1993 Suzuki Samurai. DONE for now!!!!!!!!! - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2008, 09:00 AM   #41
cruiserjg
dodge man
cruiserjg's Avatar
Originally Posted by scottie View Post
Wouldn't it have just been easier to put the Samurai body on a toyota?
I wandted a one of a kind, also it was this or a buggy.
Let me know when you want to make it to the top of test hill and we can put a toyota motor in your zuk.
cruiserjg is offline   Reply With Quote
Old August 29th, 2008, 09:48 PM   #42
pfreer
old newb
pfreer's Avatar
Man glad to see some work getting done...
Hope the head light mount is temporary, that bitch i'll bounce like crazy going down a dirt road.
Also, looks like you have room to run the exhaust over top the Xfer case mount on the left side. You probably already thought of it. My VSS adapter looks like it will hit the crossmember on the top side, I'll have to work that out.
I think when I do my X-member I'll have to fab up some weld in mounts @ work. Press brake/sheet bender/ironworker available onsite!
Wanted to log in & comment earlier, but I couldn't remember my mother huffing password.
P.S. - I think you should part out the 4runner, you'll end up with more out of it in parts.
pfreer is offline   Reply With Quote
Old August 31st, 2008, 08:55 PM   #43
cruiserjg
dodge man
cruiserjg's Avatar
Default weekend update
sorry about the bad pics they were on my phone
Old September 1st, 2008, 09:11 PM   #44
pfreer
old newb
pfreer's Avatar
Thats gonna look nice with a 1/2" of liner on it. You should make another hole cover that fits over the shifters with just the shift pattern. Probably you already planned.
You could run some 2" gages in that verticle sheetmetal in front of the shifter.
Old September 2nd, 2008, 08:28 AM   #45
cruiserjg
dodge man
cruiserjg's Avatar
A gated shifter would be cool.
Or a cup holder in front of the shifter.
Old September 2nd, 2008, 08:34 PM   #46
cruiserjg
dodge man
cruiserjg's Avatar
Default tusday update
Old September 2nd, 2008, 08:42 PM   #47
scottie
Eye candy
scottie's Avatar
I see you actually worked on it after i left.
Old September 2nd, 2008, 08:47 PM   #48
cruiserjg
dodge man
cruiserjg's Avatar
YES I DID
Old September 3rd, 2008, 02:33 PM   #49
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
cup holder would be best lookin good
mpsbvp is offline   Reply With Quote
Old September 8th, 2008, 11:08 AM   #50
cruiserjg
dodge man
cruiserjg's Avatar
Default weedend update
Well not ready for the OSTC run but gitting there.
Thats Paul making sparks.
thats me cuting the spring capture plates
Arp studs
Hopfully the front and rear axles will be done by Fryday
I also got new rubber for it 35/10.5/15 boggers I will get pics up whith them on it as soon as the axle is done.
Old September 9th, 2008, 09:43 PM   #51
pfreer
old newb
pfreer's Avatar
I'm jealous of your purple oil pan....
That was fun, we should do that again. Don't know what I was thinking when I put the knuckles on the wrong sides, you can clearly see the R stamped on the Driver side knucle in one of the pics. Apparently was pretty tired by then.
Thanks for the springs, I remember you saying one had a broken leaf, but I looked them over & didn't see any
I'm going to try to use the set with the least arc, hopefully that will drop the body about 4".
Old September 9th, 2008, 10:07 PM   #52
cruiserjg
dodge man
cruiserjg's Avatar
Then you could run a set of 31" tires.
I got some metal in my eye had to have the doc dig it out no work on zuk till healed.
Old September 20th, 2008, 07:20 PM   #53
cruiserjg
dodge man
cruiserjg's Avatar
Default axles are in time for drive shafts
How to make the toyta front axle as wide as the 86 and newer rear ifs axles.
IFS calapers
FJ60 rotors
stock spindle and bearings
stock lockout
move the calaper to the outside of the ears
Drill and tap the calaper holes to M16 by 2.0
remove 2mm to help center calaper
Old September 21st, 2008, 09:05 AM   #54
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
I want it BAD. build me one. nice ride
tcxtreme1000 is offline   Reply With Quote
Old September 21st, 2008, 10:44 AM   #55
cruiserjg
dodge man
cruiserjg's Avatar
Thanks
Bring me a samurai after I am done and large sum of cash.
Old September 21st, 2008, 11:03 AM   #56
cruiserjg
dodge man
cruiserjg's Avatar
Default drive line and battery box update
Has anybody ran a compounded angle on a rear drive shaft like this? Do you think it will run vib free?
Hear is the batt. box plated in.
and yes I know the d shaft is to short still need to retube it.
Old September 21st, 2008, 11:26 AM   #57
pfreer
old newb
pfreer's Avatar
I still think you're going to have mud coming up through that box, but I agree it does need some kind of drain
Do you have any other option than the multi angle shaft? Guess you could cut everything out & move the motor over???
I say fawkin run it
Got my pad forms finished today, started picking up sticks from the storm & found 2 trees in the woods fell over BIG ones.
more crap to do
Old September 28th, 2008, 05:16 PM   #58
cruiserjg
dodge man
cruiserjg's Avatar
Default 9-28-08
Weekend update
Old September 28th, 2008, 05:36 PM   #59
Pre4runner
Bike Dude
Pre4runner's Avatar
Super sick looking ride, very close to how i would build a sammi
Old September 29th, 2008, 05:37 PM   #60
cruiserjg
dodge man
cruiserjg's Avatar
Thanks it should start to come together faster now.
Page generated in 0.54152 seconds with 84 queries
