1993 Suzuki Samurai. DONE for now!!!!!!!!! - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2009, 07:37 PM   #121
cruiserjg
dodge man
cruiserjg's Avatar
Default Udate 1/4/09
Well this stuff had to be redone I did not like how I had it at first. I also got the mill wired back up and was able to start making some rim stiffeners.
Test fit
cruiserjg is offline   Reply With Quote
Old January 4th, 2009, 08:15 PM   #122
Rayden21
Hell Yeah It's Fast
Rayden21's Avatar
Very cool build, looks great.
Rayden21 is offline   Reply With Quote
Old January 5th, 2009, 07:44 AM   #123
VonDirt
VonDirt's Avatar
making good progress -
what grade aluminum did you go with on the stiffeners ?
VonDirt is offline   Reply With Quote
Old January 6th, 2009, 03:14 PM   #124
cruiserjg
dodge man
cruiserjg's Avatar
I think it is somewhere in the 3000 range it is kinda soft but it was almost free. I am going to test weld on a junk rim first.
Old January 18th, 2009, 04:08 PM   #125
cruiserjg
dodge man
cruiserjg's Avatar
Default 1/18/09 Update
worked on the fan shroud
I could only fit a 12" fan I hope it is enough air
thats all for now
Old January 30th, 2009, 04:47 PM   #126
pfreer
old newb
pfreer's Avatar
I like the alum shroud, if it doesn't pull enough air, you can make a perimeter shim to set it off the fin surface about a 1/16" (you'd have to cover those pass through holes).
Looks also like you might be able to cram a 6" fan off to one side also (if you have too). I've seen 6" ers on A/C 2ndary fans on some hundai car or something when I was at the pick n pull.
You could wire it in as a 2nd stage if you have an electric thermostat.
I've done this about 4X over, and finally got it right. Only time I get into trouble now is when I'm stuck in a rock pile & on the throttle, then it gets up to 230 or so.
P.S.- I'd reccomend wiring it into a lit switch, so you can see when its on. We've both had issues with forgetting the fan switch is off. :0
I still have to do my trans cooler fan that way.
pfreer is offline   Reply With Quote
Old February 1st, 2009, 06:50 AM   #127
VonDirt
VonDirt's Avatar
x2 on the gap
might not be enough volume behind to create a plenum.
it looks tight in there - might be able to use some gasketing material on the perimeter to create the gap and seal it at the same time.
Old February 1st, 2009, 06:42 PM   #128
cruiserjg
dodge man
cruiserjg's Avatar
x2 on the gap
There is .500" behind the shroud to the core. I dont think that I can get any more room than that with how it is set up now. I did seal the shroud on the top and bottom with some fome tape. I like the idea of the 8" fan. I will add that if it runs hot.
Old February 2nd, 2009, 06:06 AM   #129
VonDirt
VonDirt's Avatar
.5 should work fine -
it looked like it was really tight in the pix. time for an eye exam i guess -
Old March 10th, 2009, 09:47 PM   #130
ibanuts
ibanuts's Avatar
Send a message via MSN to ibanuts Send a message via Yahoo to ibanuts
Look`n sweet.Sammi`s rule.
ibanuts is offline   Reply With Quote
Old March 10th, 2009, 10:39 PM   #131
92comanche4x4
92comanche4x4's Avatar
is that the offroad place just off 127
92comanche4x4 is offline   Reply With Quote
Old March 12th, 2009, 01:37 PM   #132
kayler3
I Understand
kayler3's Avatar
Yes it is!
kayler3 is offline   Reply With Quote
Old March 15th, 2009, 05:25 PM   #133
jeepman784
Now pedals a bicycle
jeepman784's Avatar
Send a message via AIM to jeepman784
when you did your rockers, did you pound your floor up? i cut the original rocker panel off, and the front 1/3 hangs down behind there from the floor of the drivers side
jeepman784 is offline   Reply With Quote
Old March 16th, 2009, 08:14 AM   #134
cruiserjg
dodge man
cruiserjg's Avatar
The body was rusty enough that I cut metal and rust out and then I found a pice of metal 3x6 to make new rockers. You can not jist weld it to the body though the rocker tube will neet to be suported. Hear are some pics.
The cut I made was all the way to the bottom of the door.
I hope this helps. BTW its harder than hell to weld to the sheet steel.
Old March 16th, 2009, 09:44 AM   #135
jeepman784
jeepman784's Avatar
yea, that makes sense. i was thinking of having them welded straight to the frame. i just noticed that after i cut ~1" below the door, behind there was not flush because of the dip in the floor. i figure it'll get covered well enogh if my support tube from the frame goes across there.
i think i got confused by your pics because i assumed i did the same cuts as you. i cut additional stuff off of the body
i guess ill just have to have the boatside/slider up as tight to the body as i can
Old March 29th, 2009, 09:23 PM   #136
cruiserjg
dodge man
cruiserjg's Avatar
Default update 3/29/09
Needed to fix the rear shock mounts and brace the rear cage and fenders.
I made a seat frame
I made the tailgate drop down
Making my intake for the super charger
first time tig welding the aluminum.
Moved the tstat neck so I could use a toyota lower rad hose top and bottom.
thats all for now.
Old March 29th, 2009, 09:26 PM   #137
scottie
Eye candy
scottie's Avatar
I like the Tailgate
Old March 29th, 2009, 10:56 PM   #138
nathanthegreat
not really
nathanthegreat's Avatar
looks good!
nathanthegreat is offline   Reply With Quote
Old March 30th, 2009, 03:42 PM   #139
roll-bar Bob
roll-bar Bob's Avatar
Nice
Old March 30th, 2009, 05:26 PM   #140
cruiserjg
dodge man
cruiserjg's Avatar
Originally Posted by scottie View Post
I like the Tailgate
Thanks scottie
the swing out was driving me nuts
Page generated in 0.41000 seconds with 84 queries
