take the oil pan off and weld in the oil return line and then it can go back in.
Old June 17th, 2009, 08:42 AM   #167
95geo
newbie
95geo's Avatar
this thing is cool, I dig it!
Old June 17th, 2009, 08:47 AM   #168
cruiserjg
dodge man
cruiserjg's Avatar
Thanks
I wish that I had more $$$$ to put into it I would have done some things diferant. When I started it was going to be a low $$$$ build with out a good plan. But I think in the end it will turn out good.
Old June 17th, 2009, 09:18 AM   #169
95geo
newbie
95geo's Avatar
theres nothing wrong with a low budget build, hell, half the time those turn out cooler and nicer than the high $$$$$ ones.
if I were to build a zuk it would be pretty similar to this one. Do you have any pictures showing all of it in it's latest condition?
Old June 17th, 2009, 10:19 AM   #170
cruiserjg
dodge man
cruiserjg's Avatar
maby this weekend i will get more pics, now the motor is out the trans is out. I need to plumb the brake lines befor it goes back together I am going to install my line locks valves forward of the shifter . I got some Swagelok ballvalves to use for parking brakes.
Old June 19th, 2009, 07:35 PM   #171
VonDirt
VonDirt's Avatar
i like the treatment on the rear
what all did you do on the camden, new bushings ? seals ?
Old June 20th, 2009, 09:24 AM   #172
cruiserjg
dodge man
cruiserjg's Avatar
The charger needed new rotors , shafts, bushings and seals.
The last owner droped a bolt into it. Luck would have it that the bolt stoped the rotors and the belt sliped.
Old June 21st, 2009, 07:12 PM   #173
pfreer
old newb
pfreer's Avatar
I'll bet a coke or your choice it still won't make it to S.Lake.
Got the Front D-shaft in today, looks good, gotta check droop/compression clearance, but looks ok static.
I just got a few clean up items left after the R&P. Things that should have been done already.
Red Lock tite on the rear disk bracket bolts (they were loose again when I took it apart)
Mount hi-lift
fab up a mount for air tank & handle for tank
clean up triple shift area
Better box for the porto-welder
Old June 22nd, 2009, 07:28 AM   #174
cruiserjg
dodge man
cruiserjg's Avatar
Mount hi-lift
do you still need a shifter dust cover?
I think I can have it ready for Silver lake it will be and easy shakedown run.
Old June 22nd, 2009, 02:08 PM   #175
cruiserjg
dodge man
cruiserjg's Avatar
Default update
This stuff takes forever.
clutch line
Next get the motor in and running.
Old June 22nd, 2009, 02:26 PM   #176
cruiserjg
dodge man
cruiserjg's Avatar
I forgot this is the reason for the line above the trans.
Old June 23rd, 2009, 10:50 AM   #177
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
I really like this thing, almost makes me want to find a sammy... must resist... already... have the... flattie! lol
BeaverTown is offline   Reply With Quote
Old June 29th, 2009, 09:26 AM   #178
cruiserjg
dodge man
cruiserjg's Avatar
The heat has been kicking my a$$ There will be more updats soon.
I got the moter back in and the cluch on. Then started the wiring.
Old June 29th, 2009, 11:25 PM   #179
cruiserjg
dodge man
cruiserjg's Avatar
Default update 6-30-09
Trans is in and clutch is working.
Some shots of the suspension at full droop
This is one thing I do not like I should have made it with a flat belly.
Old July 9th, 2009, 09:47 PM   #180
cruiserjg
dodge man
cruiserjg's Avatar
well I will get pics later
But I fired the motorand it runs strong. I had not ran this motor befor this realy.
The super charger sounds good but I am having a problem with coolat flow I will look into that tomarow.
Page generated in 0.47673 seconds with 84 queries
